Well Im starting a four door build some what simular to Drews. I will try to show the progress as I go along with the build.
My build starts off with a 1968 sub. that is a factory 1 ton 4x4 one owner Arizona truck with a 6 cylinder 4 speed. Truck # 2 is a 2011 silverado extended cab which i will use the fire wall , some of the floor and all of the drive train which only has 5k miles on it. The motor is a 5.3 and the trans is a 6 speed auto which should be very reliable. Truck #3 is a 71 GMC 3/4 ton withe a very clean cab and doors in which I will use the back half of. All of the parts I dont use will be for sale to who ever needs them. I am open to any suggestions on this project.
Re: 68 Four door build
intresting... im in
This is one of my projects I built, it was a original 2wd blazer that was burnt to the ground and sat in a back yard for years until i got it and put a late model motor and trans in it and a complete resto. This is a great little blazer.
maybe I will call it (Burban Blues) what do you think?
Tot Roddin'
Can't wait to watch this come together.
Where did you locate the 2011 donor?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
PROJECT 7DEUCE
Im in what the heck was the sub used for chasing storms or something?
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I'm in. Sounds like a very cool build!
69 chevy stepside (project) ![]() 2006 Silverado Z71 Ext. cab ![]() 2005 Saturn VUE (wifes dd) |
Nice project. Only 257,500 more views and you can tie Drew (but his is still a moving target).
The Silverado was on craiges list for two thousand dollars, what a score that was. The suburban is coming out of Arizona tomorow when I go and pick it up, 7 hour drive one way. I think the suburban was used as a camping vehicle.
Posted via Mobile Device |
Re: "Mad Max" 68 Four door build
Well my daughter and I went for the 6 to 7 hour drive to pick up the suburban from Benson Arizona and it turned into a 10 hour drive one way. When we got there the paper work was in a bag that said mad max so I will call it that for now. The suburban is so clean I hate to cut it up but we all must make sacrifices. The burb is a factory 6 cylinder 4 speed 4x4 with the cleanest no rust body I have seen in a long time and it only has 69k miles on it. As I'm typing this we are waiting for a pizza here in Gila bend Arizona and still have hours and hours of driving to go tonight. I will post more pictures when we get home with this jewel.
Posted via Mobile Device Last edited by tomsprojects; 11-27-2011 at 01:18 AM. |
gets board easy.......
This is gonna be nice.
Cool blazer too Posted via Mobile Device |
6>8 Plugless........
![]() Join Date: Sep 2007
Sweet project, I'm in too! Sweet Blazer BTW!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#13 |
sounds like a sweet project, nice score on the donor 2011
2008 HD 2010 Camaro 2ss (The Wife's Ride) 2005 Suzuki GSX-R 1300 "Busa" 1969 C-10 (under Construction) 2013 Sonic LT "LIVE LIFE,TASTE DEATH" |
#14 |
Tot Roddin'
That was an amazing deal on the 2011 drivetrain.
#15 |
VA72C10
![]() Join Date: Mar 2008
Awesome project. Sounds like I want to do but not sure if I'll ever have the time/cash to pull it off....
Glad you're going to do the 4th door....will be a lot of work but WELL WORTH IT!!! Will put this build over the top on the cool factor!!! Which front end are you going with? Short or long bed and stock height, lifted, or lowered?
Looking for a 67-72 swb or blazer project in or around VA.
#16 |
![]() Join Date: Apr 2005
Another cool project.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#17 |
![]() Join Date: Jun 2010
Great project Tom. I can hardly wait to watch it in person.
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
#18 |
Re: 68 Four door build "mad max"
Well we finally made it home with the Burban. What a long drive that was, by the time we loaded it up it was huge on my trailer and we couldnt take advantage of that 75 mile an hour speed limit in Arizona (more like 50-60 tops) but it was with out any problems the whole way back.I will post more pictures tomorow after I get some sleep tonight.
#19 |
![]() Join Date: Nov 2011
Im in great build
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
#20 |
Any one out there need the factory running gear out of this 4x4?
#21 |
Sweet truck man. This will be fun to follow along.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#22 |
![]() Join Date: Oct 2011
Cool Snap-On sweater, oh and the burban is cool too lol
#23 |
Yea if you was alot closer.Cant afford shipping.Going to be a cool build.
1991 GMC K2500 4X4 350/auto 1991 Chevy S10 ext cab. 1990 Chevy S10 1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto |
#24 |
I'm in too. Hope to see that fourth door! Nice score on the '11. I would have hated to have been in that truck when that happened. Good luck!
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
#25 |
Grandpa in the rustmobile...
im in!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
| Bookmarks |
