Closed Thread
Old 04-26-2012, 03:25 PM   #76
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Re: Restored Auto Tilt Column
Originally Posted by southern parts View Post
how much pressure is put on the weld as you turn the wheel, even if you dont have power steering. it would have to be a really crappy weld to break under normal use of turning the wheel.
Yes... I have done plenty of butt welds in my day. Also worked as a glazier for 10 years. 6 years of that employed at one of the largest glazing companies in the midwest. If anyone is interested in seeing some of my work please feel free to look here http://www.yourascent.com/the-view/p...px?section=All. This building was designed by Daniel Libeskind, a world renowned architect known for his ground breaking asymmetrical buildings which seem to defy gravity. He was also chosen as the lead architect with the design of the monumental new World Trade Center Project. Me and my brother welded frames attached to structural tubed steel for every high end balcony on this condo and hand set every panel all the way up to the 27th floor penthouse.
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline
Old 04-26-2012, 03:32 PM   #77
HeavyMetalChevy
Just a Member
and here are some pics
TH400(3rd)
Old 04-26-2012, 03:37 PM   #78
HeavyMetalChevy
Just a Member
I think I got a steering shaft covered.
TH400(3rd)
Old 04-26-2012, 03:59 PM   #79
ls1nova71
ls1nova71's Avatar
True, but I've seen some really crappy welds done by people who think they're doing a good job. Add that to the fact that you cannot inspect it because it's inside a column. It's just not really worth the risk for what, a hundred dollars or so?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline
Old 04-28-2012, 10:46 AM   #80
BBC Motorhead
Just wondering what you have available at the moment? Thanks
BBC Motorhead is offline
Old 04-28-2012, 08:34 PM   #81
HeavyMetalChevy
Just a Member
I have around 5-6 van tilts, one rv tilt which has the correct length steering shaft, and one true truck tilt.
TH400(3rd)
Old 04-30-2012, 09:59 PM   #82
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 05-01-2012, 04:28 AM   #83
IndyRich
IndyRich's Avatar
Hey buddy, Just wanted to check in and say hi. I recognized that building you worked on right away.Awesome structure. When I go to Cincy to see Reds games it is next to the Roebling Bridge which was designed by Roebling before he did the Brooklyn bridge.
(I trust my bed supports are still safe. I promise to get over to you on my way to Cincy for a game)
IndyRich is offline
Old 05-01-2012, 02:59 PM   #84
HeavyMetalChevy
Just a Member
Yeah man! Sweet you know some local Cinci/ Covington history as well. Bed sills are still hanging around. No worries there. I got plenty of room here so def. not in the way.
TH400(3rd)
Old 05-01-2012, 10:21 PM   #85
72Blazing
72Blazing's Avatar
Payment sent on Truck Tilt.
Thanks Duane
72Blazing is offline
Old 05-01-2012, 10:34 PM   #86
HeavyMetalChevy
Just a Member
Thanks Duane
Yes sir.. I was wondering why nobody jumped on it. It's going to be awesome!!! I will dedicate a thread for it!
TH400(3rd)
Old 05-01-2012, 10:36 PM   #87
72Blazing
72Blazing's Avatar
Step by step on restore process would be a cool thread.
Old 05-01-2012, 10:41 PM   #88
HeavyMetalChevy
Just a Member
too many secrets there buddy! A lot of steps and plenty of cussing at first!!! BAHAHAHAH
TH400(3rd)
Old 05-01-2012, 11:03 PM   #89
72Blazing
72Blazing's Avatar
I bet. That is why I leave it to the pros!
Old 06-03-2012, 07:32 PM   #90
big d's red67
big d's red67's Avatar
do I have this right, you do not move the NNS to the truck location when you rebuild a van column to put in a truck?
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline
Closed Thread
