Re: Survivor 76 Crew Cab
I’ve watched for GMC 12” 3/4 ton caps since I got the truck. Lots of 1/2 ton 10” caps out there. Not many 3/4 ton.
I only have the 2 stainless. Ideally I’ll find 2 more, smooth out any imperfections and get them powder coated along with the 16” ford van rims. The truck still has the 16.5” wheels. |
Didn't mean to give the wrong impression on your project, just trying to emphasize how uncommon the base look was in the mid to late 70's. '78 was the end of the era for white painted hubcaps, a tradition that dated back to the 50's. These are the details that make your truck special, something '79 and newer trucks never came with.
Still working away. Picked up 2 yards of soil at lunch today.
And the workers unloading it Last edited by ACS; 09-18-2020 at 03:54 PM. |
#4 | |
Just here to tinker
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
I had a 75 A/T that was factory with the fat style gas peddle in Canada North East.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 09-21-2020 at 10:07 AM. |
Looking more at them. I'M thinking that the smaller gas peddle came with the clutch set up to give more space between the peddles.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
I picked up some new rear brake shoes. I’ll spare you photos of a brake job, but while I was cleaning up the backing plates I started looking closely at the axle U bolts
I don’t know what the half ton trucks use, but if you’ve got a 3/4 or 1 ton with the spring plates that trap and hold dirt - check your u-bolts. I cut one off and had the local spring shop bend me up some replacements. Last edited by ACS; 09-24-2020 at 06:26 AM. |
When you have the time could you take a pick of the fire wall and how the manual pedal and bell crank come out and or go in the steering column is so close and I Am interested in the bends on the rod. Thanks for the wonderful truck and the photos youve posted. Good job on keeping the cash handy to purchase it.. we all know how hard it is when you got a work crew like that.
Posted via Mobile Device |
#9 | |
On the engine bay side, the bend in the rod is inside the rubber boot - the boot is right up to the bell crank connection. There appears to be quite a bit of room all around with respect to steering column proximity. If you want more detail on the bell crank, I can take a few photos from below. |
#10 | |
Thanks it helped me understand so much. |
I discovered that the VIN got typed out wrong at some point on the title. TCLxxxx had been typed as TC1xxxx. I went to the licensing office to figure out how to get it fixed. Not really that big a deal, go to a dealer, have them verify it in writing and bring that back. Got that sorted out, and in the process took the truck back to the dealership where it was sold when it was new. The service manager has an ‘80 he’s in the midst of doing an LS swap in - I think that’s why he took sympathy on me and got me the info I needed for the VIN.
Hauled 800 pounds to scrap. The local scrap yard also keeps random older vehicles that come in. So after I weighed out I looped back and picked through a few square bodies that were in the yard. Grabbed an OEM crack free taillight lense for $5. Needs a polish, but it will replace one of mine that is cracked.
Didnt want to park to close - the magnetic claw is always on the move. |
#13 |
Nice truck , I see those 8 lug rims and was wondering what size they are? I riding a 77 Suburban K20 and am having a terrible time finding 16.5 tires
#14 |
Junior Member
You have two 16.5" tire choices anymore. Super Swampers or 37" Wrangler military tires. Neither of which you want anyway. Best option in my opinion is get a set of 16x7 Ford van rims. Up to 1996 model year or so. They are cheaper than aftermarket 8" rims and give you a little more width than our 16x6's
"I was patina when patina wasn't cool." 1973 Cheyenne Super SWB Sunset Gold / Frost White / Saddle |
#15 | |
The Firestone Transforce are still out there new in 9.50x16.5 as of today at about $170 a tire. STA - Specialty Tire of America also has some more vintage sizes. Theres also a tire called Power King that pops up online in the 16.5 diameter. It says its an all-season radial, but it sure looks like a trailer tire to me. |
#16 |
Thanks for the info, I'm going to look into the ford 16's.
#17 | |
![]() Join Date: Feb 2000
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#18 |
@burnclown Funny you ask, its another reason I dont tread to far into the scrap yard - puncturing a NLA tire. The wheels are 16.5 with an aging set of Transforce tires. Im going to do the Ford Econoline 16 wheel swap when these tires are done.
#19 |
The thing is that once you swap to 16" wheels you can get tires just about anywhere. Sometimes you ruin a tire and need another one Right Now!
When I bought my 76 C/20 in 1996, the first thing I did was go out to the salvage yard and swap the 16.5" wheels for a set of five 16" wheels with some usable 245/75T16 tires.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#20 |
After 2 pages of hubcap discussion, Ive finally found a set of the proper white painted GMCs. Theyre a bit rough, but its a great starting point.
#21 |
Out of hibernation
#22 |
Beautiful truck! Nice score on the hubcaps.
#23 |
When I got the truck I picked up a new cap, rotor and plugs. I swapped the plugs out at the time, but the cap and rotor ended up sitting on the shelf. I switched the stuff out this morning. I feel pretty bad now for not doing this immediately, I don’t even know how it ran.
I’ve also resealed the thermostat housing/water neck - again. Filed the housing flat and am trying a paper gasket painted with Permatex Aviation. |
#24 |
So the Permatex on the paper gasket did the trick. Haven’t seen water leaking at the thermostat since I resealed it.
Just been using it. Hauling water & gravel a bunch this season. Just did an 80 mile round trip to the beach @15mpg. Not bad for the SM465 & 4.10. |
#25 |
Havent done much to the truck. Just been using it.
| Bookmarks |
