#76 | |
Re: 71 GMC engine swap-arino
The one you listed is I believe only for the driver's side which is definitely a start, thank you. Only major issue I for see is... I have no idea where any of the bolts go *facepalm* |
#77 | |
Did you get the water pump pulley? Any braces? It's all the little things that make these serpentine setups cost more if bought incomplete. You may be better off going to a junkyard or pick-a-part where you can get all the bolts and braces. You will need another p/s pump or at least a pulley anyway (and it requires a proper tool to remove the pulley, a jaw puller just destroys it as you see).
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#78 | |
#79 |
If I was in your shoes, I would go to your local pick-a-part (you do show having one in Phoenix) and buy a matched power steering pump with the bracket, A/C bracket, water pump pulley, and crank pulley. 4.3 Blazers/S10 and 4.3/5.0/5.7 Pickups/Suburbans in the 90s are good sources. Camaros and Firebirds too. Corvette is also nice but less likely to find and uses a shortish aluminum water pump that can't add a fan to it (forces you into electric fans). Van ones are not as good I don't think, could be wrong. Take it off yourself so you get all the bolts and braces. You have an alternator core I think and an a/c compressor core so you don't need those. You will need a new water pump from whatever vehicle you use. You probably want to avoid Vortec V8 engines 96 and up. I think you can resell what you have and still come out ahead on trying to piece it together. Good luck.
Yes, the p/s pulley is press fit. You need a special tool to take it off. I have seen people disassemble the pump and leave the shaft and pulley together to rebuild a pump, but if I bought a used pump and it wasn't covered in oil I would just run it. There is likely a difference in the threads on the high pressure hose from your existing pump to that one but maybe the fitting interchanges? EDIT-A Serpentine setup is nice, but not really necessary. You really only need a crank pulley to use your original pulleys and add a/c. IMHO the CS130 alternator and R4 compressor are not as good as a 12SI alternator that will fit on your existing alternator bracket and add a Sanden a/c compressor with brackets when you go to Vintage Air. R4 compressor brackets won't support a Sanden Compressor but the later 4.3 S10 Blazer ones do have a pad mounted a/c compressor. Not sure it's as good as a Sanden but the Nippendenso version is pretty good. The offshore version is junk.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 01-29-2025 at 05:05 PM. |
#80 | |
#81 |
No real progress today, went to the salvage yard for some other tinkery stuff like a spring shackle... Waiting on the ARP exhaust manifold bolts and Amazon hasn't sent me a replacement 2604 intake yet... Don't get an intake manifold from Amazon... What a pain.
#82 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
I've always bought stuff like manifolds from local speed shops. Online stores are all about moving product, but if you're standing at the counter looking a person in the eye, things are different. For instance, I bought sport wood steering wheel from LMC It went to caca and cracked right out of warranty. If one can take the part back to the seller and hold up the offending product, especially with potential customers in the room, things get handled much more to one's satisfaction...without, I'll say, going all Karen about it.
#83 | |
#84 |
Does anyone know what part number this alternator mounting bracket is or what I would even call it to search for it?
#85 |
Cleaned up the serpentine brackets, got all the bolts + other needed assorted stuff for the brackets from the salvage yard (no alternator in the bracket or I would have taken pictures) changed out the blinker switch. Kids were helping, so I had fun. Not a lot of progress but fun for sure.
On a side note, can someone explain the conversion to a "CS" alternator like I'm 5 years old? Please... I've been reading alot the threads on how to do it... I'm either super confused about what is needed or go they into the reasons why the newer tech is better. I know the newer tech is better. I just need a simple explanation as to how to get it done. Also there so many conflicting opinions about what size wire(s) and I'm not 100% sure what all I need to change. I was planning on putting the 12si in the truck as it is now and redid the wires from the 10dn to the external regulator and the battery (mainly the ones going across the radiator) to 12 & 10 ga respectively... But I've seen things saying I'll need 8 ga wire... Should I just upgrade all the wires to 8 ga? Etc... Like I said please explain it/give me a step-by-step like I'm 5 yo... All the information is making my brain atrophy. And does anyone know what alternator fits these brackets? Or is there a kit to mount a 12si (for later) Update: Ok after re-reading for the 10th time, I think I finally understand what I need to do for the "upgrade" however when I do rewire do I need to use 10,8,or 6ga wire from the Alternator to the battery and what about from the "T" junction to the fuse box? Also I'm still a little confused as to what resistor(rating) I will need as my truck doesn't have the dummy light. Is there anything I need to do about the current amp meter? Last edited by Kalums; 02-02-2025 at 02:15 PM. Reason: Update/ clarification |
#86 |
If you must have a CS130 alternator-and once again I don't consider them to be a good paperweight-make sure it has the improved cooling fan. There are wiring instructions out there for it. You will basically use the 2 wires from the old voltage regulator. You will want to bypass your ammeter gauge as it will not handle the higher current and wiring could get hot and do bad things. I think painless has a kit that has a CS alternator pigtail and some wire to go to the battery. I would use an 8ga wire from the back of the alternator to the battery in addition to the existing wire (and get rid of the ammeter and either add a voltmeter or change to an "idiot light" for charge). Any additional high-amperage accessories like electric fans or big stereo should pull power from the battery and the new wire not the existing truck wiring. That way you don't overtax the truck wiring.
#87 | |
#88 |
No real progress today. What are the pros and cons of a Fel-pro 1205 S-3 vs the standard 90314-2 intake gasket? I guess I mean what are the issues/pros of blocking off the exhaust crossover? I live in Phoenix... I doubt I need "added heat" to warm up my fuel/carb... *shrugs* but idk... You guys tell me. Also do I need to plumb water lines from the rear of the cylinder head back up front? My intake doesn't have a rear coolant crossover but it does have a place to drill & tap for the circulation lines to back up front...
#89 |
Well... It begins... I got most of the periferals/accessories off. Lossened the engine mounts. More tomorrow, hopefully.
#90 |
My computer would not let me in the last few days, thought the site was compromised. Anyway, what setup did you get? I am assuming earlier 5.7 with the CS130 alternator and an R4 A/C compressor? I didn't even think about that the late Blazers have a different alternator and the pad mount A/C compressor.
#91 | |
On a side note, do you know if our power steering pumps will mount on this bracket? I know I need to swap the pulley, but mine is not leaking in anyway... And appears to have the needed bolt holes on the front of pump...I honestly wasn't keen on trying decipher correct hose/ends just yet. |
#92 |
Which intake manifold gasket? All Fel-pro #s 1205 s-3, 1206, 1255, 1256, 1266? Or "standard" MS93317?
#93 |
Ok guys I know I haven't posted in a few days... But what is this thing that was included with my new heater core? Literaly just says "normal closed"
#94 |
That's a heater valve. It's normally closed until you apply vacuum to it.
I think that is only for an A/C truck though? Hope you got the correct heater core.
#95 |
#96 |
Can i reuse my temp sensor or do I need to get a new one? Is the hole the same size? ACDelco G1852 is the part # my local GM dealer suggested.
#97 | |
![]() Join Date: Feb 2002
If your old Water Temperature Sensor fits the new engine, use it. If the old set up worked OK then it should work, providing it fits. If it doesn't fit, and you can't find adaptors, you might need the new one. When I swapped a Mr Goodwrench engine in my '71 Jimmy -- 26 years ago -- the old sender didn't fit the new hole. The new sensor didn't read right. Something about getting some resistors from Radio Shack. Tried that, never worked. I finally got a manual AutoMeter mechanical Water Gauge. Now I know exactly how hot my engine is running. Much better detail.
#98 | |
#99 | |
I have the OEM Oil Pressure Gauge, that's inside the dash and is served by copper/brass tubing. Works just like yours. No sender. Gauge head reads pressure. Someday, I intend on mounting Auto Meter gauges inside the Dash in the stock locations. I will replace the Ammeter with a digital voltage reader, mount the Water Temp in its usual positiion, affix a 3.5'' SunMeter Tach in the above position, an AutoMeter Vacuum gauge right of the column, and an AutoMeter Oil Pressure Gauge on the far right. I'm also thinking of moving the Wipers switch left, to above the Lights knob. I already have a Manual Choke on the Right. And adding a '67/'68 3-Spoke wheel. [My other truck's a '68 C/10 Stepside and uniformity of controls is my goal.] Note, the AutoMeter Water Temperature Gauge is a one-piece sealed assembly. Prior to mounting the gauge face, the sender capsule and hard line are snaked forward thru the dash, thru the firewall and to the spot in the head it mounts to. Excess hard line is coiled in a safe place, near the Brake Booster or Power Steering Pump. Unlike the Oil and Vacuum lines it's not two or three components -- gauge/line/sender.
#100 | |
| Bookmarks |
