12-30-2011, 01:29 PM | #1076 |
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
BTW, I showed the POR15 can so you can see my method for opening and resealing with two screws. I never remove the lid. Works awesome.
12-30-2011, 02:36 PM | #1077 |
just opening the can is like disarming a bomb...VERY VERY careful!!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
12-30-2011, 06:02 PM | #1078 |
Seems like a good idea, the only question I have is POR recommends stirring before every use, what's your innovative solution for that (asking because I know you have one )?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
12-30-2011, 09:37 PM | #1079 |
Shake it up in the can and stir the portion you put in another container.
12-30-2011, 10:05 PM | #1080 |
Still Learning
I've never used any POR products. I understand it's Paint Over Rust right? So, I'm wondering how well it adheres to bare metal? I know you said you scuffed it good. How durable is this stuff? I have been using rusteoleum products on my frame and it scratches pretty easy. I think it's acrylic enamel?
I assume that stuff is pretty thin too if you can pore it out of a screw hole? Keep up the pictures and great information. |
01-05-2012, 02:46 PM | #1081 |
My old boss (who sells POR15 on the side....he's into Studebakers) told me the same method. Seems to work good.
01-15-2012, 07:05 PM | #1082 |
Started bending up brake lines (no pics just yet). Came to the conclusion that a decent double flare tool will be more than justified for this project, not to mention future use. So I have the Rigid 345-DL kit on the way.
With the brake system on the mind, I ordered an adjustable prop valve which will be mounted for cockpit accessibility. Also ordered the POR-15 fuel tank seal kit. Since I did weld on it I figured better now than later after being stranded by a clogged fuel filter... |
01-17-2012, 10:53 AM | #1083 | |
I think that is the most logical place for a machine like this!!!
01-17-2012, 06:27 PM | #1084 |
Hot Rods For Life
I can't believe I am just now finding this build thread. This is one of the most impressive build I have seen. I have always thought the S2000 motor would be a good donor for any rear wheel small car. I commend you on your work. Wow.
01-19-2012, 04:33 AM | #1085 | ||
Posted via Mobile Device |
01-19-2012, 05:23 AM | #1086 |
Second Chance Program
Very ambitious project! More than im willing to tackle!
01-19-2012, 09:07 AM | #1087 |
So Many Ideas, So Little Money
isn't a rendering supposed to be for BEFORE you build it?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
01-21-2012, 02:16 AM | #1088 |
01-30-2012, 01:22 AM | #1089 |
We left off with the rear painted. So lets do a before and after:
Before- After- Moved on to the brake lines: Starting with the rear- Picked up a double flare tool for the project- MC's on down (camera is goin south)- Front line to T- First (and only) T in front circuit ...and across to the pass-side (avoiding exhaust)- DS Front- |
01-30-2012, 09:41 AM | #1090 |
Very clean. Where did you get the coil the goes over the brake lines like the factory use?
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
01-30-2012, 12:59 PM | #1091 |
Thanks. I stole them from some lines on a C5 Vette chassis. But I know inline tube carries them.
01-30-2012, 01:35 PM | #1092 |
thanks for the tip , they have stainless brakelines too
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
01-30-2012, 01:39 PM | #1093 |
Yes they do. I'd probably use it on a street rod type build. The poly-armor lines are sweet though. So easy to work with.
01-30-2012, 02:26 PM | #1094 |
Still Learning
Rear Diff and brake lines look great! You are the man.
01-30-2012, 07:12 PM | #1095 |
You are way more ambitious than I ever will be
01-30-2012, 11:54 PM | #1096 |
damn FF, how do you bend your lines so clean? what benders are you using? Also no combination valve? or is that the adjustable one you ordered? i thought they had individual lines for the left and right front wheels? i'm looking for some fittings to do a 90 on my nova. any ideas where i could get some?
now you have me thinking i want to POR15 my nova's rearend. i was just going to hit it with rustoleum but now i'm sold! POR15 it is...
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 Hawaii Rod and Custom Show 4/18 |
01-31-2012, 02:16 AM | #1097 | |
If I had known it would take 3yrs I'm not sure I would have been so ambitious Quote:
I have a no name 180* bender. But for some of the bends I just did it by hand as shown in the vid. I have an adjustable prop valve installed (will post pics). It's mounted for on-the-fly accessibility. Looking for something like this? http://www.discounthydraulichose.com...bow_p/3502.htm The S2000 MC has front and rear circuits that are split out to left and right by the ABS unit that I have deleted. |
01-31-2012, 02:33 AM | #1098 |
ahh that AGS i can get from checker..... i've actually used it and it bends nicely. i guess that's what i'll be using on my nova when i do the front brakes.
thanks for the link for the fittings! i guess i'll be looking for some that i can clip in now.
01-31-2012, 03:17 AM | #1099 |
Yep, I jump around a bit... I had the front Xmember in for checking brake line routing:
So while it was in, there was something that needed to be completed ...the shortening the front sway bar brackets. So in maintaining the theme of modifying (nearly) every part of the this car: We'll start with the original bracket shot- New bolt holes raised 1" Remove blind-nuts: Clean-up: Welded the nuts back on 1" higher and... Why I felt the need to raise the bar (see right orig vs. left raised) Side shot of modded bracket ("gusset" also clearanced) Yes the mount plate is still just tacked in... x2 (those scraps actually came from what is the top in this pic) |
01-31-2012, 03:26 AM | #1100 |
Clutch line and rear brakes to prop valve (clutch will have a bracket for the flex line)
Zoom on prop valve (inside shot disappeared in the shuffle... it's next to the ebrake) |
