10-31-2009, 11:38 AM | #1076 | |
Re: Daverods project 66
I've done the crossmember notch but it doesn't give you much for the work. To combine a c.member notch + frame 'Z' is just extra work. Skip the c.member notch & raise the rails up more when doing the 'Z' (I realize the OP has already done the c.member notch).
10-31-2009, 11:45 AM | #1077 | |
Daring to be Different
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
10-31-2009, 12:11 PM | #1078 |
I figured as much but wanted to insert the 'term' w/the description for those not familiar.
10-31-2009, 12:13 PM | #1079 |
You described it better
10-31-2009, 12:22 PM | #1080 |
Sunburst C10!!!
see dave i told you that you need to z the frame
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 10-31-2009 at 12:24 PM. |
10-31-2009, 12:24 PM | #1081 |
the Z ing makes for a lot of sheetmetal adaptations , another way would be to channel or floor the body over the frame wish keeps the frame stock but limits headroom in the cab.
channeling is just wat i says two sheetmetal channels made in the floor to drop the whole lot over the frame it does leave a big speedbump in the middle of the floor in the cab and the stock carpet whont fit no more the space to the roof stays the same the biggest challenge is to rethink the sheetmetal in front of the cab (innerfenders radiatorsupport and all that lot need to be shortened and mounted lower ) and making sure the stuff hanging from the bulkhead whont hit the engine and the top of the engine whont hit the hood . flooring is basicly cutting the floor and most of the bulkhead and some of the rearwall of the cab trimming it the amount you want to go lower and reweld it in , this leaves the floor stock looking but with a step in the doorframe and less room inside the cab floor to roof they do this a lot when they want to drag the body to bottom of the doors (they remove all sheetmetal below it ) you can still fit the stock carpet back in after some trimming , the rest of the sheetmetal lowering stays the same as with channeling the clearance problems too the bed can be either floored too or lowered by shortening the mounts and cutting holes above the pumpkin and rearframe above the axle in my eyes flooring looks the best but is the most work and the porterbuild dropmember is the easest safing a LOT of work to make the rest fit on duallyscene.com they have a lot of pictures of these adaptations though they mostly use 77 and up trucks , there laying frame with 22 inch truckrims under there pickups sorry stroddler missed you request there for a moment heres the link to the dropmember http://www.porterbuiltstreetrods.com hes building a new website tough
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 10-31-2009 at 12:58 PM. |
10-31-2009, 02:31 PM | #1082 |
There is so many ways to get this done. You just have to pick the one that you can do, or can afford.
Thanks for the link watahyahknow
10-31-2009, 03:16 PM | #1083 |
SSN 706
Life is so simple. All I need is more money. Couple grand. I do like the drop member. Wonder what I have to do to keep my arms. Don't really want to buy arms and a member.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 10-31-2009 at 05:34 PM. |
10-31-2009, 04:34 PM | #1084 |
You can re-use the stock arms w/the original DM. The later versions can use OE arms but they'll need to be from a 73-87.
10-31-2009, 05:42 PM | #1085 |
SSN 706
The arms I have now are off a 71. But I'm going to change the control arms and ball joints to the 73 type. Do they still sale the orginal DM?
10-31-2009, 05:42 PM | #1086 |
SSN 706
10-31-2009, 05:46 PM | #1087 |
You could check w/Nathan on the V1 DM. I know they pop up 'used' from time to time as some have upgraded to his newer versions. If you're upgrading to 73-up arms/BJ's, the newer version (V3) will work for you.
10-31-2009, 06:44 PM | #1088 |
the cheapest way offcourse would be living with the fact it isnt laying frame ............or mount smaller rims
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
11-01-2009, 01:26 PM | #1089 |
Sunburst C10!!!
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 11-01-2009 at 01:27 PM. |
11-01-2009, 07:15 PM | #1090 |
SSN 706
And I could use that money saved by not lying frame to buy some cool wheels and tires. bDo I really care if my frame is a couple inches high:? I'll lay frame in the back. The outside diameter of thew tires I have now is about 30" My spindle is at 12" so my frame will be about 3" in the air. If I use a tire like 265 35z r20 they are only 27" in diameter.
11-01-2009, 09:59 PM | #1091 |
Member of the longbed union.
you know, even if you dont lay frame, I will be. haha
You could always body drop it to look like it is.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
11-02-2009, 02:52 PM | #1092 |
11-02-2009, 07:51 PM | #1093 | |
SSN 706
11-04-2009, 10:11 AM | #1094 |
SSN 706
[img]http://www.*****************/files/P-47-63-87-Raised-Crossmember-Kit.jpg[/img] They make it to easy. Does take all the headache away. Rack and pinion and your done. Then I could be like Ruff.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 11-04-2009 at 10:16 AM. |
11-04-2009, 10:27 AM | #1095 |
whose kit is that?
1961 Apache SWB/SBW for now... Built 327 You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40. |
11-04-2009, 11:16 AM | #1096 |
SSN 706
It was on http://www.*****************/front_page$ 1199. I think Porterbuilt makes one too. I can't get to his site though.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 11-04-2009 at 11:28 AM. |
11-04-2009, 12:47 PM | #1097 |
it actually looks exactly like the porterbuild one
11-04-2009, 09:18 PM | #1098 |
SSN 706
Took my fenders off my 64, ordered some bottom patches. Put my body on my frame. Sat in it went up and down.laid some frame.
11-04-2009, 09:19 PM | #1099 |
SSN 706
Even my sled lays frame
11-04-2009, 10:17 PM | #1100 |
That kit is based off of Nates kit, but it has a bunch of stuff done diffrent and better then Nates. Mostly less welded parts and better motor mounts.
You still couldn't be like me Dave I have the P-51 kit and that's the P-47
