Old 11-11-2009, 01:28 PM   #101
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Project... Rusty but Trusty
Yep , Napa gold oil filter . In the walmart parking lot picks . I see the hood and tops of the doors have some surface rust . There is a thread in the project section were a guy had the same situation and used 4 to 1 hot water and CLR mixed to remove the rust then waxed it . Here they are : charity case . Kept the patina without the rust .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-11-2009, 01:32 PM   #102
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Hey now, I like my rusty truck
You like all that shiny stuff that costs money
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-11-2009, 01:35 PM   #103
hotrod 80
mini truck racer
hotrod 80's Avatar
I guess living by the bay has me worried . Surface rust gets out of hand quick here .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-11-2009, 01:39 PM   #104
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Buddy, this truck is already out of hand
If there was paint under the rust it might look cool, but Im sure there's not
Sinister
Killer
Old 04-13-2010, 11:43 PM   #105
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Back working on RBT. Not a lot of progress, but some.
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 04-13-2010, 11:50 PM   #106
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sinister
Killer
Old 04-14-2010, 12:43 AM   #107
67_C-30
I have a radical idea!
67_C-30's Avatar
WHA??? You can't post a single pic a turbocharged six banger looking ready to run and just walk away! What da he77 is a matta witchu!?!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-14-2010, 09:52 AM   #108
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Just thought I'd see if there was any interest in it?
It's getting close but is sitting for a few more days.
Every once and a while I need to go work and make a little money.
Anyway. This is a part time project Spray-Bomb and I have been working over the course of several months. In between working and other projects.
Stock 250/six (thanks to HotRod80), a turbo manifold we cut and modified ourselves,
I am modding an old 400cfm AFB for blow thru and using a clifford alum intake.
Not sure the turbo is going to be sized even close to properly, but have a few others to mix and match to get closer if needed.
This is just for fun and to learn a bit.
If you look on the previous page, there are some pics from last year showing it with a intercooler. For right now I am going no intercooler until I get it dialed in with low boost.
So far I have less than three hundred in turbocharging it.
Lee
Old 04-14-2010, 05:22 PM   #109
67_C-30
67_C-30's Avatar
Lee
Yeah, I saw the other pics, but it looked a ways from being funuctional. I thought you had got it going. I can't to hear it. I have thought about putting a 6.5 turbo on my shop truck, so it works out well for you I may do that too!
My trucks
Old 04-14-2010, 06:07 PM   #110
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Another shot
We don't have a LOT left.
Hook up some gauges, including a boost gauge. Spray didn't have a temp gauge and that's part of the reason the other engine (integrated head) cratered.
Finish the chain brace
Do the mods to the AFB and hook up fuel line and throttle cable
Fabricate PCV system
Glue up, sand and paint the intake piping
Hook up the boost referenced fuel pump
Run the oil supply line to the turbo (the drain is run)
Still have to figure out what I'm going to do to control the internal wastegate. (this is the biggie). The stock won't work with the way it is clocked
Get an air filter for it (to start it will just get a cone type directly on the turbo)
Finish the clutch linkage and adjust the clutch (had to have clearance for the exhaust)
Finish the exhaust (only has 2.5" downpipe currently)
Bleed the brakes (had to re-route the six brake lines, V-8 would have worked)
maybe a few other small items
Re-install front sheet metal, radiator and battery, etc
Then a few maintenance items.......... and go for a test drive!
A good day or so would get most of it. But is back om the "wait" list right now.
DO you already have the 6.5 turbo? If so, what number? Is the shop truck a 250?
I "think" mine will work, just not as well as it could. I think it is a bit small on the compressor side to flow well at higher rpms. I am NO turbo expert. But learning.
Time will tell.
Lee
Old 06-24-2010, 01:24 PM   #111
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Very interested in this turbo build. I'm not familiar with blow through carbs, but it sounds fairly simple as simple as a turbo project is....
Lovin the RBT theme through and through!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 06-24-2010, 01:57 PM   #112
JimmyFloyd
yeah, I am interested in this as well. i would love to do a turbo six in my blazer since it originally came with a 6 cyl. Where'd you get the manifold and do you have links to the blow-thru carb you mention?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 06-24-2010, 03:06 PM   #113
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
We made the exhaust manifold from an original 250 manifold and grafted on the turbo portion of an GM exhaust from a 6.5 turbo diesel. Not sure how long it will last, but braced it well. If it doesn't last I will build one from a flange and weld ells.
There was some exhaust manifold being sold on ebay a few years back but don't know now.
TLowe on the inliners international bulletin board (http://inliners.org/) was importing some a while back also. They looked quite nice but were out of my price range at 400 or so. You might contact him.
The blow thru carb mods were from the theturboforums. http://theturboforums.com/ They have info on both holleys and carter/edelbrocks.
I need to finish building my O2 sensor (JAW), and do a few final plumbing details and then I could fire it up and start tuning.
Been pretty busy for a unemployed person. lol
Mine is just an effort to learn more about turbos etc. Hope it puts out 250 or so hp. There are a few out there with more than 500 from a 250-292. That would be a blast.
Leo Santucci has a good book on modding the 250 - 292 and there are lots of books on turbos. Most recommend Corky Bell's.
Lee
Old 06-24-2010, 03:09 PM   #114
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Thanks for the nice words. Its fun to drive a old beater pickup. You don't have to worry about scratches etc.
Turbos have interested me for several years, finally decided to try my hand at one DIY. I am sure it won't be as good as a professional setup, but it's fun to me.
Hope to get back on it toward the end of summer.
Lee
Old 06-24-2010, 09:01 PM   #115
bigguy69
dazed and confused
bigguy69's Avatar
i would love to see a video of it when you get it goin!!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-24-2010, 11:55 PM   #116
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
I think I could handle that. Hopefully it is a video of a success and not a big oily spot. Only time will tell.
Lee
Old 06-25-2010, 08:33 AM   #117
propanemudtruck
Exactly! I would rather drive the old 82 Chevy that I had than my 01 Powerstroke!
Lookin forward to the videos of the turbo mod running good! Reading this build, I'm sure you two will be fine getting this thing tuned and hauling [junk] down the road!
-Kevin
Old 12-11-2010, 07:37 PM   #118
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Bump! Updates?!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-11-2010, 09:19 PM   #119
67chevy1series
67chevy1series's Avatar
hey got an i dea for your hood poor coca cola on it and get some tin foil and scrub the sh$^ out of it tell you see results do this too the whole hood then wash it off it helps with the rust
67chevy1series is offline   Reply With Quote
Old 12-11-2010, 10:43 PM   #120
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Originally Posted by thirdstreettito View Post
Bump! Updates?!
Well it's not dead. The shop has been full of SprayBomb's projects, but he started cleaning up today.
I am going with a SLC DIY wideband from 14.7 ( http://www.14point7.com/SLC-DIY.php ) and I've assembled and tested it. I need to weld the bung in the downpipe. I'm getting a temperature probe off ebay and will weld a bung in for it to read EGT. And I will be able to datalog!!!!!!!
Have a few other things on my santa list.
Anyway I hope to get it pushed back in the shop soon and get it going.
The biggest short term project I have is building a bracket and mounting the wastegate actuator. When I re-clocked the turbo the old one no longer fits....... so I ordered a new one and need to get it hooked up.
Lots of little stuff to do
trim the inner fender
remount the front sheet metal
bleed the brakes
Get a longer speedo cable
Get the factory gauges working
Get the wipers working
Fab fuel line from pump to carb (mega squirt on hold right now)
Lots of little things to fix from it sitting so long.
And that's just to get it drivable, not good, just good enough
And lots of tuning to keep from detonating the engine.
I really would like to get it going soon.
Old 12-11-2010, 10:44 PM   #121
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
That sounds like a good idea, but getting the outside nice is a bit in the future. Need to get it driving first.
Old 12-11-2010, 10:47 PM   #122
67chevy1series
ohh you are going to sand it down and paint it , i thought you were going to leave it rat rod
Old 12-11-2010, 10:57 PM   #123
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
Don't know what I am doing on the exterior.
I really like patina / ratrod trucks, but i think the sheetmetal needs to be straight.
My front fenders and drivers door need some work on them......
Time will tell.
Old 02-06-2011, 12:26 PM   #124
propanemudtruck
Any updates on this again? I really think this thing's gonna sing when it's running!
-Kevin
Old 02-06-2011, 05:44 PM   #125
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
I really thought I would be back working on this by now.
Santa brought me a few things for RBT, but it still sits outside waiting patiently.
Weather has really been off (cold, wet, snowy, rainy, etc) lately and seems it will continue for a while. I do hope to get back on it soon. Maybe by the the beginning of next month.
I would really like to hear it run SOON!
