Old 01-26-2011, 06:54 AM   #101
Ipaintgrt
Re: New guy with truck
If you do some digging around here on this forum you will be able to find a few how too's on the front subframe. There are allot of choices. If it where me and I were to do it over again I would contact Porterbuilt customs and get a crossmember for a C-4 corvette. They handle great and come with big brakes and look really cool. The A arms and other components can be polished out and are really pretty inexpensive by the time you buy tubular A arms and fancy disk brakes, and sway bars etc. good luck Scott
Ipaintgrt is offline   Reply With Quote
Old 01-26-2011, 04:40 PM   #102
56ClassicTruck
Thanks oldschool ..........
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 01-26-2011, 04:50 PM   #103
56ClassicTruck
Hey thanks for your advice Iprintgrt,yes been digging my sub was ok just to high and I didn't want to use drop spindle. Wish I could use c_4 corvette stuff, but I am on a budget so I have to work with what I can aford, the life of a pour man, lol.
1996 Dodge 3500 4x4
Old 01-26-2011, 06:32 PM   #104
Ipaintgrt
When I got my truck the sub was on wrong and it sat like a 4wd. If you get the angle of the sub, measured at the a arms at the correct angle it should put you pretty low. Then you could use air bags to lower it more. The lower ball joint needs to be leading the top one I believe. When I did mine, I happened to own a camaro, so I just used a magnetic degree wheel and measured the angle from my camaro, then when I welded my sub on I made sure it was the same. My truck sits pretty low. Just what I did. S
Old 01-26-2011, 11:22 PM   #105
56ClassicTruck
Hey scott, ya my truck look like 4x4 lol .... My angel are good I set them at 8°, would like airbag what do they cost?
I almost have 1994 roadmaster sub welded so far so good.
1996 Dodge 3500 4x4
Old 01-27-2011, 01:50 PM   #106
Ipaintgrt
Can't remember for sure, but I think they were like $65 a piece? I got them off Ebay. You can also check Suicide Doors. Not sure if I told you already but I have a 96 Caprice w/Lt1 that I'm going to use for my build like yours, so I'm curious about how you get yours running. Harness and stuff. S
Old 01-27-2011, 02:12 PM   #107
56ClassicTruck
Ya that 1996 caprice is just like like my 94brm roadmaster, do you have trend on your project?
1996 Dodge 3500 4x4
Old 01-27-2011, 03:28 PM   #108
hotrodrookie
hotrodrookie's Avatar
What kind of load can your rear suspension handle? Im only asking because those coilovers look like helper shocks I've seen on pick up trucks(not load bearing) and the air schocks aren't load bearing either. Maybe I'm wrong, just wondering what it is.
hotrodrookie is offline   Reply With Quote
Old 01-27-2011, 09:03 PM   #109
56ClassicTruck
hi hotrod, well the suspension handle the load of the Buick roadmaster? that's a big car, and it was a nice smooth ride..
1996 Dodge 3500 4x4
Old 01-28-2011, 12:44 AM   #110
56ClassicTruck
just some pic,s roadmaster fire wall not finish......
1996 Dodge 3500 4x4
Old 01-28-2011, 01:07 AM   #111
56ClassicTruck
more pic,s see how high front is.
1996 Dodge 3500 4x4
Old 01-29-2011, 12:18 PM   #112
56ClassicTruck
new 56 short bed frame.
1996 Dodge 3500 4x4
Old 01-29-2011, 12:28 PM   #113
56ClassicTruck
94 roadmaster sub droping it 3"
1996 Dodge 3500 4x4
Old 01-29-2011, 12:41 PM   #114
56ClassicTruck
boring stuff on how i budded it together keep same measurement as camaro. 28" 3/8 from cab mounts to shock hole, at 8 degree
1996 Dodge 3500 4x4
Old 01-29-2011, 12:49 PM   #115
56ClassicTruck
more pic,s
1996 Dodge 3500 4x4
Old 01-29-2011, 01:22 PM   #116
56ClassicTruck
sorry i am posting to pic,s at a time but out here in hicksville Washington it take me 15 min to get 2 pic,s on sucks!!!!!!
1996 Dodge 3500 4x4
Old 01-29-2011, 01:30 PM   #117
56ClassicTruck
more
1996 Dodge 3500 4x4
Old 01-30-2011, 11:56 PM   #118
56ClassicTruck
sorry the pic,s are not that i toke them with my phone.
1996 Dodge 3500 4x4
Old 02-03-2011, 11:34 AM   #119
Ipaintgrt
Wow, what made you go with a different frame and start over? Mysubframe is a little different. Its from a 71 camaro. It looks like you have been doing alot of work on this. If nothing else you have learned alot. If the measurements and angle of the a arms are good then as long as the welds are good, it should be fine. Box it to make it look pretty and add strength, and it should be fine. Hope it sits how you want. S
Old 02-04-2011, 12:35 AM   #120
56ClassicTruck
[QUOTE=Ipaintgrt;4459354]Wow, what made you go with a different frame and start over? Mysubframe is a little different. Its from a 71 camaro. It looks like you have been doing alot of work on this. If nothing else you have learned alot. If the measurements and angle of the a arms are good then as long as the welds are good, it should be fine. Box it to make it look pretty and add strength, and it should be fine. Hope it sits how you want. S[/QUOT
O sorry I thought I posted why. 1 to lower front end I wanted to use roadmasters spindle with the ABS brakes.... 2 now my lt1 will sit right in with no issues with AC compressor.. And yes it will be all boxed in for sure......and yes I been learning alot!! Lol , , mybe to much.............
1996 Dodge 3500 4x4
Old 02-08-2012, 08:47 PM   #121
56ClassicTruck
Well finally got back to my truck after 9, month off..... I got my subframe together and rearend and test fit some sheet metal, and I am happier with the stance ..... my lt1 fits nice to. Can't wait to finish ....
trying to post picture but can't?
1996 Dodge 3500 4x4
Old 01-26-2014, 03:55 PM   #122
56ClassicTruck
Well since my last post over a year ago I have not been able to work on my truck do to my wife health. Now I am going to start , it been so long am overdeveloped!!!!! Were to a start??? :-(....... hard to get motivated, but here I go.....
1996 Dodge 3500 4x4
