08-01-2011, 07:55 PM | #101 |
Certified Car Nut
Re: 57 Step Side
Man it will not see color for a while. I'm still working on the minor details.lol Things like panel alignment.
08-06-2011, 10:29 PM | #102 |
Re: 57 Step Side
Put the the dynamat in today,the foil is as sharp as a razor if you run your finger over it.Use a glove if you plan to use your hand instead of the roller!!
08-07-2011, 08:52 AM | #103 |
A320 Pilot/USAF Retired
Re: 57 Step Side
It's definetly worth the effort to put it down. It will really make a difference in stopping the heat and making the cab sound that much more solid. Did you put any in the doors? After putting it in mine it made a dramatic difference in how solid the doors sound when you close them.
It looks like you did a door latch mod without giving up the info!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-07-2011, 09:50 AM | #104 | |
Re: 57 Step Side
www.triquemfg.com |
08-11-2011, 01:23 AM | #105 | |
Re: 57 Step Side
How difficult was it to do the door latches? I just went to the Trique site and they look awesome. My truck is painted and I don't want to mar up the paint ... is it possible? I have to slam the doors to get them to close. Will these latches pull the doors close even with brand new rubbers that aren't relaxed yet? Thanks Byron |
08-11-2011, 07:06 PM | #106 | |
Re: 57 Step Side
08-12-2011, 08:58 PM | #107 |
Re: 57 Step Side
Shot of the door
08-13-2011, 03:18 AM | #108 |
Re: 57 Step Side
This is one awsome Build. My next project after the 67 Short Fleet is a 56 Bigwindow Short Step. This is really Motivating me to get the 67 done so I can get to work on my 56. Look forward to seeing some more pics.
JRBECK64 |
08-13-2011, 06:57 AM | #109 |
Re: 57 Step Side
Thanks, i'll be looking for the photos on the big window.Big windows have a kool look to them.
08-14-2011, 04:32 PM | #110 |
Re: 57 Step Side
Fab up a shroud to support the fan instead of using the the fins to support the fan.It was hard finding a fan to fit is the space i had left between the engine and fan.
08-14-2011, 04:42 PM | #111 |
56 - autocross
Re: 57 Step Side
that sure is pretty!
08-14-2011, 06:10 PM | #112 |
Re: 57 Step Side
Looks real nice and clean.
Kim |
08-14-2011, 06:29 PM | #113 |
Re: 57 Step Side
There is no substitution to detail, and you have not missed it one bit . This is a great build.
My Build Thread 51 chevy http://67-72chevytrucks.com/vboard/s...d.php?t=437496 48,49,50 Chevy trucks. 41 Olds |
08-14-2011, 07:12 PM | #114 |
Re: 57 Step Side
Thanks to all,been trying to do it right but i have to say i did pick up alot of detail and information here on this board.It also helps when others share information and photos for others to learn from.
08-16-2011, 08:36 PM | #115 |
Re: 57 Step Side
Had to fab up a bracket for the neutral safety switch that i have to mount to the cable bracket on the steering wheel.No room on the trans to mount it so the column was the only spot left.
08-17-2011, 06:45 PM | #116 |
Re: 57 Step Side
It fits and seams to work,won't know until it gets wired but the switch is depressed when the truck is in park.
08-17-2011, 06:52 PM | #117 |
56 - autocross
Re: 57 Step Side
That is a nice fab piece!
09-20-2011, 10:01 PM | #118 |
Re: 57 Step Side
Almost done with the painless wiring and gauges,working under the dash is not so painless but a pain in the a**.Vintage Air lines are done especially the ones in the cab,another story about 20 lbs of s**t in a 5 lb bag.Everything is very tight under the dash.
09-21-2011, 12:31 AM | #119 |
Re: 57 Step Side
Your dash looks great.
Kim |
09-21-2011, 12:54 AM | #120 |
Re: 57 Step Side
It's looking VERY good!
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
09-21-2011, 01:13 AM | #121 |
Certified Car Nut
Re: 57 Step Side
Its looking great man.
09-21-2011, 03:24 AM | #122 |
Re: 57 Step Side
WOW !!! She's a beauty, keep the pictures coming.
I'm not tail-gating, I'm drafting. http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
09-21-2011, 06:45 PM | #123 |
Re: 57 Step Side
Thanks to all,its finally close to throwing a battery in it and turning the key to see if it works,LOL.My first wiring job so i hope the sparks and flames don't get that high when i turn the key.
09-21-2011, 07:42 PM | #124 |
56 - autocross
Re: 57 Step Side
That's pretty! Any pictures of the side view to see the stance?
09-21-2011, 08:31 PM | #125 |
Re: 57 Step Side
A friend gave me a tip many years ago about putting power to a new wiring job. I used it when I put the Ron Francis panel in mine. What he told me was not to use the full power of the battery the first time, but to use a battery charger on the lowest AMP setting. That way you still get 12 volts without the full amperage of a bttery to test it with. It worked for me!
