#101 |
Re: Another 4X4 Front Sway Bar
With a 4" lift, you will need shims between the cross member and bushing retainers. I posted pics in the 4wd forum years ago. Mine had the 4" lift as well.
#102 |
Any pics or a link to pics? Ant spacers laying around? I know that first one had some that you said you removed.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#103 |
![]() Join Date: May 2003
jjzepplin
If you go to my build thread: http://67-72chevytrucks.com/vboard/s...259859&page=12 pages 12 & 13 you can see what I did. I had the same frame brace for the steering box and decided to keep my original cross member and modify the bushing brackets instead of changing cross members. I wanted to try and keep a somewhat stock looking appearance. Maybe this will help you some ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#104 |
Great work sir. Though I don't think I have your fab skills. That was sort of my idea too but I was worried about cutting those ribs off where it bolts to the frame. I did use the 73 up front x-member as upon checking the side by side it is thicker. I have it in there but the bar brackets will not fit and must go outside the frame on the bottom like yours. I guess I could reverse the ribbing and make it go downward, just cut it all off and move it lower and weld back on. Love how you did the tabs that bolt to the member and will do that for sure. Thank You for the inspiration! Any one else?
#105 |
I know that taking the ribs off so it could be bolted under the frame will weaken it some, but I really didn't want to mess with the cross member or the steering box frame brace, besides this truck will be living an easy life from hear on !!!! "LOL"
Gary
#106 |
I am thinking spacers instead of removing the ribs and possibly spacers under the sway bar bushings as well. I have to get it lower anyway due to the lift. And if I ever break a mount I can just replace with one from the junk yard. I won't be wheeling mine much anymore. Those Rubicon days are over unless I make one hell of a long trip. Oh well maybe- It does have that crawl box still in there.
#107 |
Did some work on this yesterday. I thought the driver side was going to be the biggest hurdle but I think I figured that one out. The passenger however is giving me some grief. I don't like the angle on it versus the driver and to me looks odd. Not sure the force of the bar in a real world situation would hold up and if it lets go while I have a big trailer on the back it could prove to be catastrophic. I want to keep it level. I think I have it figured out. I should be able to keep most of the ribbing by placing 3/8" solid stock under the driver side but will have to fab a wedge sort of mount for the passenger. I am going to leave them a bit rearward to utilize the strength of the x-member rear mounting hole with a spacer and the bar should be putting most of the downward force on the mount itself. So kinda using both of you fellas ideas and modifying both to make it work. I am going to have a 20 ft trailer full of wood and heavy concrete at times on the back so I have to be as safe as I can. Not that either method looks unsafe- I am just trying to mimic as much as possible the stock install.
#108 |
I finally have it where I want it. I think the passenger mount will be ok. I took a bit from both of your installs. Thank you both. I will post some pics soon. Cannot find the camera.
#109 |
This is what I came up with. Haven't driven it yet. What do you think? I will powder coat the pieces when I am satisfied.
#110 |
Here's another one available
#111 |
I'll take it.
#112 |
![]() Join Date: Oct 2014
I'll be next in line if available
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) ![]() MAI Interior shop |
#113 |
This one sold to taylorbg...Thanks!
I will have another one available in a week. |
#114 |
#115 |
Need pp info and I'll Take it
#116 | |
I'm finally installing the front sway bar set up you sold me this past summer. Good winter project :-) I'm having issues with the U-bolt plates you sent me. Looks like the U bolt plates on my 72 Jimmy are for 2.75 axle tubes and the ones you sent me are for 3.0 dia axle tube. Do they make sway bar U-bolt plates for 2.75 tubes. If so do you have some and could I trade back for the 2.75 plates? Thanks, Eric |
#117 |
Got the sway bar on and 3/4 rear spring-wow! such little things make such a big difference.
#118 |
Yeah- I'm loving mine too. No rear but still a HUGE difference. Can't imagine having a new truck in 73 with one of these.
#119 | |
Well I finally was able to get back out in the barn and work on the sway bar install some more. The U-bolts I have around the 2.75" axle sprung out naturally to fit through the 3" U-bolt plates you sent me. ![]() Thanks, Eric My Jimmy is a 1972 and it haa a factory powersteering reinforcement plate. This pics shows how I had to cut some of that plate (Top and Bottom of Rail) for the cross member to fit. Showing the actual distance moved rearward from original mounting hole to new one 2.25" |
#120 |
Eric, That looks great! Thanks for the pictures.
#121 |
![]() Join Date: Oct 2013
Interested in one too, if you have one.
Les |
#122 |
Yes. I have a couple of them available. Sending pm...
#123 |
All about them K’s
![]() Join Date: Jun 2014
Ray, what are these coming off of? 73-87?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#124 |
Yes.
#125 |
![]() Join Date: Mar 2004
Got anymore? 64081
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
