Old 04-15-2018, 12:16 PM   #101
jocww
Re: Fatman, TCI, or Scotts IFS/Chassis on 49 AD
Originally Posted by dsraven View Post
lifting under the cab may bend/dostort the edge of the cab since that is a spot prone to rust. maybe better to lift under the top of the door with a spreader bar that is cab width. less chance the cab will roll that way too since youre picking it up from the top.
here is a pic of how I lifted mine with an engine hoise, you could easily adapt that theory to a gantry
You have a good point, my rear cab corners are a little rusty. didnt think the weight would be that much to distort. good looking out.
My build a 49 5 window ls1 4l60e on a TCI chassis
http://67-72chevytrucks.com/vboard/s...d.php?t=754926
My travel blog
The Wong Winding Road-Adventures of The Chinese Cowboy
https://thewongwindingroad.blogspot.com/
jocww is offline   Reply With Quote
Old 05-15-2018, 04:41 PM   #102
jocww
j will 18x9 with a +24 offset work in the rear 17x8 with +15work for thefront?
My travel blog
Old 05-16-2018, 06:37 PM   #103
slow4dr
slow4dr's Avatar
The rears are roughly 1.5" off on backspace, the fronts are closer but about .5" off. That would be some big spacers.
At least comparing them to the Revolver.
Front: 245/40--ZR 19-----8" wheel-----Wheel has 4¼ inch backspace
Rear: 245/45—ZR 20----8.5" wheel-----Wheel has 4 inch backspace
slow4dr is offline   Reply With Quote
Old 05-16-2018, 07:07 PM   #104
jocww
Glad I sill haven't picked them up then lol. When is that truck show you were talking about?
My travel blog
Old 05-21-2018, 01:36 PM   #105
slow4dr
slow4dr's Avatar
June 24th.....
Old 05-29-2018, 01:36 PM   #106
jocww
J, is the parking brake bar suppose to fit in the hole on the frame wing right where the front cab mount goes? Right now the body eating on that and is not able to sit flush on to the frame. Not sure if I need to remove it, or just res
Adjust it more.
My travel blog
Old 05-30-2018, 11:41 AM   #107
slow4dr
slow4dr's Avatar
Adjust it more.
If you're talking about the factory parking brake assembly, it won't clear. Give Evan a call, he said that Lokar makes a cable adapter.
Old 05-30-2018, 12:21 PM   #108
Scott2
For my ‘51 on a TCI chassis I used a generic AC Delco Park brake pedal with Wilwood cables at the rear and a custom Control Cables front cable to connect it all.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 05-30-2018, 01:03 PM   #109
jocww
Thanks you guys. Cut it out yesterday, also trimmed the inner fender wells now it sits flush. Just have to drill out the shackles to fit the enlarged bolts.
My travel blog
Old 06-04-2023, 03:04 PM   #110
shoveland
I'm currently building a 72 C10 frame up and finished bolting on Fatmans Fab IFS. My dilemma is finding frame stands for the motor mounts, as the originals I have interfere with the rack and pinion stem. I'm running an L6 292, which utilize factory SB mounting points. Other than custom building, are there any other bolt on options your aware of?
shoveland is offline   Reply With Quote
Old 06-04-2023, 03:45 PM   #111
daveshilling
daveshilling's Avatar
this thread is 5 years old.... start a new thread with your question, sir (after searching the vast amounts of info, of course)
daveshilling is offline   Reply With Quote
Old 06-04-2023, 03:52 PM   #112
shoveland
Cool Re: Fatman, TCI, or Scotts IFS/Chassis on 49 AD
I'm new to this site, pls step me thru your reply, Thx!
Old 06-04-2023, 11:01 PM   #113
mr48chev
mr48chev's Avatar
Old dead thread where sometimes your question gets lost in the mix as anytime you open a long dead thread the original question gets responded to and a lot of guys do not look at the last page and your queston is lost. Right now if I were in the market and had the money I would go with one from fatman that had the upright mounts for the upper A arms that use shims. Those will stay in alignment and the alignment tech will appreciate it to no end.
My ongoing truck projects:
Old 06-05-2023, 04:31 PM   #114
Rickysnickers
Rickysnickers's Avatar
Presumably you are building a complete '72 truck. Or are you building a '72 chassis to do a swap for your '47-'59 truck? If it's the first, then please post your question here, https://67-72chevytrucks.com/vboard/...splay.php?f=38
If it's the second, the swap, then please start a new thread here https://67-72chevytrucks.com/vboard/...splay.php?f=38
