Old 02-07-2026, 02:43 AM   #101
Luke87gt
Luke87gt's Avatar
Re: My Own Vice Grip Garage - Getting the 250 i6 Running Again
So my replacement vacuum advance arrived and I head into the garage to swap it in.
Easy job I thought. I get the old one out in about a minute, and mock up the new one. As I’m attempting to get the little screws into the side of the distributor housing, I drop the screw and never hear it hit the ground. UGH!
I probe around with a magnet for 10-15min and just can’t find it.
Off to the hardware store tomorrow. I think these are 8-32 3/8” length from what ChatGPT tells me, with a round head.
These are super short screws and I found it really awkward to get them started with my fingers as I held the vacuum advance up to the side of the distributor.
Fun times.
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 02-07-2026, 02:49 AM   #102
Luke87gt
Luke87gt's Avatar
double post delete
1969 C10 Shortbed
Old 02-07-2026, 04:46 AM   #103
Rust_never_sleeps
Rust_never_sleeps's Avatar
Next time, use that magnet to magnetize your screwdriver instead ;-)
I just swapped a vac can on the bench and it was fidgety enough. SBC dizzy location is ideal for this sort of thing ;-)
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 02-07-2026, 12:16 PM   #104
MikeB
MikeB's Avatar
I sometimes glue tiny screws to a screwdriver or even my finger tip to get them started. I also have a magnetic fingertip somewhere in the shop. It's like the finger tip of a glove, but with a magnet in it.
Seems like I'm always using this glue for something:
https://www.tractorsupply.com/tsc/pr...135-oz-2376234
Just one option of many on the Internet:
https://www.electriduct.com/lsdi-mag...ger-glove.html
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-07-2026, 12:22 PM   #105
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I've had one of these for over 50 years. Works great on slotted screws.
https://www.homedepot.com/pep/GEARWR...iABEgKDl_D_BwE
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 02-07-2026, 01:59 PM   #106
MikeB
MikeB's Avatar
https://www.homedepot.com/pep/GEARWR...282D/205593353
That's a nice tool!
Mike
Old 02-07-2026, 03:58 PM   #107
Rust_never_sleeps
The screws on the one I replaced were brass anyway ;-)
Had to retrieve them from the dizzy housing with the roach clip when I inevitably dropped them in there
Old 02-07-2026, 10:43 PM   #108
Luke87gt
Luke87gt's Avatar
We’ll ChatGPT lead me down the wrong path. 8-32 is too small.
I’m betting 10-32 is the correct size (1/4” to 3/8” length).
Canister to house: 10-32
Distributor hold down: 3/8-16
Back to the hardware store, arg!
1969 C10 Shortbed
Old 02-09-2026, 12:07 AM   #109
Luke87gt
Luke87gt's Avatar
10-32 1/4” length was correct.
New vacuum advance is on, thanks guys! Hex head screw made things a lot easier.
1969 C10 Shortbed
Old 02-15-2026, 06:58 PM   #110
Luke87gt
Luke87gt's Avatar
Today I got in the garage and got the 10W-30 out and the 20W-50 in.
I also added half a bottle of Lucas oil stabilizer.
One more step closer…
Now if I can figure out why my Saginaw 3-speed doesn’t have a drain plug, I’ll be able to change the transmission oil
1969 C10 Shortbed
Old 02-15-2026, 10:12 PM   #111
Getter-Done
Getter-Done's Avatar
If there wasn't a drain plug installed from the factory,
Removing the lowest bolt in the tail shaft works.
The only thing I don't like about that is it might create a leak.
(That is if you didn't have one to start with).
If you take this approach,
I would check and make sure the others are tight
before loosening the lower one.
Here's a video
The early bird gets the worm,
85 Chevy K-20
Old 02-15-2026, 10:28 PM   #112
Luke87gt
Luke87gt's Avatar
Here's a video
Trans Fluid Change 1976 Chevy C10 3 Speed - YouTube
Thank you, that’s helpful.
What about just using the hand pump method to pump fluid from the fill plug out of the transmission. I assume that running a nylon tube into the fill plug until it bottoms out, doesn’t run any risk of hurting anything ?
1969 C10 Shortbed
Old 02-15-2026, 11:06 PM   #113
Getter-Done
That will work also.
85 Chevy K-20
Old 02-15-2026, 11:13 PM   #114
RichardJ
Switching to thicker oil in the middle of winter. COOOL.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-15-2026, 11:32 PM   #115
Steeveedee
Steeveedee's Avatar
It doesn't hurt anything, but unless the fluid is good and warm, can leave metal at the bottom of the trans. Of course, too much metal and the trans is already toast. We're working on vehicles that the manufacturer had no expectation of having them last this long. I'm looking to buy another!
~Steven
Simi Valley, CA
Old 02-16-2026, 11:14 PM   #116
Luke87gt
Luke87gt's Avatar
Picked up an inner mesh grill for the ‘69.
Should be installing it next week.
https://www.summitracing.com/parts/OER-CX1401
1969 C10 Shortbed
Old 02-17-2026, 02:53 PM   #117
70STOVEBOLT
70STOVEBOLT's Avatar
I wonder why they even sell 20w50 oil if it’s not in the protection zone? That’s doesn’t make any sense…
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-17-2026, 03:35 PM   #118
MikeB
MikeB's Avatar
That chart's x axis is oil temperature, not ambient.
Instead of 20w50, I'd use 10w30 for less wear on startup. And then I see no reason at all for 50 weight, unless it's an old engine with very low oil pressure when warmed up. Even then I'd try 10w40 first.
Mike
Old 02-17-2026, 06:20 PM   #119
Rust_never_sleeps
I used 15W50 diesel as break-in oil in my son's XJ after rebuild and damn near burned out my drill priming the system ;-)
Old 02-17-2026, 06:39 PM   #120
MikeB
MikeB's Avatar
Driven Racing Oils suggests using straight 30 weight for break-in, except maybe for all-out racing engines. I've used their BR30 break-in oil a few times over the years, and then what they used to call Hot Rod oil in 10w30. No additives needed.
Mike
Old 02-17-2026, 07:30 PM   #121
'68OrangeSunshine
'68OrangeSunshine's Avatar
They used to specify Straight SAE 30 weight Non-Detergent oil for break in.
Old 02-26-2026, 12:08 AM   #122
Luke87gt
Luke87gt's Avatar
Replacing the old crusty inner grill (I was expecting the mesh would show up in black but it’s actually silver). Anyone know whether oem was black or silver (not the horizontal lining but the actual mesh)?
I thought I’d be done quickly but discovered that I had to place an order for missing hardware.
1969 C10 Shortbed
Old 02-26-2026, 12:57 PM   #123
MikeB
MikeB's Avatar
My was silver from the factory.
Very old photo with original inner, newer outer.
Mike
Old 02-26-2026, 06:18 PM   #124
Luke87gt
Luke87gt's Avatar
Thank you for confirming
I see that your horizontal trims looks silver too
1969 C10 Shortbed
Old 02-26-2026, 07:29 PM   #125
Rust_never_sleeps
many threads on the 69 vs 70 grills. f'rinstance:
https://www.67-72chevytrucks.com/vbo...d.php?t=803128
