11-01-2013, 08:05 AM | #1251 | |
GEARHEAD
Re: Junkyard Jimmy Super Low Buck Build Thread
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
11-01-2013, 07:41 PM | #1252 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-01-2013, 09:51 PM | #1253 |
GEARHEAD
Badpeanut, the reason I plumbed it this way was just cuz it looks better. There are pro's and cons either way. I appreciate you pointing out the difference though. If someone was gonna use mine as a guide they might not like that it's non-stock.
11-06-2013, 11:51 AM | #1254 |
GEARHEAD
Its a handful on the ice. Fun in the snow.
11-06-2013, 01:37 PM | #1255 |
Ha Ha! Wheeeee! 4x work good?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-06-2013, 01:52 PM | #1256 |
Countdown Survivor
YeeeeeeHaaaaaaaaa!!!!!!!!!!!
Might be coming up there soon for work, can't wait to see some snow this winter!
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
11-06-2013, 02:32 PM | #1257 |
GEARHEAD
I didn't shift it to 4 high until after the picture. It was sloppy wet snow and while I could make progress as a 1 wheel wonder it was easy to pull back on the shifter and pop it into a front/rear 2 wheel wonder. I desperately need to bleed the rear brakes.
You be sure to look me up. I'll PM you my contact info.
11-06-2013, 04:04 PM | #1258 |
I dont miss that white stuff at all.
11-07-2013, 12:23 AM | #1259 |
GEARHEAD
A couple of things that came up today were that I had a hell of a time starting it and the rear brakes were not grabbing at all (well I knew that last part a while ago, makes for ez brake stands).
I was having some trouble with it sputtering the past couple weeks and then double checked that the manual choke was actually opening and it wasn't. Popped it open and it's running like a champ again. Then today it would not start. It had been flooding with the choke issue so I checked again and sure enough, the cable is binding and keeping it shut too far. If I pull to hard shut it binds up and won't open, so I'm gonna try using some marks on the choke knob shank as a reference. The brake issue I thought was just that they needed bled again. But while looking things over I found the adjuster on the pass side had popped out of its slot. So I got that back into position, readjusted the pads on both sides, bled the lines again just because, and gave it another test drive... Test drive SAT. (Abbreviation for satisfactory) Took it out through a cornfield on the south edge of town. Drove it like I stole it.
11-07-2013, 01:14 AM | #1260 |
OMG its dirty!
11-07-2013, 10:40 AM | #1261 |
clean it quick, otherwise that crap wont come off.
11-07-2013, 01:29 PM | #1262 |
Wow, wish mine looked like that....theres a truck being used properly, nice pics
Wonder if i could paint faux dirt on my truck lol
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-07-2013, 02:04 PM | #1263 |
AAAAAAK! It's dirty! Right on! Glad the brakes were an easy fix!
11-07-2013, 07:00 PM | #1264 | ||
GEARHEAD
It had a sore spot so I rubbed some dirt in it.
Kinda like when I was making that face and it stayed that way? My plan was to let it dry and then flake off. Just the beginning of my protective layer so rocks flinging off the tires don't scrath my paint. Quote:
I'm getting to the point where I'll have to tear more stuff apart to "finish" it. Gotta pull the rear seat out and the wheel tubs to reseal those and get the bed liner done in the back. I need to do a little cutting and welding to get the roll bar mounted the way I want. Fix the driver side seat mounting (needs a spacer to lift it and more permanent bolting), still need to change lube in the diffs, install the electric fan, fix a few wiring glitches, hook up the stereo (low priority) replace some headlights, replace plug wires, fix gas tank fill hose, fuel gauge, and then decide which way I'm gonna go with bumpers and start working on those. I have doubts that I will start the suspension changes this winter. And honestly, I'm in no hurry to jump into that. I'm having way too much fun driving it. Can't stand having a laid up vehicle. I have a bunch of vacation days to use up before the end of the year. I have some house projects to tackle but I know there will be several garage days in there too. Thanks again for the support/encouragement I have received from my fellow gear heads.
11-16-2013, 12:34 AM | #1265 |
I miss this truck.
Awesome, isn't it great getting to drive it?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
12-04-2013, 09:58 PM | #1266 |
GEARHEAD
Yes it is.
Finally got back to work on this thing. I went out to the garage and saw that the front left tire was low. So I aired it up and took it for a test drive...
12-04-2013, 10:02 PM | #1267 |
GEARHEAD
Test drive was satisfactory.
That is all.
12-04-2013, 10:22 PM | #1268 |
I remember full throttle, cookie fun in my orange blazer. Fun times!!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
12-04-2013, 11:09 PM | #1269 |
Vintage 4x4s
Nice pics! Hows the heater work Looks like Sleepy Eye got more snow that the south metro here!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
12-04-2013, 11:21 PM | #1270 | ||
GEARHEAD
Glad we didn't get hit like NE MN did. The arrowhead region had 2' this morning and were expecting another foot. I think the snow is here to stay this time. Here's some video of the fun. I freaking love driving this thing.
12-05-2013, 10:30 AM | #1271 |
2WD Jimmy
Damn... That LOOKS COLD. Im digging my heated Garage..LOL
12-05-2013, 11:04 AM | #1272 |
Yeeee-Haw!
12-05-2013, 08:24 PM | #1273 |
Proprietor of Dale's Corner
Wow...I must be a wuss, I got cold watching that...but...it looked like fun!!!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
12-05-2013, 09:33 PM | #1274 |
Built for FUN.
Ain't no garage queen |
12-05-2013, 11:20 PM | #1275 | |
GEARHEAD
Looks colder than it was. It was almost 30F out. Barely cold enough to snow. I wanted to get out in it yesterday cuz the real cold was moving in. I think our high today was about 6F.
BTW, my garage is heated too. That heater was by far the best spent money in the entire garage. Hick Quote:
Single digit highs and below zero lows for the next several days. I figured if I was on a snowmobile I'd be in the open, so no top for me. I had my heavy coat on, and knit hat, and gloves. The heater was on. The boy and I were just fine. Nailed it. It's gonna need a rear locker at least though. Spools are much cheaper. Need to do some parts searching. I used a lock right on my C-10. It's a bit cheaper than replacing the full carrier and it's easy to install. Need to find a bargain though, money is tight.
