#126 | |
Re: New guy with 52 AD project.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
#127 |
I'm a white wall fan, and I actually do like that set up there. I def like seeing a fat back wheel (if you got the power to back it up) that is my take. I like seeing just a slightly higher rear end when using a fat tire.
But I think it will all depend on your final ride height and if you are gonna paint it or what color scheme you come up with. But black on black looks good and black with wide white looks good too. I'm down and personally have no idea what kinda traction you would get. Could get slippy in the rain.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#128 | |
#129 |
![]() Join Date: Mar 2011
You're not rambling, you're letting us know you ideals, which is good....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#130 |
Longhair did some photo shop colors in this thread. Keep in mind, I will be going with flat paint. He could not flatten the color on the photos but it gives me some ideas.
http://67-72chevytrucks.com/vboard/s...d.php?t=477726
#131 |
Moderator
![]() Join Date: Jul 2006
I love the Coker slick, looks like a Hurst "pie crust" or "cheater" slick. There is a truck from Kansas maybe that I've seen at the HAMB drags and Goodguys that runs chrome reverse wheels with whide whites and those tires on the back. It looks killer. I'm considering getting a set, but for the track only...
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#132 |
I finished boxing in the frame this weekend and finished with POR15 and a top coat of black epoxy paint. It turned out better that I thought it would. I hope to have the fuel tank mounted this weekend and start plumbing the fuel lines. The frame is flipped, upside down in these pics. I also attached a photo of the under side of the cab.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 Last edited by 52 Rat; 12-12-2011 at 09:26 AM. |
#133 | |
#134 |
Frame and cab looking good....Jim
#135 |
A320 Pilot/USAF Retired
Frame is looking sweet!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#136 |
I installed the Grand National fuel tank this weekend. I still need to weld in the cross brace and braze on the AN fittings on the fuel feed and return lines at the tank. I should have the fuel lines installed this week. Then I will put the engine and trans back in the frame, install the radiator and start plumbing all of the lines and wiring.
#137 |
Hey looks great. I'm a bit skeptical on rear tanks though. I just had my s-10 totaled as it was hit from behind, and wow was I glad there was no gas tank
back there, it bent my frame to kindom come and pushed the bed into the cab. So I'd advise on making some cross members to help protect it incase of an accident. So how much did the tank and sending unit run you?
#138 | |
#139 |
Looking good so far keep at it!!!
Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#140 |
Thanks Mark.
#141 |
I finished the fuel tank install and got everything painted. I cleaned the engine and got it back in the frame. The fuel line frame tabs should be here today so I hope to have the fuel lines ran and connected by the weekend. I sent the ECU off for a custom tune. Getting closer to starting the engine.
#142 |
OOOHHH yeah looks sweet!!!
#143 |
man looking sweet let me tell ya ,You are ganna love the power that 6.0 puts out!! My 5.3 is a beast and its all factory..I amagine a 6.0 with standard trans is ganna be really wild!!
#144 | |
#145 |
It's coming together nice!!!
bet you can't wait to hear it for the first time? Mark...
#146 |
Like the fan setup on the rad. Where did the radiator come from, looks nice??....Jim
#147 | |
http://www.ebay.com/itm/Chevy-Truck-...item4600162530
#148 |
What did you use to clean the motor? Turned out very nice!
#149 |
It was not too dirty to start with. I used a commercial degreaser and my pressure washer.
#150 |
52rat.. you'll be very pleased with your champion radiator mine keeps the 5.3 180.all summer,Also glad to hear that I inspired someone out there! The truck has really paid off! I CAN'T GO ANYWHERE WITHOUT BEING STOPPED.LOL EVEN LAW MAN HAS PULLED ME OVER TO TAKE A LOOK
Posted via Mobile Device |
