Old 07-28-2012, 03:08 PM   #126
DURG
DURG's Avatar
Re: How many still have stock tank in place?
Originally Posted by Rich 5150 69 View Post
So ok I fell off the fence on this, going rear tank, the big brown truck dropped mine off today.......18 gallon, set up for FI already, straps included , bought sender along with it, $ 178 delivered to my door....
Source and part number ??? Thanks, Durg.
DURG is offline   Reply With Quote
Old 07-28-2012, 04:35 PM   #127
Rich 5150 69
Rich 5150 69's Avatar
Bob Drake early Ford parts .....chevy tank 49 to 52 # C4952-9200 and sender # C-9275.....30 ohm.....note will require rear crossmember to be moved back about one inch and notch in left side of frame rail to clear filler. Tank will also accept all other aftermarket senders.......if you`re not running FI right now there is a block off plate for it included, you`re still set up for carb 3/8 lines and a drain plug and straps included......
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-30-2012, 01:18 PM   #128
Rich 5150 69
Pics of new tank...I`ll bring the filler neck to the inside bed wall behind wheel well. It will hang roughly 4 inches below frame.
Old 07-30-2012, 02:45 PM   #129
GTdaddy63
GTdaddy63's Avatar
Originally Posted by koda360 View Post
Mines there, but only till i get the $$ for an under bed tank. Sorry, beyond the fact that I just don't like sitting in front of a "bomb" I also smoke and my kids will ride in that truck...... Not while I'm smoking tho!
Just got through changing mine again. I had the blazer tank installed about 5 years ago behind the rear axle. Now that I have lowered it some more I just changed it while going through changing out my gas lines to braided stainless lines I decided to put an aluminum gas tank in as well. I have the tank out and don't have any plans for it if you would like to get it. It fits perfectly between the frame rails and has the flanges that allow you to bolt it right up under frame. Just let me know as I thought about selling it and don't want alot for it. might save you some money, just have to ship if not local.
GTdaddy63 is offline   Reply With Quote
Old 07-30-2012, 02:48 PM   #130
GTdaddy63
GTdaddy63's Avatar
Durg, I just took mine out and put the aluminum one in from Performance. I took the one out that was already under the bed which was a 69-? years blazer if not mistaken. Got it from classic american trucks a few years ago. If you are interested in the one I have or just for FYI on the one I just put in from Performance- It was about $450 for the aluminum. The one I took out is steel.
Old 07-30-2012, 03:07 PM   #131
GTdaddy63
GTdaddy63's Avatar
This is the tank I just removed from under the bed prior to my aluminum one if you are interested, it is great shape and no rust or leaks.
Old 07-30-2012, 03:31 PM   #132
GTdaddy63
GTdaddy63's Avatar
new aluminum tank installed.
Old 08-13-2012, 12:47 PM   #133
txinliner
txinliner's Avatar
makes me 29 no plans of changing
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 08-13-2012, 08:12 PM   #134
ChrisDollins
ChrisDollins's Avatar
Another one here! When I do a 6ltr swap, ill put one under the bed. For now this one works great.
Chris
ChrisDollins is offline   Reply With Quote
Old 08-13-2012, 10:07 PM   #135
BigDan3131
BigDan3131's Avatar
The behind the seat tank has to go so I can put buckets in for my long legs and the two saddle tanks go bye bye as well. I plan to have a tank built to my specs with two filler necks that fit flush on the rail so I can fill from either side. I will be boxing in the area outside the rail for protection and it will have the drag style sump in it.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-14-2012, 12:15 AM   #136
corvettejim1968
corvettejim1968's Avatar
yep mine still there
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 09-03-2012, 01:13 AM   #137
Robert Bergstrom
Robert Bergstrom's Avatar
Will keep mine stock. Yes, if I was in a real bad crash it will rupture. I have seen two Chevy truck accidents (71 and a 68). One wrapped itself around a telephone pole at the driver door (No leakage from the tank at all). The other the truck went on its roof going 80 plus MPH and slid for a block. No leakage there either. I think to really get the tank to ruptre would either be an oddball freak accident or a huge amount of force. A small rear ender would rupture a rear bed tank pretty quickly if it hit the axle or a bent bumper.
Vancouver Bob
Robert Bergstrom is offline   Reply With Quote
Old 09-03-2012, 10:03 AM   #138
vintagetin
vintagetin's Avatar
The tank is still in the cab in my truck. It doesn't stink or leak ever, and it's the original tank. If I was going to add the under bed tank it would be just to increase the capacity for long trips.
vintagetin is offline   Reply With Quote
Old 09-03-2012, 10:23 AM   #139
LT1 Burb
LT1 Burb's Avatar
Just a note to you guys changing tanks and going with steel braided lines, I used Russell high pressure braided lines on my supply and return fuel lines on my burban and they leaked after a couple of years. The frame the whole length of the lines was wet with gas so I had to rip them out and use aluminum lines, I am done with steel braided lines now.
LT1 Burb is offline   Reply With Quote
Old 09-03-2012, 10:54 AM   #140
CRGRS 66
CRGRS 66's Avatar
mine still behind the seat... if I fill it much past half full, strong smell of gas for a little while One of my winter projects to rectify that, but I will keep it where it is.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 09-03-2012, 11:41 AM   #141
My63C10
My63C10's Avatar
All stock here and I am sure it will stay that way for now.
My63C10 is offline   Reply With Quote
Old 09-03-2012, 07:39 PM   #142
Volvo_Matt
Volvo_Matt's Avatar
#29
Just reinstalled it in the cab after having it repaired and expoxied.
Rebuilt carb., new fuel lines, filters, and fuel.
1963 LWB 350 M-21 4spd comp/edelbrock/holly/LT1 1.94/1.60
Volvo_Matt is offline   Reply With Quote
Old 09-06-2012, 01:45 PM   #143
clemdaddy
clemdaddy's Avatar
the truck shop in orange cali has repros of the 20 gal. full width tank... got one for my current project and i like it very much... always wondered why they made tanks that didn't use all the space alloted behind the seat... adds about 3 gallons to the capacity and just looks right... 2 cents
clemdaddy is offline   Reply With Quote
