11-08-2015, 10:29 AM | #126 |
Re: Another 4X4 Front Sway Bar
Yes. Sending pm...
11-27-2015, 08:10 AM | #127 |
Sleep-Deprived
I'd like one also if you have one; 74105
12-04-2015, 07:29 PM | #128 |
Sold and shipped to halfton...Thanks!
Here's another one available. Its in good shape, but there are some small scars from it being welded to the frame. $90 plus shipping. |
01-08-2016, 10:55 AM | #129 |
Sleep-Deprived
Bump for your thread - Thanks again for providing these for sale - it can't be too easy removing them from the trucks they come off of.
Installed on truck with a 6 inch lift. If I ever have the front clip off, I'll make a couple of adjustments to the install. Had to remove the fan and radiator to drill 2 of the holes and only used 2 spacers under top mounting points of the frame so you can't see them.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
01-09-2016, 11:27 AM | #130 |
Looks nice! It looks like you moved the cross member back a bit to line up with the 6" lift. Thanks for posting up the pictures.
01-09-2016, 05:33 PM | #131 |
Sleep-Deprived
Thanks, I used the factory rivet holes in the bottom of the frame and drilled new holes in the top of the frame that moved the mounting points about 3" back from the factory rivet holes in the top of the frame. The replacement cross member has 2 holes on either side and comes to a sharp point that gets in the way for this install. Removed the point and one mounting hole to help with installation. If I had the truck apart, I could be more precise with the new mounting holes in the frame, but as it went, took using c-clamps and pry bars to get it to set in place and lined up. Hopefully this will help anyone else consider doing this - I just like the more factory look of this set up compared to the aftermarket bars that are out there.
07-01-2016, 01:05 AM | #132 |
ttt 1 still available
08-14-2016, 01:54 AM | #133 |
KrazyRay,
Do you still have one complete set up available? I would prefer one without the weld marks you make reference to for the last one posted. Shipping will be to 97217. Thanks! |
08-15-2016, 07:05 PM | #134 |
Yes, I have one without the weld marks. $125 shipped to OR.
Thanks, Ray |
08-20-2016, 10:08 PM | #135 |
Ray,
Sway bar assembly came today. Looks great, thanks ! |
08-22-2016, 10:21 AM | #136 |
Any left? I'll take one of the set ups if you do.
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process Last edited by Tdrcreyn4; 08-23-2016 at 07:59 AM. |
08-22-2016, 10:26 AM | #137 |
Please put me in line for one of these.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
