Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 06-26-2015, 01:16 PM   #1
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
back up top!
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline
Old 06-26-2015, 02:17 PM   #2
jessemthompson
These guys build top notch radiators at a reasonable price. Very happy with my decision to go through them for my LS swap radiator. Thank you.
jessemthompson is offline
Old 07-11-2015, 04:17 PM   #3
steveo3318
steveo3318's Avatar
Hey Sparky I need a 4 core with no trans coolers or ac ports as I am running a vintage air AC and standard trans. Also do your radiators work with the stock fan shroud and fan? I am running a 383 about 450 hp with a 3 core factory now and runs cool but I know I will need more cooling when I put my AC on.
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline
Old 07-12-2015, 11:27 AM   #4
SparkyRnD
SparkyRnD's Avatar
We have a scratch & dent version on the shelf with that exact set-up (cosmetic issue only, been pressure tested and is fine). Regular price is $450, forum member price is $425, and for this scratch & dent unit, $375. We've been told by a few customers that they were able to use their factory shroud (I don't believe any mods were done to their shrouds either).
Old 07-12-2015, 11:33 AM   #5
steveo3318
steveo3318's Avatar
Ok sparky after lots of research last night I am thinking one of your 2 cores would cool better than a 4. Is the scratch and sent a 4 core or 2 and if you could shoot a picture of the dent I would be very interested. If it's on the bottom or side I may be ok with it as I still show my truck
Old 07-13-2015, 08:26 AM   #6
SparkyRnD
SparkyRnD's Avatar
all of our radiators are made with dual 1" thick cores (same thickness as a brass & copper 4 core, as the brass & copper style used four 1/2" thick cores, while aluminum uses two 1" thick cores). The marks are on the core side (fins) but with a fin comb could be straightened. I'll get a pic today for you. PM me your email address
Old 07-28-2015, 04:20 PM   #7
SparkyRnD
SparkyRnD's Avatar
bringing up again!
Old 08-12-2015, 05:20 PM   #8
SparkyRnD
SparkyRnD's Avatar
back up!
Old 08-27-2015, 11:39 AM   #9
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 09-13-2015, 02:20 PM   #10
SparkyRnD
SparkyRnD's Avatar
bringing up again
Old 09-29-2015, 05:12 PM   #11
SparkyRnD
SparkyRnD's Avatar
back up top
Old 11-02-2015, 10:22 AM   #12
SparkyRnD
SparkyRnD's Avatar
Up top again
Old 12-03-2015, 09:57 AM   #13
SparkyRnD
SparkyRnD's Avatar
back up top
Old 12-09-2015, 12:58 AM   #14
Az. Hank
Az. Hank's Avatar
P/M Sent
My 55 Build 55 C-4
Az. Hank is offline
Old 12-22-2015, 11:10 AM   #15
SparkyRnD
SparkyRnD's Avatar
remember that we will accommodate any engine conversion at no additional cost!
Old 12-28-2015, 05:34 PM   #16
SparkyRnD
SparkyRnD's Avatar
remember to ask for your discount when ordering!
Old 01-08-2016, 03:30 PM   #17
SparkyRnD
SparkyRnD's Avatar
back up again
Old 01-12-2016, 04:09 PM   #18
hozeman469
Need one for a ls swap in a 69 pu
hozeman469 is offline
Old 01-13-2016, 11:11 AM   #19
SparkyRnD
SparkyRnD's Avatar
Invoice sent, thanks!
Old 01-24-2016, 01:28 PM   #20
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 02-22-2016, 12:55 AM   #21
class01
class01's Avatar
Im doing an LS swap and probably going to run a higher than stock stall in the tranny. Do you recommend a separate transmission cooler or is your built in cooler enough?
class01 is offline
Old 02-22-2016, 10:03 AM   #22
SparkyRnD
SparkyRnD's Avatar
Our cooler should be adequate for your needs. The only time we really recommend a separate auxiliary cooler is when you have a high horsepower engine, or live in extreme heat with a medium or higher engine build.
Old 02-22-2016, 11:21 PM   #23
class01
class01's Avatar
thanks sparky. im not at the point in my build to buy anything but i will be going with you on a radiator. hopefully by summertime
class01 is offline
Old 06-05-2016, 10:48 AM   #24
SparkyRnD
SparkyRnD's Avatar
back up top
Old 06-17-2016, 09:36 AM   #25
SparkyRnD
SparkyRnD's Avatar
we also carry radiators for many other makes and models, as well as fabricate custom radiators!
Closed Thread
