Old 01-16-2016, 10:13 PM   #126
steveo3318
steveo3318's Avatar
Re: Pace performance fitech fuel injection
heres my install thread
http://67-72chevytrucks.com/vboard/s...33#post7450333
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 01-19-2016, 12:29 PM   #127
Big Kev-O
Big Kev-O's Avatar
Originally Posted by TA1968 View Post
This is to Big Kev-O what vented fuel cap did you go with? I'm not sure you mentioned it or I might have read over it.
Sorry I have no clue. All I know is my tank does not have a vent line so I think it is a early year 67-68 tank. I assume the cap is vented. The cap that is on the truck has a lock so I think it may be aftermarket. I dont know much about the different fuel tanks or caps. I need a replacement but I am not quite sure what to order.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 01-19-2016, 02:41 PM   #128
PowerdbyChevy79
PowerdbyChevy79's Avatar
man after reading this ..yall got me fired up...gonna start doin my research now..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-19-2016, 02:46 PM   #129
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Also take a look at this :http://67-72chevytrucks.com/vboard/s...d.php?t=686601
66 C20 Service Truck:
Old 01-19-2016, 07:22 PM   #130
dirtyjim
dirtyjim's Avatar
they are also coming out with a multiport setup, the only info I could get out of them on it was it wouldn't work with my mercruiser efi tunel ram so i'm going to assume you would still have to use their throttle body
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 04-16-2016, 11:39 AM   #131
empi1776
Originally Posted by Lattimer View Post
No, I usually have a very slight vacuum. Mine is a correct aftermarket vented cap for 1970 and earlier trucks. I had to modify the seal quite a bit to get it not to leak gas on corners, but now it works well.
Question, how did you modify your cap so as not to spill on corners. I cannot get my jot to leak.
ty
empi1776 is offline   Reply With Quote
Old 04-16-2016, 01:18 PM   #132
Lattimer
Lattimer's Avatar
ty
Step one, get a cap with a vent that works correctly. I bought 3, 2 from Brothers and 1 from LMC. 1 of the Brothers caps worked. The blue part in the center is the vent. If you try to blow through it it shouldn't let air through. Not recommended on a used cap...LOL.
Step 2, buy an O-ring kit. I got mine from Harbor Freight. It has a variety of sizes.
Step 3, add o-rings. I put one around the center part of the cap against the gasket, and I stacked several behind the gasket. This adds pressure to the gasket and helps it seal against the tank neck. My o-rings are starting to fail, they are about 2 years old now.
The cap is hard to turn like this, but I have had zero leaks even with a full tank in a hard right turn.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 04-17-2016, 06:50 PM   #133
lutronjim
Just a note - some orings are not gas friendly especially e10.
lutronjim is offline   Reply With Quote
Old 04-17-2016, 09:34 PM   #134
Lattimer
Lattimer's Avatar
I think these are Buna. So far they are surviving ok. And they are cheap, so when they get too bad I will just replace them.
Shawn
