Old 03-13-2019, 05:38 PM   #126
bigmoe
bigmoe's Avatar
Re: Speed Engineering LS Swap Headers Findings
Don't forget to check clearance from your bell housing as well. I had to trim a bit of my bell where the starter bolts up. Scorpion LS shorties SP16-5077CC.
bigmoe is offline   Reply With Quote
Old 03-13-2019, 05:44 PM   #127
crakarjax
crakarjax's Avatar
Originally Posted by TA_C10 View Post
Actually I'm worried about the header heat when engine running during driving melting the nylon nylocks rather than the grinding process. If I clearance out the clamshell top shelf the header will definitely fit, but it will be about 3/16" away from the top of that nylock nut.
Thoughts? Not sure header wrap will clear 3/16" gap, it will be touching yeah?
I see what you're saying. What brand sliders are you using?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-13-2019, 06:19 PM   #128
bigmoe
bigmoe's Avatar
My adapter plates were bought off Ebay. No slide but 4 different positions. I used CPP mounts.
Old 03-13-2019, 06:24 PM   #129
gringoloco
A guy with a truck
gringoloco's Avatar
Use a mechanically locking nut instead of the nylock, problem solved. They are very slightly ovaled so that they don’t back off
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-13-2019, 06:27 PM   #130
crakarjax
crakarjax's Avatar
I'm wondering if you can rotate the mount so the clamshell is more towards the bottom of it?
Old 03-13-2019, 11:02 PM   #131
TA_C10
TA_C10's Avatar
Uh, what are these, you have a name or a picture cuz this sounds like a great idea!
Explain this, how can I rotate the clamshell? I have sliders and mounts kit from performance online.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-13-2019, 11:30 PM   #132
Captainfab
60-66 Nut
You could put the bolt in from the other way or just use an all steel lock nut. Fantenal calls them top loc nuts.
Old 03-14-2019, 12:24 AM   #133
TA_C10
TA_C10's Avatar
Boom. Found em. Distorted thread locknut.
https://en.m.wikipedia.org/wiki/Dist...thread_locknut
And I also found the Fastenal brand top lock nut.
I will get one of these and replace the nylock nut. I've used these before now that I'm setting them... And as for putting the bolt in the other way that is out of the question as the adapter plates are right up next to the block and these bolts come from the backside so can't switch them like that. I should be able to clearance a small amount of that clamshell top plate and use the top lock nut. Thanks guys, I will report back here and on my build thread when I get this completed.
"It's only money".
Old 04-06-2019, 09:17 PM   #134
62chevy302
hillbilly
62chevy302's Avatar
These headers fit great. I had to slide the engine back an inch for them to clear the frame but they fit great everywhere else.
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 04-06-2019, 11:30 PM   #135
Captainfab
60-66 Nut
Which ones are you using? The long tubes, mid length or the shorties?
Old 04-07-2019, 09:35 AM   #136
62chevy302
hillbilly
62chevy302's Avatar
Im using the long tubes with 1 7/8 primarys. They fit better than the old longtubes that were on the 283 when I got the truck. I will try to get a picture under neath to show how far they hang down.
-1962 C-10
Old 04-17-2019, 11:03 PM   #137
TA_C10
TA_C10's Avatar
Here is what I ended up clearancing. Now you can see that nylock nut underneath and why I was worried about the heat melting it. But I still plan to get one of those all metal Top Lock Nuts.
I think this is going to work just fine
"It's only money".
Old 04-18-2019, 12:03 PM   #138
crakarjax
crakarjax's Avatar
Can anyone say how much louder these headers are vs. manifolds? I've got LTs on my other car and they kind of drone, which is cool at first but not so much on longer trips.
Old 04-26-2019, 12:22 AM   #139
stevenbear72
stevenbear72's Avatar
Been thinking about buying a set as well.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 05-03-2019, 09:02 PM   #140
hfd410
hfd410's Avatar
Was looking through here and didtnt see my exact combonation of a 71 with a 5.3, speed engineering shorties, CPP mounts and clamshells. I have the multi position dirty dingo plates, not the sliders. Anybody with this combo ?
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438
hfd410 is offline   Reply With Quote
Old 04-20-2020, 10:40 AM   #141
jjzepplin
jjzepplin's Avatar
I think I am getting a set of the 1 7/8. Seems they could put a v band on the collector and it probably could solve a lot of shipping issues and make us all happier. They are cheap enough to add a few bucks to the price for the peace of mind. I've got the f body setup with a T56. It's all in mock up right now. Anyone running this setup yet?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-20-2020, 10:46 AM   #142
jjzepplin
jjzepplin's Avatar
Originally Posted by AustinBelair View Post
Here is a pic
Are you up and running yet?
Old 04-21-2020, 09:12 AM   #143
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I'm using them on my K10 swap which is currently in process. I bought the shortie version (25-1021) because I have a 4WD crossmember to contend with. These will give me more room to work my exhaust around/through. I also decided to send them out for ceramic coating.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 04-22-2020, 11:00 AM   #144
jjzepplin
jjzepplin's Avatar
The spark plug clearance looks pretty good on the drivers side. How about the passenger side?
Old 04-22-2020, 08:57 PM   #145
derotoreut
derotoreut's Avatar
Good on both sides.
~ Dan
Old 04-27-2020, 06:00 PM   #146
69GMC2004
Active Member
Any chance anyone has used the 1 7/8" long tubes with a No Limit rack and pinion?
69GMC2004 is offline   Reply With Quote
Old 04-29-2020, 07:54 PM   #147
Pitpig
Bought the shorty version for around $200. Fit great , but have to trim passenger side ear off th 400
Pitpig is offline   Reply With Quote
Old 06-07-2020, 09:11 PM   #148
Lugnutz65
Lugnutz65's Avatar
My Vortec 5.3 is on a run stand and has 2001 Camaro LS1 manifolds. They hug the block nicely.
I intend to keep a manual tranny and from the looks of things these manifolds will interfere with a hydraulic clutch slave.
So I want to know if maybe these Speed Engineering headers will give me more room. I know they will fit nicely between the frame rails of my 65 C10.
Anyone willing to make a few measurements?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-08-2020, 09:19 AM   #149
clay68c10
clay68c10's Avatar
I have the long tubes and there’s no clearance for a Novak external slave.
Not a great pic, but it kind of shows the lack of room.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-08-2020, 09:25 AM   #150
Lugnutz65
Lugnutz65's Avatar
Thanks. I’m thinking the shorty headers turn down sooner but that’s the clearance info I need. I’m sure others have mated Tremec trannies. I just need to see their setup. I don’t think a Novak setup will work for me either.
