#1 | |
![]() Join Date: Oct 2012
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
![]() Great progress.
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
![]() ![]() Join Date: Jan 2005
Reassembly
Setup
I also reinstalled the sender with a new Jeep plastic float and a new seal.
![]() Join Date: Sep 2013
Nice truck, I love it! I'll follow your thread as I work on my '71 step-side.
Bobby 1971 K10 SWB Stepside 1968 Chevy Camaro 1931 Ford Model A (truck) 1997 Land Rover Defender 90 1994 Harly Davidson MT350 |
This evening I worked on getting the pinion depth and preload set. I settled on .035" on the pinion which is only .002" less than the funky trashed shims that were in there. The drive side would have been better with a thinner shim, but the coast side would be way on the edge of the tooth that way. It feels smooth when rotated.
I installed a solid sleeve on the pinion and got the preload in spec. Took a couple of hours to get it right, but now I will be able to take it apart and put it back together in the future without worrying about messing up a crush sleeve. I cleaned up and painted the pinion yoke, so installation will have to wait until the paint dries. This is a nice original yoke I had left over from another project. The one that was on this truck had messed up splines and was loose on the pinion. The pinion splines look perfectly fine, and this other yoke fits nice and snugly. I wouldn't be surprised if the issues with this rear end were what doomed this truck in 2001. Last edited by pjmoreland; 10-30-2024 at 03:45 PM. |
Finished setting up the rear end this evening. Got the backlash set at .008" and the carrier bearings are preloaded.
One of the axle shafts was the wrong length so a brake drum wouldn't fit (it would hit the backing plate). I replaced it with a new axle shaft that's the correct length. Installed new studs on both sides and painted the axle flanges. Cleaned up the diff cover. It had a few small dents and the bottom edge was bent up from being hit with jacks over the years. Straightened it out a bit and then painted it black. Last edited by pjmoreland; 11-01-2024 at 03:05 AM. |
More photos
Diff cover photos
![]() ![]() Join Date: Jul 2003
As always, beautiful workmanship.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#13 |
#14 |
Put some gear oil on the internals to help keep rust at bay. I will fill it after I weld on new perches. Installed the cover.
#15 |
All about them K’s
![]() Join Date: Jun 2014
Excellent work!!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#16 |
#17 |
All about them K’s
Man that’s always how it is, time and money. Rarely do you ever have sufficient of both. You’re doing a great job so far. This thing has turned around in a huge way in not that much time! A lot of these trucks would be lucky to have more owners like you!
#18 |
![]() Join Date: Jul 2021
Great job, slowly but surely you will have back on the road before you know it. Then all of the hard work will be a distant memory. Keep it up!!
Darrell ![]() 1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck) 2000 S10 Xtreme (Black Magic) (My Drag Truck) |
#19 |
#20 |
More axle work today. Removed the bent rear perches in preparation for replacing them. Used a large drill bit through the center hole to mark the location of each perch on the axle.
#21 |
Replaced the front axle u-joints. They were really stuck in there. Took lots of pressing back and forth on both sides to get them to break free. Cleaned them up with a wire wheel and painted them
#22 |
Reassembly
#23 |
Also pulled the front carrier and pinion bearings. Assembled a puller from various tools.
#24 |
Did some rust removal on the portion of the front diff carrier that was not submerged in oil. It's badly pitted, but thankfully none of the machined surfaces or gears are rusted.
#25 |
Welded new perches onto the rear axle this evening. Decided to set them at the stock angle since my suspension is at stock height.
Thanks, Tim, for your help! Last edited by pjmoreland; 12-15-2025 at 06:56 PM. |
| Bookmarks |
