Old 07-20-2011, 12:04 AM   #1551
PhileCool
PhileCool's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
WOW what an unbelievable build. I'm inspired by your work, have read up to here tonight page 28 (Just Joined). I can't wait to see it finished...Man I need a garage!!
PhileCool is offline   Reply With Quote
Old 07-27-2011, 02:27 PM   #1552
Kinghat
Kinghat's Avatar
Can't believe this made it to the 5th page. Any news?
Hail to the King, baby.
Kinghat is offline   Reply With Quote
Old 07-27-2011, 06:47 PM   #1553
68 TT
Still plays with trucks
68 TT's Avatar
What's up with that? Get to work Drew
He is probably hard at work making money while the weather is good or spending the nice weather outside with his family.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-27-2011, 09:09 PM   #1554
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Ding. Ding. Ding. You are correct.
School is almost in session, more time then.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 07-31-2011, 12:16 PM   #1555
drewskiren
drewskiren's Avatar
I was able to spend some time Saturday to keep plodding through the body work. Maybe I am being too much of a perfectionist? I think I will be able to prime for the last/second last time today.
Drew
Old 07-31-2011, 12:53 PM   #1556
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Drew, I can't blame you for being a perfectionist. I would be too because this is a super nice truck! It's looking great!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-31-2011, 01:21 PM   #1557
mcbassin
Still Learning
mcbassin's Avatar
Nice work as always Drew! Keep the updates coming.
mcbassin is offline   Reply With Quote
Old 07-31-2011, 07:41 PM   #1558
doc70sub
doc70sub's Avatar
Drew,
As a Sub owner, I was initially concerned w/ cutting one up - but after ready the ENTIRE thread, I'm truly impressed!!
Keep up the good work & cannot wait to see it completed!!!
D.
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 07-31-2011, 11:16 PM   #1559
youngrodder
youngrodder's Avatar
Good to see that your back on it....
Keep it up.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-31-2011, 11:29 PM   #1560
oldman3
oldman3's Avatar
Looking good....Jim
oldman3 is offline   Reply With Quote
Old 08-01-2011, 06:27 AM   #1561
68greg
Drew, good to see you back at it. I forgot the 'burb you built this off of was yellow. Perfectionist, I don't think you'd have it any other way, this is going to be a super nice truck and a radical departure from the norm. Keep up the awesome work and I look forward to seeing it completed.
68greg is offline   Reply With Quote
Old 08-01-2011, 10:23 AM   #1562
drewskiren
drewskiren's Avatar
OK, looking better now. We'll see how the monster looks after a wet sanding with 400 grit. I'll be down to tiny spots to fill with glazing putty I'm pretty sure. Then prime again and block/wet sand with 600 grit.
Everything I read talks about how 400 grit scratches don't show in the final paint, but I beg to differ. I tried it on both the black truck and the green Denali and I could see the scratches in the right light. I also do not trust that if I wet sand/block with 400 grit and then go back over with the 600 grit that I will find and eliminate all the 400 scratches. When you are doing it you just cannot tell where you have been or not since it is already a sanded texture. That is why I will respray the primer and then go over it again, this time with the 600 grit. I use and 11 inch block with 8 by 11 sheets of wet or dry sandpaper cut in half wrapped on the block. If you hand sand this step you can end up with tiny ripples in the surface instead of mirror flat.
Drew
Old 08-01-2011, 11:25 AM   #1563
mcbassin
Still Learning
mcbassin's Avatar
I've had the same results. 400 grit will show scratches in the final paint. I always use 600 for the final blocking too. I guess if you're wet sanding and buffing it may not be as much of a factor using 400?
Old 08-01-2011, 12:57 PM   #1564
68 TT
68 TT's Avatar
The shop I worked for used 400 as well. The owner who sprayed everything said it was how he knew there was enough sealer on the truck by when the 400 grit scratches in the primer were no longer visible. I think he rushed things as it was a collision repair shop.
20 years ago the factory paint jobs weren't so hot so his repairs were on par with what was on the truck to begin with. Definitely not show car worthy but fine for a daily driver.
Just to be safe I always use 600 to wet sand the final primer coat on my own projects.
Old 08-04-2011, 11:13 AM   #1565
drewskiren
drewskiren's Avatar
Originally Posted by Dinos63 View Post
awsum brotha !
Originally Posted by red71cheyenne View Post
Well, it took me two days to get all the way thru your build, but MAN!! Was it worth it! Great work and inspiration! This is going to be the same as my next project, I appreciate you figuring out all the headaches for me up front. I really love the newer HVAC idea too, but I may have to re-engineer it to keep the stock dash and controls.
Just a great build thread and I wanted to let you know your project rocks, can't wait to see it done.
Originally Posted by Dieselwrencher View Post
Congrats on doing such great work for other people! That's awesome.
Originally Posted by VA72C10 View Post
Yes, but not because of your build Happy because of how blessed I am...and I am happy about all the missions work you've been doing....
....but I'm upset because you stalled to make sure you weren't finished by my ETA
just kidding....
but I am glad to hear the burb will start to get some more work done on it soon
Originally Posted by jbclassix View Post
Man! I forgot how cool your truck looked, Drew!
Originally Posted by jamie72 View Post
this is going to be awsome... great work drew.
Very nice work as usual. Did you paint that green unit in your portable paint booth too?
Originally Posted by eagleuh1 View Post
Whats this epoxy seam sealer that flows that you speak of? Oh and great work you do, both on and off the truck. Jim
Originally Posted by Mike C View Post
Beautiful work Drew. Don't know how this is the first day I have seen this thread, but will continue looking for it!
Originally Posted by jeffg1010 View Post
Man, I love it. Can I call dibs on it, when you finish it and decide you want another project? Of course, as a 'Burb guy, I am obligated to say "I cant BELIEVE you cut up that all original 'Burb." - there... I'm over it.
Originally Posted by Erick Barnett View Post
your project is looking good makes me with i had try to build a crew
mmmm! looks better than cake!
Looking good. So when will the body parts all meet on the frame for the last (permanent) time???
That bed looks great. I'd definetly like to have a friend that can work one over for a few hundred bones.
Originally Posted by 1985-GMC View Post
Awesome build man! I love the blue & white!
Originally Posted by 69-72 View Post
Looks good
Isn't that door pillar vent for the in cab gas tank ventilation?
Originally Posted by WORP67 View Post
I have spent the past couple days goin through this build. Just had to say very very nice work man. Got some ideas from you on how to do that late model AC. looks really nice. Cant wait to see it finished.
Originally Posted by 68greg View Post
Looking good drew, truck has come a long way in a very short amount of time especially with all the other endeavors you have taken on recently. Great job keep it up motivates me to get home and get to work on mine.
Originally Posted by 1tonchevy View Post
WOW great work sir. sat and look through the whole tread (last night and sme of today! amazing job!
Originally Posted by doc70sub View Post
Drew,
D.
Keep it up.
Marc
Originally Posted by oldman3 View Post
Looking good....Jim
Thanks to all of you who keep encouraging me, it is quite addictive. If any of ya'll move to Memphis, you can be my best friend.
Drew
Old 08-04-2011, 02:00 PM   #1566
Dieselwrencher
I doubt I move there, but I may end up there for some training some day. If so I'll try to get a hold of you before then.
Ryan
Old 08-04-2011, 02:40 PM   #1567
firethorn
incredible build, keep up the good work.
firethorn is offline   Reply With Quote
Old 08-04-2011, 06:54 PM   #1568
luis979motoring
luis979motoring's Avatar
WOW!!! what a build!!! you truly just motivated me to finish my C10... lol. Can't wait to see this thing hit the roads!
also, let me mention that through all this reading, I realized that by the time I got here, I totally forgot you started with this.....
luis979motoring is offline   Reply With Quote
Old 08-04-2011, 11:32 PM   #1569
jbclassix
Junk Yartist
jbclassix's Avatar
Memphis, I'm down! My wife wants to know if you get tornadoes. That's the deal breaker I guess.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-05-2011, 03:07 AM   #1570
71Sleeper
71Sleeper's Avatar
Drew love the build.... I am planing on repainting my 71 back blue. What is the type of blue are you using?
71Sleeper is offline   Reply With Quote
Old 08-05-2011, 04:22 AM   #1571
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
I'm In lol
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 08-05-2011, 10:44 AM   #1572
drewskiren
drewskiren's Avatar
The Factory 1972 "medium blue". Yes, that is the name of it.
Drew
Old 08-05-2011, 01:55 PM   #1573
68greg
Drew, when I'm not playing in the sand I'm only 25 miles north of Little rock so I'm only about an hour and 45 min away. I need some painting lessons can you wait till november to paint it.lol
Old 08-05-2011, 10:47 PM   #1574
drewskiren
drewskiren's Avatar
I hope not!!!
I do have 2 junk doors and a hood with a dent we can practice on if you like.
Drew
Old 08-05-2011, 10:54 PM   #1575
drewskiren
drewskiren's Avatar
Yeah, I know, I never let it get to the 5th page back. How am I going to get any views way back there???? We are lake-ing it this weekend, sorry no progress.
Drew
