#151 |
Re: Xmas In March, Thanks To Porterbuilt.
#152 |
looking good..can't wait see when its all done!!!
#153 |
MeanGrean, how did you/do you plan to wire the two compressors together? I am using a viair relay/pressure switch but I'm not sure how I'm going to use it to hook up two compressors. Any suggestions?
Thanks |
#154 |
Epoxy Primer Friendly
[IMG]http://*****************/how_to/wire-diagrams/compressor.gif[/IMG]
#155 |
Originally Posted by SCOTI
Since most are using the 380's I would say the 480's would work just as well. Got that front clip in place yet? Scoti, got the front clip in place this wk. looks good ![]() I'll be posting pics this wkend when I push the old girl out of the garage, so she can get some sun if it doesn't rain. ![]() |
#156 | |
I'm going to be using one, and thwn I'm putting a pressure switch on each tank. Hope this helps you, let me know if you need more info. ![]() |
#157 | |
#158 |
Any progress pics MeanGrean ???
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
#159 |
True Addiction
I want one of the Porterbuilts crossmembers so bad. From what I understand it narrows the front and moves it forward? I was wondering what kind of offset you guys are running that have the Porterbuilt X member. I have a narrowed 9" out back and want to run wheels with a large outside lip. I already have Strong Arms and am running RE7's with CPP drop spindles. I was hoping that someone could give me the exact specs or any helpful info on the Porterbuilt X member. Thanks
#160 |
BigShoe24-
I run a 8.5" wheel with a 5.5" backspacing. The Dropmember will narrow the track-width one inch per side, and yes, it does move the axle center-line forward to center the wheels in the wheel-wells when deflated. If you have some more specific questions post em up on the Dropmember thread and I will be happy to answer them all.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#161 |
#162 |
#163 | |
#164 |
A sneak preview of the truck with the new front end,
![]() ![]() I'm also working with he original fender wells, trying to make then work so i don't have to use a trailer fender. Not that there anything wrong with. ![]() |
#165 |
It's lookn' awesome.
![]() I can't wait to get started on my Blazer.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#166 | |
Thanks Dan |
#167 | |
#168 |
what are you going to do for hood hinges?
#169 |
hey meangreen could take another pic at a differnet angle of your inner fenders. i'm curious how you mounted in there so cleanly...thanks!!!
#170 |
NICE!!!meangreen
#171 |
True Addiction
MEANGREEN70,
Your truck looks GREAT! I was wondering what you think of running 22's (probably will be 9.5" or 10" wide) with the porterbuilt. Is this a bad idea? I dont really care to lay frame, just want to get really low. Plan on purchasing a crossmember in the very new future. Just need to save a few more $$$. Thanks for any suggestions. Shoe, |
#172 |
dan468, I'm going to use the hinges that sachse rod shop makes,their down the street from me, so I seen the hinges in person and they are cool looking.They mount on the firewall. I'll try to get some pics of then, or you can go to thier wed site. ![]() |
#173 |
#174 | |
they tuck just perfect under the fenders for me. But like I said this in just my personal opinion, I have seen some nice trucks with big wheels. I dont thing you'll have any problems running then, I do know that it takes more trinning of the inside fenders. I hope this helps you some. ![]() |
#175 |
True Addiction
PORTERBUILT,
I was wondering how much more drop the crossmember provides? I believe I have saved up enough money to purchase the crossmember, rack & pinion, according to the prices in your website. Last, I was curious to know if you keep them in stock or build upon ordering. Thanks for the help, and any other information would be great. |
