Old 10-03-2012, 09:21 AM   #151
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1958 LS2 with C4 front and rear
Originally Posted by Lolyin58 View Post
Time consuming and teedius for sure. Look at the bright side you are almost there. Once the truck fires al that pain will be forgotten. Good job!!
You got that right....
I was excited when i started this build......then it became like most builds a pain in the a$$....but now i am excited to be close to the end of the project..
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 10-03-2012, 09:58 AM   #152
wutnxt
Well I think the rad is in for the last time......it actually has water in it so thats exciting. Engine has oil,tranny has fluid and the ac lines have been crimped and bolted in. The vintage air set up has been for the most part installed give or take a few screws that have to wait until it's charged. Mounted the controls for the ac as well, they were late to show up and that made the install a little bit more difficult. I merged the LS2 ac system with the vintage air system so i guess we will see how that works out
Old 10-04-2012, 08:44 AM   #153
Lolyin58
Lolyin58's Avatar
Sounding good. Almost all the small details wrapped up. U got some pics for us???
Lolyin58 is offline   Reply With Quote
Old 10-04-2012, 09:08 AM   #154
99 to Life
99 to Life's Avatar
I have a question, for using an LS engine or even TBI, what ignition are you using? It is possible when you reprogram the cpu and do away with the VATS that you could use just an old ignition switch from anything?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-06-2012, 09:25 AM   #155
wutnxt
I will down load some new pictures later today...they don't show how much work has been done....Seriously it's been crazy...Yesturday I had myself plus another guy all day....plus another guy for a couple of hours. We checked alot of the stuff as we wired it with a power probe but as we power up the basics some of it has done so well. I want it all done but I really want to make sure everything is strapped tight wrapped and ready to be driven, I don't want to revisit anything for awhile.
Old 10-06-2012, 09:27 AM   #156
wutnxt
I am still waiting for the LS guru my buddy know to show up....But I am going with yes.....Shouldn't be a problem at all. I don't speak LS all that well yet but have learned tons since I started this project.....and want to learn more
Old 10-06-2012, 10:06 AM   #157
eagleuh1
eagleuh1's Avatar
Any ignition switch will do the trick. All you need is for a switch to power up the relay for ignition on circuits. And power up the starter relay to turn it over. Really simple. The wire for the coil on the old engine works for the ignition on circuit. Old starter wire goes to the relay on my under hood fuse box where the starter relay is.
eagleuh1 is offline   Reply With Quote
Old 10-06-2012, 10:21 AM   #158
eagleuh1
eagleuh1's Avatar
Oh, and one of my favorite truck styles, this one in particular.
Old 10-06-2012, 01:54 PM   #159
wutnxt
Hey thanks for jumping in on the switch.....
This body style was never really my thing....I have always been a dir hard 64-66 truck guy......But since i have started this I really like the way it looks ...I could just sit and look at it sometimes..maybe thats why it's taking so long to put together...
Old 10-06-2012, 01:57 PM   #160
wutnxt
So....
The vintage air conditiong i have been working on......Some pictures aren't great and it's my first install.....but here you go
Old 10-06-2012, 01:59 PM   #161
wutnxt
Work in progress.......
For my first AC conversion it was more work then I thought and i should have knowen better....lol
Old 10-06-2012, 02:11 PM   #162
wutnxt
Lots of parts and pieces.....
Old 10-06-2012, 02:17 PM   #163
wutnxt
I merged the LS parts into the Vintage air kit which included the need for some Tig work and some fitting rework.
Old 10-06-2012, 02:20 PM   #164
wutnxt
Lower left near the bottom tig work..... the AC pump manifold tubes ( thats what i am calling it )
Old 10-06-2012, 02:27 PM   #165
wutnxt
Not sure how mch of this process you all want to see.....But here is how it pretty much how the lines were laid out before crimping....I took them to a AC place to be crimped it was fast and was about 50 bucks for all the crimping washers and extra parts...
Old 10-06-2012, 02:33 PM   #166
wutnxt
Dash controls installed......
Let me tell you...they sure don't make those cables any longer then they need to be. If they were a inch longer each it would be way easier, you have to have someone hold the controls as the cables are connected or you with scratch off all your dash paint.....or at least tape off around the dash prior to install
Old 10-06-2012, 02:35 PM   #167
wutnxt
Dash and under dash controls installed....I might consider painting the under dash part to match the dash later on.....no sure just yet ow i feel about the black down there
Old 10-06-2012, 04:47 PM   #168
Kim57
Kim57's Avatar
Nice clean install.
Which VA unit did you get?
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-07-2012, 12:22 AM   #169
wutnxt
http://www.tbssowners.com/docs/2007tbss_ECM_pinout.pdf
Found the pin out at long last
Old 10-07-2012, 09:02 AM   #170
Lolyin58
Lolyin58's Avatar
Looking really good. There is just one thing....... I don't think u have enough lines under that big old hood Definitely looks like a plumbing night mare!!
Great work.
Old 10-12-2012, 01:35 PM   #171
wutnxt
Well i broke down and bought a new custom harness to run on my Computer.....will be here next week ....
Old 10-16-2012, 12:45 AM   #172
wutnxt
Well i need to post some new pictures....But i made my first carpet kit.....installed it ( it looks okay ) Installed all my new stereo which worked for aout 2 mins before the amp for the subs gave up the ghost. Brand new amp under warrenty just have to wait for it to be replaced.....But the 2 mins were wicked. Built a set of pods for upfront to mount a 6"& 4" and tweeter with a set of 12" subs for behind the seat. It will be pretty wicked when it's up and running again.
Old 10-16-2012, 08:43 AM   #173
Lolyin58
Lolyin58's Avatar
Sounds like there was about 2min of smiles. Can't wait to c pics!!
Old 10-16-2012, 02:59 PM   #174
Painter D
Painter D's Avatar
Nice to see youre making good progress, keep at it.
Btw sorry if i missed it somewhere , what radiator is that?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 10-16-2012, 10:28 PM   #175
wutnxt
It's a american eagle...I have used lots of them never a problem....it's a bit differnt the way it fits because i sunk it down more and pushed it towards the front more. It's designed to bolt right in..but the LS2 is a bit longer and i needed the extra room
