Old 02-01-2010, 01:03 PM   #176
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The upper frame rails are about 1.5" wider than later year trucks. Also the brake lines run inside the frame instead of on the outside. We should be fitting them on a 70 BB truck this week to make sure they will work with pre 72 motor stands. Stainless may be ready by mid summer.
Jokers69 is offline   Reply With Quote
Old 02-01-2010, 04:52 PM   #177
67chevemall
67chevemall's Avatar
Re: Header Solution
Originally Posted by Jokers69 View Post
You have great plug access.You can run straight boot spark plug wires on all cylinders but #6 it requires a 90 degree boot.
Ahhh # 6 There has been a few swear words directed at #6 over the years...
Sweet job on the headers.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-03-2010, 12:04 PM   #178
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Header Solution
Did you ever get the sbc headers with factory a/c flange, ball mount collector? Prices? Thanks.
70k52wd is offline   Reply With Quote
Old 02-05-2010, 08:23 PM   #179
70stroker
70stroker's Avatar
Re: Header Solution
ordered some of these today. cant wait to recieve them. Ill post when i recieve.
Steve is a very friendly guy. Prompt on callin me back as promised.
70stroker is offline   Reply With Quote
Old 02-08-2010, 10:50 PM   #180
AJs72K5
AJs72K5's Avatar
Re: Header Solution
Gonna bump this back up. Have the BBC's been test fit on a 4x4? How's the clearance on the front shackles, front driveshaft, and transfer case?
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 02-08-2010, 10:56 PM   #181
umwtnt
umwtnt's Avatar
Re: Header Solution
Subscribed for future reference
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 02-09-2010, 01:38 PM   #182
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
We have not found a BB 4x4 to test fit them on ( looking for one as we speak)
Old 02-09-2010, 01:41 PM   #183
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
We have not got an a/c bracket to replace the factory one for our headers yet.
Old 02-22-2010, 08:12 PM   #184
AJs72K5
AJs72K5's Avatar
Re: Header Solution
What's the word? Anything?
- AJ
Old 02-24-2010, 03:53 PM   #185
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Still looking for local stock 4x4 BB truck. Every truck I've found is to modified.
Old 02-24-2010, 07:46 PM   #186
70stroker
70stroker's Avatar
Re: Header Solution
if there is any local to the se kansas area i would be more then welcome to let them try my headers i bought from jokers on a bbc 4x4 truck before i install on my 2wd (its going to be a few months anyhow)
Old 03-13-2010, 05:08 PM   #187
Jeffs70
Jeffs70's Avatar
Re: Header Solution
awesome setup of headers it looks like.
Jeffs70 is offline   Reply With Quote
Old 03-14-2010, 02:55 PM   #188
Willys47
Willys47's Avatar
Re: Header Solution
So how did the test fit work out any did you take any pictures?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 03-19-2010, 04:04 PM   #189
70stroker
70stroker's Avatar
Re: Header Solution
These headers fit amazing on a 2wd bbc truck on pre 72 stands. I just installed mine heres a few pics.
Old 03-19-2010, 07:23 PM   #190
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Thanks For the pics Stoker.
Old 05-08-2010, 01:29 AM   #191
Dan 67 Chevy LWB
Re: Header Solution
Anything on the Stainless BBC headers yet?
Dan
67 Chevy LWB, Small Window - In the process of being rebuilt. Small Block is coming out & I'm gathering parts to switch to a Big Block 496.
Dan 67 Chevy LWB is offline   Reply With Quote
Old 05-17-2010, 02:14 AM   #192
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
We should be able to do BB stainless in about two weeks.
Old 05-19-2010, 03:29 PM   #193
Hart_Rod
Hart_Rod's Avatar
Re: Header Solution
Do you have any pictures of the small block header in stainless and powdercoating that are mounted? I have 383 with a vortech supercharger (631 TQ/622 HP http://67-72chevytrucks.com/vboard/s...d.php?t=370973), do you think these will help or harm performance? I currently have long tubes with 1 5/8.
Hart_Rod is offline   Reply With Quote
Old 05-23-2010, 01:36 AM   #194
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
I will try and see if I have pics of stainless in installed. I do have pics of coated installed and i will post asap. As for performance if you are running 1 5/8 primaries headers with a supercharger you should gain sum hp on the top end with 1 3/4.
Old 07-08-2010, 01:22 PM   #195
Clear Image (Dan)
Re: Header Solution
Hello everyone. I would like to introduce myself. My name is Dan Ferraro. I am the owner of Clear Image Automotive. I have been in business for over 10 years now. We specialize in GM vehicles and have been designing and building headers and exhaust components for specific vehicles. Our origin started with the 94 – 96 Impala SS. From there we branched off to the Chevy Cobalt, Saturn Ion, Pontiac Solstice, Camaro/Firebird, as well as the Corvette. Recently we have released products for the Chevy Colorado and GMC Canyon as well as the early Chevy trucks. We also build private label products for other companies in various other markets.
I have not posted to this forum before as I have left marketing of our products to one of your own. Our headers have been sold by Steve Kinney of Carb’s Unlimited & Performance. He posts here as “Jokers69” and is obviously the originator of this specific thread. I’m sure some of you are familiar with him as you have already received and installed our headers. Steve and I have discussed the advertisement possibilities on this forum and he has become a gold vendor. Recently another one of your members, “67-72trucks” posted a thread to try and drum up interest in our headers.
http://67-72chevytrucks.com/vboard/s...d.php?t=410104
He contacted me about “group pricing”. I explained what my requirements were but I failed to explain my relationship with Steve. Many of you have been wondering what happened, why Steve isn’t posting the sale, etc. The “GP” thread was posted specifically so I could see how much interest there actually is. Since Steve is one of my vendors, and he is also the owner of the shop next door, he will be handling the actual sale on this forum.
At this time I do not own a truck and am not capable of answering specific fitment and application questions. This is exactly the reason I am letting Steve do the marketing on this forum. I will continue to remain a member of this forum and will be here to support Steve and answer specific questions about our products; material, design, primary sizes, collector sizes, construction, finish work, etc.
I would like to thank “67-72trucks” for being so enthusiastic and for posting information and answers to many question about our products. I will work on the sale prices and we will the information for all of you tomorrow. Steve will post a new thread entitled “Header Group Purchase”.
I apologize for any misunderstanding. If anyone has any questions about our headers, exhaust systems, mandrel bending, etc, please feel free to ask.
Thanks all.
Warmest Regards,
Dan Ferraro
Custom headers, exhaust & intake systems
http://www.clearimageautomotive.com/
(425)251-0329
Clear Image (Dan) is offline   Reply With Quote
Old 07-09-2010, 04:51 PM   #196
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
BB headers are now available in stainless 304 with v-band outlets on collectors. $1095.00
Old 07-11-2010, 07:00 AM   #197
Dan 67 Chevy LWB
Re: Header Solution
What size V-band? What size ID"? do you have photos off the v-band and does it come with the clamp and other half?
Dan
Old 07-11-2010, 03:00 PM   #198
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
I will post pics of v-band setup asap. It will come with both sides and a clamp.
Old 11-03-2010, 01:43 PM   #199
Hart_Rod
Hart_Rod's Avatar
Re: Header Solution
Any pictures yet?
Old 11-03-2010, 10:49 PM   #200
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
No pics yet working on them now.
