Old 04-16-2010, 12:27 AM   #176
Captainfab
60-66 Nut
Re: My whole braking system - thinking out loud
I'll put your name on a set, and get them over to the powder coaters tomorrow. I'll send you a PM to work out payment details.
As for the proportioning valve, some guys are using the stock disc/drum one with success, others use the disc/drum with an adjustable in the rear line, and others run only an adjustable in the rear line. There is also the disc/disc proportioning valves. I would say it will somewhat depend on which calipers you use. If you're going with the Wilwood dual D52's, they recommend using the 1.5" dia piston models in the rear with the 2"up front to help maintain some of the braking bias. So I guess decide which calipers you are going to use and then we can go from there.
Originally Posted by skeeterbug View Post
I guess since i have read this very interseting post everyday since it was started by chuck, that means i have turned my wants into needs. captain fab sign me up for a set of the brackets powdercoated in satin black please. i am currently working on my braking system now anyways, do you know what prop. valve i will need, i have to replace mine anyways.
Old 04-16-2010, 12:42 AM   #177
Captainfab
60-66 Nut
Do you have an application for those rotors? It sounds like you setup and drilled the holes on a CNC? How long do you figure it took you to turn the original rotors into hubs? It seems like someone already makes aluminum hubs that will work on the truck spindles. I'll have to find them and see how much they are.
Originally Posted by 87chevy.com View Post
this is the front rotor setup I was mentioning earlier..
I must have been in a hurry and didnt double check the spacing in the autocad file becuase I drilled the frist patten to 5.25.. lol... these rotors are at minimum anyway, but the second pattern (shoulda been the 1st) was spot on.
and with the rotor turned upside down, you can see how it fits perfectly onto the stock replacment rotor and already has a bevel. For those who will notice the studs dont stick out much.. the stock rotor was not turned into a hub yet so the Dodge rotor was sitting down on the stock rotor surface.. I think the studs will need to be longer anyway
Weather permitting, I will be going to the pick and pull for a spindle nut and washer... Ace hardware didnt have a 3/4x20 nut, or castle nut... plus they want 5 bucks anyway.. then I will be able to snug everything down and start working on the caliper adapter bracket
clint
Old 04-16-2010, 12:55 AM   #178
SCOTI
SCOTI's Avatar
KORE3 makes billet alum hubs for C10's. They're very nice & were less than 4-bills.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-16-2010, 01:42 AM   #179
Captainfab
60-66 Nut
That's right, that was one of them. Thanks Scot. Chris Alston makes them too, but I don't know if they're available seperately. Are the KORE3 hubs available in a 5x5? The website just says the have a dual 5 x 4 3/4" pattern.
Old 04-16-2010, 08:41 AM   #180
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
No CNC here, just a lexmark printer, punch and hammer... I didnt turn the rotor into a hub just yet... I wanted to measure the runout of the hub, or see if there was any before I cut up a brand new rotor.
As far as the rotor its from a 2003 newer dodge ram 1500. As far as the new pattern I used a template I created in Autocad. Before I attached it to the face of the rotor, I got a pick and poked a small hole where the chevy pattern was (makes center punching it supa easy. I attached the pattern to the face of the rotor with some stuff called butyle aka dumb dumb (it's like sticky tack but for cars) and stuck it onto the face of the rotor. Turned it upside down and moved the pattern untill everything lined up. Silmply took a center pinch and hammer to mark the new pattern. Removed template and center punched the new holes a second time. Used a 1/8 bit to start with, then progressed to 17/32. Later I chosed 17/32 becuase it was a hair larger than 1/2 to give me a little wiggle room incase a hole was not 100% on the money. I will put a picture of the pattern I am refering to.
Clint
edit:
heres the screenshot of the pattern I whipped up... the ones with the (X) is the dodge, and the other... obvious.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-16-2010, 09:24 AM   #181
SCOTI
SCOTI's Avatar
They are available in dual patterns. Mine are 5x4.75 & 5x5.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-16-2010, 06:14 PM   #182
jasonb72
PorterBuilt Man Crush
True on the above
I have been talking back and forth with Tobin at KORE3 the last couple of days. I am getting ready to buy their kit with 14" front and 6 piston C6/Z06 setup and 13.4 4 piston on the rear. If you skip the parking brake it is actually a reasonably priced kit. I just need to make sure the calipers will clear my wheels.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 04-16-2010, 08:51 PM   #183
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by jasonb72 View Post
True on the above
How much are we talking about for rea$onably priced
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-16-2010, 09:41 PM   #184
87chevy.com
looking at kore3's site, its around 1100 bucks
http://www.kore3.com/proddetail.php?prod=10336-03
nice stuff but just out of the budget... plus that might be way too much brake for a normal truck...
Old 04-16-2010, 10:34 PM   #185
jasonb72
Granted I said reasonably priced..for what you get. I am looking at getting their complete kit as I described minus the calipers since I have a hookup for GM parts at cost. This will cost me 1500 plus whatever the calipers cost me, so I am hoping to be right at 2-2100 for the total cost.
I compare this against what I bought from ECE which was a 4 wheel disc brake kit all stock parts with CD&S rotors for $1500.
This means I get the bigger rotors and much much better calipers for around 600 more than the other kit cost me.
That is reasonable to me.
Old 04-19-2010, 06:32 PM   #186
lolife99
67-72 parts collector,…
lolife99's Avatar
Got my Captainfab D52 rear caliper brackets today.
Excellent quality product!
Thanks again for designing and manufacturing these brackets.
Keith
Convert to disc brakes.
Old 04-19-2010, 11:49 PM   #187
Captainfab
60-66 Nut
Thanks for the compliment Keith
I finally got a for sale thread started for these rear disc brake brackets HERE
Old 04-21-2010, 09:34 AM   #188
skeeterbug
skeeterbug's Avatar
looking forward to getting my captain fab d52 caliper brakets, my willwood calipers and disc/disc prop. valve came in sat via fed ex truck. i also went yesterday and got the rotors and a dual diapram booster to go on one of cap. fabs booster brackets. everything is painted and disassembled ready for an upgrade, i cant wait to see the difference manual brakes to four wheel power disc brakes make. lolife 99 did you get your lines yet, just wondering if anyone has figured that part of the process out yet? also what brake pads to use, hmmmm.....?
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 04-21-2010, 10:00 AM   #189
lolife99
lolife99's Avatar
I plan on using braided lines.
Any line that accepts a 7/16-20 banjo bolt will work.
Speedway Motors sells them in rubber ($39/pair) or steel braided ($49/pair) for a reasonable price.
Make sure you get D.O.T. approved brake lines.
Any stock D52 pad will work. (Same as the front disc brake pads)
Keith
Old 04-21-2010, 10:10 AM   #190
N2TRUX
Happy to be here
N2TRUX's Avatar
...Speedway Motors sells them in rubber ($39/pair) or steel braided ($49/pair) ....
Really? Makes you wonder why any one buy rubber if stainless is only $10.00 more. I guess thats for the retro builds.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-21-2010, 10:27 AM   #191
crakarjax
crakarjax's Avatar
Don't the rear brakes use hard lines?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-21-2010, 10:32 AM   #192
lolife99
lolife99's Avatar
Rubber:
Part# 617-8563 $39.99/set
(Includes banjo bolts, clips, and brackets)
Steel braided:
Part# 617-8562 (front 16" hoses) $49.99/set
Part# 617-8564 (rear 8" hoses) $49.99/set
Keith
Old 04-21-2010, 10:34 AM   #193
lolife99
lolife99's Avatar
Rear disc brake calipers require a flex line.
Ususally a steel line is mounted to the rearend housing and then converted to a flex line at each rear wheel.
Keith
Old 04-21-2010, 10:36 AM   #194
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for sharing the part #s Keith.
Normally yes. In this application they are using front calipers on the rear so it requires the same soft line.
Articles-
"Refining Sierra"
Old 04-21-2010, 10:41 AM   #195
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I might add that I found out the hard way that the front flex lines for a 67-72 are much shorter than those for a 73-87.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-21-2010, 03:16 PM   #196
suttoncurt
suttoncurt's Avatar
Wow - I just realized i screwed up! I ordered four of the same front caliper . For the back I need the one with the smaller piston ? I ordered from jeff and he said something about it but i thought he was talking about rotor width ? Can someone chime in on this - Thanks
suttoncurt is offline   Reply With Quote
Old 04-21-2010, 03:33 PM   #197
smashingchuck
Yes, you want the smaller bore for the rear.
78 Build Thread
4Runner Build
Old 04-21-2010, 03:53 PM   #198
suttoncurt
suttoncurt's Avatar
Thanks Chuck - Ill get in touch with cpp jeff and get it corrected!
Old 04-22-2010, 01:21 AM   #199
Captainfab
60-66 Nut
Your parts shipped out today. If you didn't get an email with tracking info, let me know. Thanks.
Old 04-22-2010, 07:24 AM   #200
skeeterbug
skeeterbug's Avatar
i got my smaller piston calipers (willwood) from jegs, i belive they measured 1.25 or 1.5, i know the front calipers measured 2.0. i will have to double check the rear calipers measurement to be certain
2013 best 7.39
2014 best-7.38
