11-03-2012, 07:39 PM | #176 |
Green club
Re: Let's see pics of paintjobs done yourself...
Here is a couple, BUT the HB gun is not exactly what I would suggest using for a decent finish, but it can lay clear down OK in the right conditions. In my defense I have a few cars I have painted under my belt, used quality material (chromabase Dupont) and got it to flow OK. In retrospect a nicer Devilbiss or a similar gun would be a worthwhile investment, and the final finish would have come out nicer.
I am in the middle of a complete on my son's 61 Continental and the HB gun is staying in the cabinet for this one. Primers maybe, topcoats no, the Devilbiss 'plus' is going to be my choice for the job but that is a $300 gun new its not cheap by any means. Thank you for the props on the truck, lots of sweat went into it
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
11-03-2012, 10:43 PM | #177 |
low n' slo
looks good from here...i only use mine for primer right now, i sprayed some single stage with it and it was real hard to tone it down. ill be getting a new gun for the basecoat.
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
11-10-2012, 06:19 PM | #178 |
My candy painted firewall!!! Hok apple red candy over black!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
11-11-2012, 08:05 AM | #179 |
Looks great. Normally if you spray a candy over black, you don't see the candy. Sure that's not a black metallic or a charcoal metallic?
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
11-11-2012, 08:24 PM | #180 |
Apperantly my phone turns pictures sideways for no reason... Fixed it!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 11-11-2012 at 08:30 PM. |
11-11-2012, 08:29 PM | #181 |
Yup 100% because the base is off a 98 mustang black as black can be. The actual uk11 (urethane kandy) has to be over a metallic or pearl base because there is no metallics or pearls in the midcoat on a tri coat paintjob. This hok paint uses a shimmering basecoat and adds stuff to it to make it close and its very close!!! I unwrapped it and started painting some of the accesories to match the motor but here it is unwrapped!
Posted via Mobile Device Posted via Mobile Device
11-12-2012, 10:12 AM | #182 |
5 long months, but I finally got mine painted
Sanded the the body, got it ready for some primer 1st coat of Epoxy primer Sanded to find high and low spots, then filler work Second coat of epoxy A good coat of Polyester primer (feateherfil) Block sanded 4th coat of epoxy primer Block sanded again Epoxy mixed up as a sealer coat Base coat Finally Clear! All products were from Southern Polyurethane! |
11-12-2012, 10:44 AM | #183 |
Mine is in the process now. My first paint job.
11-12-2012, 10:57 AM | #184 |
Nice job PD1292, what color did you use?
Scott |
11-12-2012, 11:14 AM | #185 |
It is called Heritage Blue, its on the new 2013 GMC Z71 heritage edition. I think it is also an older color called blue topaz or lemanz blue, or zenon blue. It has been on I think the 04 chev pickups, on some corvettes and on cadi cts. I saw it on a dealer custom at a local car lot and got the paint code off of it.
and thanks sduckworth Last edited by PD1292; 11-12-2012 at 11:43 AM. |
11-13-2012, 03:17 AM | #186 |
Done this one back in 2001.Thought it was going to just get by and it has stayed on for 11 years now.Sherwin Williams brand. 2nd line.single stage.
11-13-2012, 03:21 AM | #187 |
didn't list first time
11-13-2012, 10:59 PM | #188 |
Wow mrhino & paws those look great!
Posted via Mobile Device |
11-14-2012, 09:26 AM | #189 |
11-18-2012, 09:30 PM | #190 |
heres one from last spring
1966 C10 short stepper KMHK |
11-18-2012, 09:34 PM | #191 |
one from this spring
11-18-2012, 09:35 PM | #192 |
and my 66 short step side im currently building
11-27-2012, 01:11 PM | #193 |
My son and I have been working on her for 3 years. It's finally close to complete. PPG DBC 2000 Synergy Green. Sprayed with an Iwata 400. My son did all the body and paint work.
11-29-2012, 07:09 PM | #194 |
This is my 99 s10. It was sprayed with all Dupont products. It started with 2590s epoxy primer then 4 coats of 7707s surfacer. After being blocked with 320 dry then 500 wet, it was shot with 1 coat of 7770s sealer, 3 coats of a custom mixed chromapremier basecoat, and cleared with 2 coats of 74700s chromapremier pro clear. The following day everything was wet sanded with 800 then 1000 and sprayed with 2 more coats of clear. I should have washed it before I took the pics
11-30-2012, 12:21 AM | #195 |
Did all the metalwork, bodywork and cut-ins at the house shot in the booth at the shop my brother manages, cut and buff and assembled at home. Did it all right down to the color matched bedliner!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-30-2012, 03:59 AM | #196 |
too many to post, so http://www.ifitsgotwheels.com/pictures/
enjoy |
11-30-2012, 05:25 PM | #197 |
Finally I can post here. My dad and I just finished up the suburban, was done in the garage.
12-02-2012, 10:48 AM | #198 |
Heres one I restored last year
12-02-2012, 12:30 PM | #199 | |
I love that color..I painted a Suzuki gsxr synergy green this summer.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
12-02-2012, 12:31 PM | #200 | |
NiCE suburban...
