Old 04-23-2014, 10:50 AM   #176
Kim57
Kim57's Avatar
Re: My 1959 Fleetside Build
Nice stance.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-25-2014, 12:31 AM   #177
pbeguy
pbeguy's Avatar
Steering wheel mocked up. Love the old wheel. Waiting on column drop bracket.
Bag switches installed in dash. Air lines tucked inside dash area.
Under hood stuff getting close.
pbeguy is offline   Reply With Quote
Old 04-25-2014, 06:58 AM   #178
Spblack
Spblack's Avatar
Originally Posted by pbeguy View Post
I keep expecting you to drive up one day in yours.
Lets do a convoy to Hoedown on May 24th in Hempstead.
I wish I was that close. I still have to tear it back down to the frame after I am finished with mock up. ill follow yall up there on my bike, lol.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 04-25-2014, 01:22 PM   #179
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 04-25-2014, 02:14 PM   #180
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Man you build some cool rides!
ChuckDriver is offline   Reply With Quote
Old 04-29-2014, 10:21 PM   #181
pbeguy
pbeguy's Avatar
Started on the wiring today. It is a 21 circuit kit. It is like swimming in spaghetti.
One wire at a time.
My son sent me this link of Wes Drelleshak's youtube video and it inspired me.
https://www.youtube.com/watch?v=Ke_9...ature=youtu.be
Pickup Power / Big Muscle
Old 04-30-2014, 10:07 PM   #182
pbeguy
pbeguy's Avatar
This last Saturday I was turning my engine over checking for TDC and kept hearing an intermittent scraping noise. I looked under the truck and noticed I had a dent on the front of my oil pan. Must have been the three or nine times I took the engine in and out. I decided to order a new oil pan and now I am glad I did. Rod 1 or 2 was definitely hitting the pan. My new pan is chrome and looks and fits great.
Disaster averted. It would have rubbed a hole in it.
Old 04-30-2014, 10:36 PM   #183
Kim57
Kim57's Avatar
Nice to find that out before it got any worse.
Kim
My build thread
Old 05-04-2014, 10:30 PM   #184
pbeguy
pbeguy's Avatar
Hooked up my battery and spun the engine over today. It was pushing oil through the lifters and sounded great. I am going to do my best to get it running this week.
Got a lot more wires sorted and run. Even if it is not pretty right now it will be neat and orderly. I got the brake lines run from the master cylinder. I still need to install the adjustable proportioning valve.
Old 05-07-2014, 11:30 PM   #185
pbeguy
pbeguy's Avatar
The UPS guy is becoming my best buddy. I got a good price on a GREAT shifter. I love the look and feel of it. I can finish my floor now that I know where the shifter sits.
Old 05-08-2014, 10:46 AM   #186
Kim57
Kim57's Avatar
That's nice.
Kim
My build thread
Old 05-10-2014, 09:15 PM   #187
Rednek13x
Rednek13x's Avatar
sent you a PM pbeguy!
Rednek13x is offline   Reply With Quote
Old 05-11-2014, 12:08 PM   #188
pbeguy
pbeguy's Avatar
Rednek13, if you look at post 18 here you can see how I did it. I will warn you it adds a host of issues to your list. You have to figure out how to attach the frame horns if you use the stock ones. It puts your power steering unit in the way of the radiator. I shifted my radiator over about an inch left. You have to cut the floor and firewall a lot. If you use the stock brake unit there are issues with your tranny crossmember. This method is not for the faint of heart.
Old 05-11-2014, 08:43 PM   #189
Rednek13x
Rednek13x's Avatar
are you tunneling your cab floor? And stock break unit as in the master under the cab bolted on the frame rail? I was not too sure what i am going to do there, i want to run power brakes and mount in the same general location. I think the most difficult part for me will be tunneling the floor, but willing to try!
Old 05-11-2014, 10:20 PM   #190
pbeguy
pbeguy's Avatar
You do not have to tunnel the floor. You can see how the tranny comes up and it will need a hump in the cover. I am thinking the factory tall hump big truck unit will work ok. I did notch the rear of the cab but I am laying body on 31" tires. If you rears are not that tall you will not need to cut it like that.
Actually, if you are not putting huge tires on the front, it might not be worth the PITA you are going to go through to do it this way. I only did it to clear my chosen wheel/tire combo.
Old 05-13-2014, 03:25 PM   #191
Rednek13x
Rednek13x's Avatar
For now my tires are going to be 27.05" total height. But probably get bigger wheels down the road, i think they look better... Still debating what way to do it, getting a plasma cutter Wednesday so need to make up my mind by then.
Old 05-13-2014, 10:29 PM   #192
pbeguy
pbeguy's Avatar
For the record, I could literally run stock spindles and airbags and still lay the body on the ground. I am running 265/40/22's on the front which are about 30" tall.
Old 05-14-2014, 10:53 PM   #193
pbeguy
pbeguy's Avatar
Started and ran the engine tonight. Started on first try. I am excited.
It has a nice little lope to it.
Old 05-15-2014, 12:07 AM   #194
NDWEEDS
Ok, so I was planning to recess the horns of the clip into the frame as you did but I have concerns about clearance issues with a big block and 700R4. However, after reading your thread, maybe it's not necessary to go this rout in order to lay frame, or body in this instance. You mentioned that with the rockers on the ground, you still had 1.5" of lowering available in the suspension. 1.5 is about the amount you gain be recessing the clip horns. Therefor, it might be best to simply weld the clip to the bottom of the frame and avoid potential clearance issues with the drive train. Would you agree?
Nice build by the way. I played hell finding a Fleetside bed (by itself) here in AZ that was worth a darn. And I had to pay a pretty penny only to find out it was rougher than originally thought after having it blasted.
NDWEEDS is offline   Reply With Quote
Old 05-15-2014, 08:03 AM   #195
pbeguy
pbeguy's Avatar
NDWEEDS,
I would agree with that.
If you are running standard size wheel/tire combo the regular way is fine. I was just looking to make an oversize set work for this truck.
Old 05-15-2014, 09:50 AM   #196
NDWEEDS
Yeah, I'm going a more traditional rout when it comes to wheel and tire size, about 27" overall.
Old 05-18-2014, 10:38 PM   #197
pbeguy
pbeguy's Avatar
Got my steering finished today. With the angle of my clip, my steering rod is almost flat. The one u-joint turns smoothly with no binding and I do not think I will need any other support. On a side note, this Camaro unit is lock to lock with 2 full turns. I am used to more rotations so I assume this was a quick ratio box.
PS the nuts holding the crossarm on my upper a-arm are temporary. No snappy remarks necessary.
Old 05-18-2014, 10:42 PM   #198
Spblack
Spblack's Avatar
looking good larry. almost done
My builds:
Old 05-19-2014, 12:10 AM   #199
59stepside
59stepside's Avatar
Just read the whole build. Your doing a great job on the truck. I will be following the rest of the build...
USCG Aviator
C-130
1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386
59stepside is offline   Reply With Quote
Old 05-19-2014, 09:53 AM   #200
Kim57
Kim57's Avatar
Steering looks nice and clean.
Kim
My build thread
