07-03-2013, 06:34 PM | #176 |
Junk Yartist
Re: project pacific wonder
cant wait to hear how she travels, and mileage! Well done!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
07-24-2013, 06:37 PM | #177 |
Cool build, very nice.
07-29-2013, 10:25 AM | #178 |
Could you point in the right direction to look at your engine? I may have candidate for a 4BT, at least I can dream of it.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-01-2013, 09:26 PM | #179 |
My machinist found it for me down in california....
Chuck |
08-01-2013, 09:27 PM | #180 |
Good news....the beast is finally road ready...bad news is im out of town for a week....i will pick it up next wednesday or thursday... ..stay tuned!
Chuck |
08-13-2013, 10:23 PM | #181 |
I picked it up last week and was so frustrated i nearly thought about selling it!!
The battery was not charging- i found the alternator did not have 12v to the voltage regulator so it wasnt charging, the starter had abad wire crimp that kept popping out and another extremely loose connection. There is a fuel leak on a vent from the injector pump the dakota digital tach interface is not working Pyrometer switch was loose The heat valve for the AC/heat was installed backwards, the ground for the AC switch was removed. I have been a little busy and all that is left from this list is the fuel leak and tach issue.
Chuck Last edited by Coboyle04; 08-13-2013 at 10:29 PM. |
08-13-2013, 10:35 PM | #182 |
no mileage updates for you yet but maybe by the end of the month.
I still need to tighten some other bolts, install the hitch, charge the AC system, anchor some parts that are vibrating excessively, wire the grid heater, get rear shocks measured, install tow hooks, adjust a couple trim clips, have the doors re-aligned, some paint fixed, tint fixed in 2 windows, install a cage on the trans cooler. i was also thinking about a trans tempt gauge. I am also having a hell of a time finding these mirrors. i have found some but the legs are either too short (10") and narrow or way too long. any help would be greatly appreciated!
Chuck |
08-13-2013, 10:36 PM | #183 |
Chuck |
08-13-2013, 11:08 PM | #184 |
I had a V-8
I think those are early mirrors. The shorter legs are the ones that are correct for the '72. They tie into the door at the top just below the trim piece and the lower legs are shorter (like the ones on my Sub). They use the same mirror head. PM tkorinek. He probably has either variety and others not mentioned here.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
08-31-2013, 04:16 PM | #185 |
I found some mirrors. aparently these ones were only made for about a year between 69 and 70.
Chuck |
08-31-2013, 04:37 PM | #186 |
Time for some updates.....
AC is functioning great i have one mirror installed and waiting for some more well nuts to show up to do the passenger mirror. i have fixed all of the leaks and mounted my hitch. During the troubleshooting of my charging system i had my battery load tested (rated at 930cca) producing over 1500cca. The tac hasnt been finished yet and i am awaiting a new speed sensor I upgraded the old tailgate supports We drove from portland area to bend. on the trip out we averaged about 22mpg and on the way home about 26mpg.
Chuck |
09-01-2013, 09:44 PM | #187 |
Nice build!
09-02-2013, 03:13 AM | #188 | |
I had a V-8
It's nice to finally use it instead of just incessantly working on it. Congrats!!
09-03-2013, 12:11 PM | #189 |
pyro gauage was reading between 6-800 most of the trip more when i was on a steep climb, lots of elevation change. the santiam pass is nearly 5,000ft elevation. sherwood where we starter is about 500ft. sisters and bend area are about 3,00ft. power was great. I am interested to see what MPG i get around town and maybe down a longer I-5 trip.
And these are the motor mounts i am running right now.
Chuck |
09-07-2013, 01:44 PM | #190 |
2WD Jimmy
That Burb of your is freakin Awsome!! if I do say so
09-09-2013, 11:51 AM | #191 |
thanks tom!
the aftermarket door seals i purchased wont hold any adhesive....just ordered the Press on door seals from GMC paul. cant wait to install them
Chuck |
09-12-2013, 02:20 AM | #192 | |
I had a V-8
I am very interested to hear how the press-on seals work out for you. Maybe do an install overview and review?? I'm not thrilled with my door seals on the front doors (A&M Soffseal). The rear door has Precision weatherstrip and I like that a lot more, but I am interested to hear how you like the ones from GMC Paul.
09-12-2013, 11:49 PM | #193 |
those are from classic parts, and i am also experiencing deterioration on the anti rattle kit after a couple weeks where my arm rests on the rubber portion (apparently GMCpauls anti rattle kit is way better also) i might be ordering those soon as well
Chuck |
11-04-2013, 09:33 AM | #194 |
Amazing build!
Do remember if the 2WD and 4WD frames were the same? I cant really tell from the pictures. I'd like to do something similar but my 4WD frame has more rust than the 2WD frame. Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
01-10-2014, 06:25 AM | #195 |
Great build! Awesome truck! Any word on gas mileage yet, I was thinking of putting in a 4bt as well.
There's no point in buying new. 1977 K20, Full time 4x4 (Engine Blown/Project) 1985 Buick LeSabre 2003 Kawasaki Vulcan 800 2003 CBR 600RR |
01-10-2014, 09:51 AM | #196 |
Wish to know more about the 4BT and custom 47RH ..?
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
01-10-2014, 08:23 PM | #197 |
6>8 Plugless........
Nice work on your swap! It looks and sounds great!
Goldenburb, if you use a 47rh trans, you can bolt it to a 4bt by using a 94-02 6bt 5.9 dodge cummins adapter plate.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-11-2014, 01:35 AM | #198 |
I dont fully recall and my photos didnt capture it i will have to check
Chuck |
01-11-2014, 01:36 AM | #199 | |
I dont have a working tach yet so hopefully as the motor breaks in and i get the tach working i can better manage fuel consumptions
Chuck |
01-11-2014, 01:36 AM | #200 |
what can i tell you about it?
Chuck |
