06-18-2017, 04:11 AM | #176 |
Re: project orange crush 76 crewcab build
So close to finished
06-18-2017, 04:16 AM | #177 |
Door back on
08-03-2017, 12:15 AM | #178 |
Haven't done much too the truck lately it's monsoon season so every time I wanna work on it it wants to rain. I got the driverside pretty much all finished up. Took the cowl panels too work and stripped them to bare metal and epoxy primed them. Cut out a filler panel for the driver side kick panel vent hole and I filled in the hole in the trans tunnel cover. Hopefully I'll get started on the pass side floor soon.
08-20-2017, 03:44 AM | #179 |
Got started on the pass floor this week.
08-20-2017, 03:47 AM | #180 |
The inner rocker was in better shape than the driverside so I didn't need to replace the whole thing just a section of it.
08-20-2017, 03:51 AM | #181 |
This pass side floor pan didn't fit well at all. Took allot of massaging to get it flat against the supports and close enough to weld.
08-20-2017, 03:56 AM | #182 |
Finally the end is in sight! I'll get the outer rocker trimmed and fit tomorrow and welded on then I can weld the cowl panels back.on and start bodyworking the firewall finally can't wait to get all this metal work done so I can get some color on this and install my ls swap
08-20-2017, 04:05 AM | #183 |
Here's a parts blazer that Ive had and finally got it cut up and have been playing around with some yard art idea's. Thinking this would look cool mounted against my wall or maybe even incorporate it into my gate not sure what the end goal is just yet but when the weather cools down I'll get back too it.
08-27-2017, 03:38 PM | #184 |
Got the rocker and cowl welded up. Ground down all the welds and got some primer on everything. Rehung the door with the rebuilt hinges and got it all mocked up for now. Still need to finish the driverside cowl then I'll get that side in primer and start bodyworking the firewall and rockers
08-27-2017, 03:44 PM | #185 |
Looks good in primer
08-28-2017, 02:37 AM | #186 |
Mocked up the fender for the first time in over a year kinda nice to see it looking like a whole truck again. Also picked up a door for the yard art project.
08-28-2017, 01:04 PM | #187 |
Nice job. Been watching what you do since I'm trying my hand at replacing my rockers and floors in my c30 shortly. Thanks for all the pictures.
09-23-2017, 12:59 AM | #188 |
09-23-2017, 01:18 AM | #189 |
Got the driverside in epoxy and 2k primer then I hung the door and fender again to check fitment
09-23-2017, 01:29 AM | #190 |
Just about totally gutted time to start the bodywork on the firewall, rockers and get everything in primer and ready for paint.
09-23-2017, 01:37 AM | #191 |
So heres my newest project to flip. I was browsing facebook sales and this was posted for 1k so I messaged the seller and was on my way. I got there first with cash and it was ment to be so here's my new 75 Chevy c20
09-23-2017, 01:43 AM | #192 |
Gave it a wash and put two of my torque thrusts on to move it gotta say this truck sure has alot of potential
09-23-2017, 01:54 AM | #193 |
Theres no drivetrain but ive got a 350,th400 that im going to install in it. The interior needs work but its all there. I'll post updates on this one as I work on it
09-25-2017, 12:14 PM | #194 |
That is a good find for a flip. A little work and you should make a nice profit.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
09-25-2017, 03:38 PM | #195 |
6>8 Plugless........
Very nice work on your crew cab, and nice score on the 75! That will make a nice truck with a little bit of work. Like daddyjeep said, it should yield a very nice profit!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-06-2017, 07:46 PM | #196 |
10-06-2017, 07:47 PM | #197 |
10-06-2017, 07:50 PM | #198 |
Got the passenger side all sanded and primed
10-06-2017, 07:56 PM | #199 |
Bodyworked my driverside fender. It's ready for primer and block sanding rounds now. My pass side fender needs some rust repair and is in rough shape overall still unsure if I should put the time into this one of find a better replacement
10-06-2017, 08:41 PM | #200 |
Looking nice! I'm not sure on the fender. If you can find a nicer one close to you then getting a different one would work. But my luck you can't find any near me so I'd spend the time and fix it. Haha
