Old 05-22-2015, 12:35 AM   #1
520-k5
520-k5's Avatar
project orange crush 76 crewcab build
Project orange crush
here's my 76 c20 crewcab 350,4 speed 3+3 that i picked up in February from the 2nd owner. Plans for it are shortbed conversion, 4/6 drop, keeping it 8 lug, completely redo the interior, paint/body work, auto swap and later down the road ls swap,overdrive. This will most likely be a slow progress build over the next couple of years. here's how it looked as I bought it
520-k5 is offline   Reply With Quote
Old 05-22-2015, 12:38 AM   #2
520-k5
520-k5's Avatar
Re: project orange crush 76 crewcab build
Interior was in pretty bad shape but all complete and other than a battery splitter unmolested underhood.
Old 05-22-2015, 12:43 AM   #3
520-k5
520-k5's Avatar
So fast foward here a few months I started to buff the orange paint to see if it would shine and sure enough there's still some life left in it. I still have the roof,white and bottom to do but the upper orange is mostly buffed out.
Old 05-22-2015, 12:46 AM   #4
520-k5
520-k5's Avatar
It now has HD wheels and fairly new tires. And the quadrajet took a dump so i rebuilt an old carter 625 carb I had and topped it off with a cheap edlebrock aircleaner.
Old 05-22-2015, 01:00 AM   #5
520-k5
520-k5's Avatar
Pics
Old 05-22-2015, 01:05 AM   #6
520-k5
520-k5's Avatar
Since the interior needed major work I picked up a better dash pad and dash mat. Painted all the door panels and headliner trim. Bought new window cranks, picked up some nice seat belts and had the seats Reupholstered.
Old 05-22-2015, 07:02 AM   #7
walkerb
walkerb's Avatar
Nice work and truck
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 05-22-2015, 09:39 AM   #8
travlinman
Looking good. What did u use to clean/paint the interior? Color? I need to do mine soon.
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 05-22-2015, 10:07 AM   #9
rajincajintj
those seats look great.
76 c30 3+3 Camper Special - 12V 5.9l 6BT Cummins and 47RE
rajincajintj is offline   Reply With Quote
Old 05-22-2015, 11:08 AM   #10
520-k5
520-k5's Avatar
I used dish soap and a scotch brite pad to clean the door panels and trim. Then just rattle can valspar paint from lowes. I can get a pic of the can and color for you later.
Old 05-22-2015, 11:11 AM   #11
520-k5
520-k5's Avatar
Old 05-22-2015, 11:12 AM   #12
520-k5
520-k5's Avatar
Originally Posted by walkerb View Post
Nice work and truck
Thankyou
Old 05-22-2015, 01:47 PM   #13
Eyegore
What Hump?
Eyegore's Avatar
Nice looking rig, nice job on what you have done so far. Will you be adding AC especially for the Old Pueblo. With the way it looks I would keep it stock since their are not to many running around like that. But just my opinion.
Keep posting!!!!
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-22-2015, 02:11 PM   #14
520-k5
520-k5's Avatar
Yes ac is definitely on the list of things to do. I'm not looking foward to 110+ days on leather seats and no ac. I just haven't made up my mind on whether or not I want to peice together a factory system or just buy the vintage air kit. From what I've researched the vintage air kits flow alot more air than the factory systems can anyone confirm this? Thanks
Old 05-22-2015, 02:19 PM   #15
greg64
greg64's Avatar
Nice truck and great looking seats.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 05-25-2015, 11:28 PM   #16
520-k5
520-k5's Avatar
Got the dash pad,dash mat and bezal all back in this weekend. Also had it on the lift checking things out and changing the oil. I didnt do much this weekend but it's getting there. Hopefully within the next week or two I'll start the shortbed conversion
Old 06-13-2015, 09:51 AM   #17
520-k5
520-k5's Avatar
Well yesterday I dove into the tear down. I sold my longbed to a friend who sells at some of the major swapmeets back east. Pulled the bumper and saddle tanks and got it ready to measure.
Old 06-13-2015, 09:56 AM   #18
520-k5
520-k5's Avatar
Few pics of it without the bed. And got the frame cleaned of all the dirt and rust in the front.
Old 06-13-2015, 10:05 AM   #19
520-k5
520-k5's Avatar
Next i cut the rivit heads off that held the tailpipe support bracket and got that out of the way. Then we got the frame stripped to bare metal. So we could lay out our measurements.
Old 06-13-2015, 10:21 AM   #20
520-k5
520-k5's Avatar
I've read just about all the threads online that I could find. After alot of speculation on measuring 6" back from the rear cab mount it put the line right on the rear edge of the front bed bolt hole so we decided to mark 7" back and start there.then we measured 14" back and layed out our lines. We did a z cut method with 7" on each side of the z and a 4" height on each as the frames 8" tall. We used 3 cutting methods started out with the plasma cutter until the tip burnt out and being late at night and no replacement we decided to finish with a 41/2" cutoff wheel and a sawzall. Gotta thank one of my best friends ed port for setting time aside in his busy schedule to let me use his shop as well as help me out with this project.
Old 06-13-2015, 10:32 AM   #21
520-k5
520-k5's Avatar
And with the z cut we set the frame back together and called it a night. There's a little clean up work to do before we weld it back together and we're going to fish plate the inside of the frame. More photos to come later on today stay tuned.
Old 06-13-2015, 11:01 AM   #22
520-k5
520-k5's Avatar
Old 06-13-2015, 04:41 PM   #23
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Wow looking good looks like you did dive in head first. Great job on it so far going to be an awesome truck to cruise in when you get it all done and put back together.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-13-2015, 04:54 PM   #24
Average Joe
Average Joe's Avatar
Cool project! I had a chance to purchase a clean 2wd cclb 3 months ago for 2k. Factory 454 with TH400 and AC. I kick myself for not buying it, especially after seeing yours. Nice work!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-17-2015, 10:09 AM   #25
520-k5
520-k5's Avatar
So after a long weekend and many late nights I'll start with were I left off. We came in Saturday morning to realize we only cut 7" out of the frame duh. So then we marked another 7" which ended up giving us a straight cut at 14" and not a z cut. So in all the confusion we decided to z cut another 3.5" thinking our centerline would stay the same. Long story short I ended up cutting all the rivits out of the spring hangers,shock mounts and brake line bracket and rolling the axle back 3.5 inches. It created another day and a half of work for me but lesson learned. If you never make mistakes how will you ever learn from them right? So with that said I know have a crewcab shortbed with a 150.5 wheel base.
