Old 10-08-2008, 01:04 AM   #201
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 66 slammed hearse
yeah thats one of the things that I always said I would do for the 56, and never did, which was to buy 15/20 filters and 5 or so sets of points, in case they quit making them.
Old 10-09-2008, 12:17 AM   #202
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
might not be a bad idea Jon, I think I am going to try the stock filter etup again and see if it will seal up.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 10-10-2008, 12:39 AM   #203
Captainfab
60-66 Nut
This may sound dumb kd but did you remove the aluminum piece from the block that is used with the canister filter? (I think it has the bypass in it) It sounds like there is something up there keeping the O ring from sealing. And as was previously mentioned by soba_03, do you have the correct spin on filter for it? IIRC those use a F*#d filter.
Old 10-10-2008, 07:20 AM   #204
soba_03
soba_03's Avatar
Well I hope that you get it or got it resolved. You could do like they used to do and just change the oil regularly. My 235 in the Burb had either option, it had a remote canister or just a plug in the block. If you didn't have a canister you just had to change your oil a bit more often. It would allow you to drive it till you could concieve a fix.
Just a thougth..although not the best one....
soba_03 is offline   Reply With Quote
Old 10-10-2008, 04:20 PM   #205
sweet70beast
sweet70beast's Avatar
Derric I was digging around my junk and found these for you.
[IMG][/IMG]
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 10-10-2008, 09:07 PM   #206
kdrodworks316
KOFFIN DRAGGER
Sweet!
Old 10-10-2008, 09:10 PM   #207
kdrodworks316
KOFFIN DRAGGER
and yes I did remove the stock bypass, I am going to reinstall the stock canister and try that. It does have the correct filter, it dont leak where the filter meets the adapter, just at the block.
Old 10-10-2008, 11:14 PM   #208
PrerunnerRob
PrerunnerRob's Avatar
Before you give up on this, you could try some loctite 515 sealer on all of the machined surfaces and o-rings. Everything must be super clean and dry! I use this stuff at work on chilled water equipment to take up any remaining leaks in the o-ring seal on the refrigerant side of the machine. These things get leak checked to 500 microns(almost a perfect vacuum, around -60lbs or 30 inches of mercury) and this stuff seals up any imperfections. I don't see why it would not work on your seal if it is an o-ring, but if it is a flat rubber gasket, it may squish out when you start tightening it.
PS-If you are not sure if you have the right stuff, it is purple and kind of smells like grapes....seriously!(you will keep smelling you fingers, no matter how disgusted you are by the smell) Should be available at most HVAC supply places, or they can point you in the right direction.
Here is what it looks like:
http://www.all-spec.com/1/viewitem/5...=yahooshopping
PrerunnerRob is offline   Reply With Quote
Old 10-11-2008, 06:16 PM   #209
kdrodworks316
KOFFIN DRAGGER
thanks rob, I will look into this stuff. I am going to change back to a canister till I get this adapter figured out.
Old 10-11-2008, 07:29 PM   #210
msgross
msgross's Avatar
I tried one of those spin-on adapters on my 68 sbc and it leaked as well... after making a mess I just switched back to the canister... advanced auto had them in stock..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-14-2008, 12:44 PM   #211
clean cut creations
I have included some pics of the build but all the pics can be found here: http://www.cleancutcreations.com/crdel.html
Don't tell me what you're gonna do...SHOW me what you've DONE!!!
Click here for the TRUTH...
clean cut creations is offline   Reply With Quote
Old 10-14-2008, 02:35 PM   #212
suzq044
Resident Photoshop Nerd
suzq044's Avatar
no offense, but wouldn't this be considered spamming the thread? You've already made your own thread. I thought this was going to be an update of the "Halfway-Hearse"
PJ - 1966 C10 Panel --
Max² - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline   Reply With Quote
Old 10-14-2008, 08:22 PM   #213
clean cut creations
I didn't post on this thread to step on toes. I just saw it as the same type of project and thought it would be an ok addition . I will delete if this is a problem.
Old 10-14-2008, 10:48 PM   #214
Captainfab
60-66 Nut
This may be a bit late kd, but I just thought of something. Could it be possible that the bolts that came with the adapter are just a hair too long? If so they would be bottoming out feeling like everything is tight, but in reality not compressing the O ring.
Old 10-18-2008, 01:26 AM   #215
kdrodworks316
KOFFIN DRAGGER
Your pictures are welcome on my thread Clean, thanks for posting them. We just look out for each other on here...Thanks Suzq. And yes I did think about that captain, While I was truckin this week it run through my mind, I am going to check it out tomarrow.Oh by the way John, I almost run over you today (oct 17) at the top of 4th of july and you didnt even wave at me as you flew past, and I need your phone number again, I've lost it again. That goes for Runninlo and Jonzcustomshop as well, I have lost all of your numbers again due to a network switch on my phone.
Now for the hearse update...I am going to soda springs ID in the morning to pickup the new engine and tranny doner, 454 cubes and a th400 for now till the 348 comes off the stand and goes between the fenders. I acquired this rig with the help of 70sweetbeast and we are splitting this one, for the smokin deal of $200 for the whole truck. I am not sure if this engine will go in the burban or not at this point, maybe the next project? Also the hearse has been hired by the local chamber of commerce for a spook alley/trunk or treat deal from oct 20-31. All it has to do is show up and look scary, so I have to get some things wrapped up and install the cool, spooky lighting kit I got from runninlo. I will get some pics tomarrow, well 70sweetbeast will, but ya'all will get fresh pics on saturday. I cant wait to share all of my (and dont forget all my friends that have been a huge help, thanks guys, couldnt do it without ya)hard work and ideas with ya'all.
Old 10-19-2008, 01:25 AM   #216
kdrodworks316
KOFFIN DRAGGER
well I cant upload any pics for some reason. maybe later
Old 10-19-2008, 07:42 AM   #217
soba_03
soba_03's Avatar
Did you get the BBC? Keep waiting to hear that you got the whole oil problem squared away..LMK I'm interested in what you found....Enjoy the fall .. it's the best time of the year...
Old 10-19-2008, 04:34 PM   #218
kdrodworks316
KOFFIN DRAGGER
I did get the BBC, I havent got it pulled out of the doner yet, but I do have it. I am planning a full rebuild with a mild hot rodding. I never solved the oil problem, mainly due to lack of time. I will be working on it later today, switching back to the canister filter. I talked to the parts guy that sold me the adapter and he is ordering a new one and will trade it out in hopes its a faulty part.
Old 10-20-2008, 12:03 AM   #219
Captainfab
60-66 Nut
Originally Posted by kdrodworks316 View Post
Oh by the way John, I almost run over you today (oct 17) at the top of 4th of july and you didnt even wave at me as you flew past, and I need your phone number again.
You know Derric, I saw the truck and was wondering if it was you, but I didn't remember your KW having the bull bar on it. Sorry I didn't wave....I was in a hurry to pickup some 35's for my '68 over in Pinehurst and get back to work. I'll pm you my number.....
Old 10-20-2008, 02:04 AM   #220
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Originally Posted by Captainfab View Post
, but I didn't remember your KW having the bull bar on it. .....
it probably didn't but you know how "truckers" are when it comes to blingin accessories such as chrome and lighting
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 10-20-2008, 02:05 AM   #221
kdrodworks316
KOFFIN DRAGGER
ok, I figured out why this thing leaks oil like an excited puppy on halloween. The lil rubber o-ring keeps getting a wowee in it and dont seal. I tried again tonite to reassemble this thing with such care as if I were performing brain surgery, and......it still leaks! I am going to use this adapter as a $20 frizbee and huck it in the next county and go back the the original filter setup. I will only be running this engine thru the winter and spring anyway, till I get the 348 or the 454 built and ready to install.
I also got my plasmaglow kit installed, and wow is that the icing on the cake! it gives a really creepy glow from under the truck in about 10 colors and flash sequences. My grafics guy also cut me some super custom landau bars and I got them stuck on till my future ex-wife gives me the real ones. I hope to get some pics up asap, but I have had alot of problems uploading pics. I also got my other decals on it, on the windshield it reads "DROPSICILE" and the barn doors carry the future club name and logo of "KOFFIN DRAGGER". I still have tons of work to do, but its getting closer everday.
Old 10-20-2008, 02:17 AM   #222
kdrodworks316
KOFFIN DRAGGER
Trucker's are just like lowriders, Bling and lights are our weakness, we just call them differant things. You call it "bling", we call it "chicken parts", you call 'em "leds", we call 'em "chicken lights". but we both do our fair share of "rooster cruisin", "ckicken haulin", "cluckin truckin". You strive to by lo and slo, I go for low and long.
As far as the cow smasher up front, thats called "protect the investment. it goes like this:$147,000 kenworth W900L + 1000lb elk= about $50,000 damage and the police asking questions about my logbook as opposed to $147,000 kenworth + $1200 bull bar + 1000 lb elk = dead elk and big, bloody mess on highway as my taillights fade into the darkness.
Anyway, I should see all of my western montana and northern Idaho buddies this week, stock the coolers boys, KD"s going "chicken truckin"
Old 10-20-2008, 02:21 AM   #223
RunninLo
RunninLo's Avatar
Read the box, it's 2.1 MILLION colors.... some kind of endorser you turned out to be oh I'll beat Joe to it:
Josh
88 4x4 crew DD
Last edited by RunninLo; 10-20-2008 at 02:21 AM. Reason: I spell like KD counts colors
Old 10-25-2008, 04:03 AM   #224
kdrodworks316
KOFFIN DRAGGER
We discused the 2.1 milion color thing, lol.
You will all be happy to know I have solved the oil filter problem, and it was my own common sence the whole time that made it leak.
There is a by-pass in the block, held in by 2 bolts. It retains the shape of the o-ring against the block as well. The adapter fits over it and seals against the block. It works great when you put all of the parts back it, DUH! just thought you may all need that lil tidbit of info in case anyone converts filters. Pics up tomarrow.
Old 10-25-2008, 05:22 AM   #225
TimE
Hey Y'all!!
TimE's Avatar
I bet you were like when you figured out the leak. A lot of times it's the simple things that get ya. Glad to hear you got it worked out though.
Better get the pics up before Joe sees this though!!! Otherwise, you know what's comin'.
TimE is offline   Reply With Quote
