Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 09-17-2017, 06:54 PM   #1
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
back up
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline
Old 09-27-2017, 02:12 PM   #2
Steve Cole
Any chance you could post the specs on your fans? Particularly CFM's and current draw, but the full specs would be nice. Are the fans American made as well? Thanks.
Steve Cole is offline
Old 10-01-2017, 02:25 PM   #3
SparkyRnD
SparkyRnD's Avatar
We have several dozen fans that we carry depending on diameter, depth, speed, etc and it varies on each application. I believe all of the fans are imported.
What we do is get engine / trans / application info, if there are any power adders, what the vehicle is used for, and location information. We use that to determine which fan(s) would be best suited and that is what we recommend. Available space also has a bit to do with it.
Old 10-13-2017, 11:37 AM   #4
SparkyRnD
SparkyRnD's Avatar
bump
Old 10-16-2017, 09:21 PM   #5
truckdude239
truckdude239's Avatar
Have a 71 c10 with 4.8ls 4l60e how much for a radiator and fan set up with the ls ports on passager side and a trans cooler i currently have a griffin ls rad that has sprung a leak after only 4 years which sucks...
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline
Old 10-18-2017, 06:00 PM   #6
SparkyRnD
SparkyRnD's Avatar
David, thanks for contacting us. The price with discount is $425 for the radiator, and we never charge extra for any of the following:
LS configuration ports
Steam Port
Built-in Trans Cooler
For the fans, I'd need to know about how the engine is built (hp & torque), and if there are any power adders (turbo, supercharger, nitrous). Let me know and I can provide recommendations.
Old 10-18-2017, 10:00 PM   #7
truckdude239
Its a stock 4.8l i think it makes 280 hp
David fuller
2012 Subura outback
1999 honda accord
Old 10-19-2017, 11:23 AM   #8
SparkyRnD
SparkyRnD's Avatar
Ok, then our standard dual 12's will be fine. That is $220 after discount, and $75 for the controller with relay (not needed if you have a relay set up in your harness for fans). Shipping on that setup will be $55.
Old 11-10-2017, 01:11 PM   #9
SparkyRnD
SparkyRnD's Avatar
thanks for the orders!
Old 11-14-2017, 10:49 PM   #10
carbuff382
carbuff382's Avatar
Hello Sparky,
So I need the LS conversion radiator for my 70, and I have the smaller 3 row metal mounts with the rubber inserts. This will work with your radiator correct? Also, I need the tranny cooler and can you make the intake(upper hose connection the same size as the lower)?
Thanks,
carbuff382 is offline
Old 11-15-2017, 12:25 PM   #11
SparkyRnD
SparkyRnD's Avatar
Yes, that'll work with our setup. We make the LS ports on the passenger side and they are the same size inlet / outlet. We also include a steam port at no additional cost.
Old 11-15-2017, 12:35 PM   #12
carbuff382
carbuff382's Avatar
OK, so how much shipped to 87111 and do you have it in stock?
Thanks,
Old 11-15-2017, 12:55 PM   #13
SparkyRnD
SparkyRnD's Avatar
I had replied to your email earlier as well (but you may not have seen it). We make everything to order, and currently we're on a 1.5-2 week turnaround (maybe a little faster). Shipping is $65, and the radiator (after forum member discount) is $425. Let me know if you'd like to set up an order (I can email you the invoice with payment instructions).
Old 11-15-2017, 01:06 PM   #14
carbuff382
carbuff382's Avatar
Yes, I'd like to get one ordered, also is the core approx. 28" wide? The fan set-up I have is for a minimum of 28" wide core.
Thanks,
Old 11-19-2017, 02:47 PM   #15
SparkyRnD
SparkyRnD's Avatar
Thanks for the order!
Old 11-30-2017, 12:29 PM   #16
carbuff382
carbuff382's Avatar
Hello Sparky,
Sent you an email as well, when should I anticipate receiving my radiator?
Thanks,
Marc
Old 12-03-2017, 02:40 PM   #17
SparkyRnD
SparkyRnD's Avatar
I had replied the other day, but just saw this as well. It'll be shipping out tomorrow and I already emailed tracking and a copy of the invoice.
Old 12-17-2017, 04:18 AM   #18
birkinsb
Looking to get a radiator for a 1970 2wd blazer ls swap 5.3 stock with 4l60 trans would like it with trans cooler , steam port , fans and relay kit to 92807
birkinsb is offline
Old 12-17-2017, 02:12 PM   #19
SparkyRnD
SparkyRnD's Avatar
birkinsb, thanks for contacting us. The price for the radiator is $425 ($450 retail), standard dual 12" fans are $225 ($245 retail), relay kit is $75, and shipping is $80. Total is $805 shipped after discounts.
Note that we never charge extra for a transmission cooler, changing the ports to LS application, or for the steam port. If you would like to proceed with an order, send me a private message with your email address and your full shipping address and I will put together an invoice and email it to you. Thanks and let me know if you have any other questions
Old 12-19-2017, 05:23 PM   #20
sangell
Sent you a PM with my email address and some questions.
sangell is offline
Old 12-22-2017, 11:28 AM   #21
SparkyRnD
SparkyRnD's Avatar
replied, thanks!
Old 12-29-2017, 11:06 AM   #22
SparkyRnD
SparkyRnD's Avatar
bump
Old 01-11-2018, 03:41 PM   #23
SparkyRnD
SparkyRnD's Avatar
back up again
Old 01-25-2018, 03:26 PM   #24
SparkyRnD
SparkyRnD's Avatar
up top
Old 02-14-2018, 07:00 PM   #25
SparkyRnD
SparkyRnD's Avatar
Closed Thread
