Old 05-20-2020, 08:06 AM   #201
cornerstone
cornerstone's Avatar
Re: Uncle Loyd's 72' C-10
Originally Posted by MDPotter View Post
Have you figured out your fan wiring yet? I've been doing research on Gen V's in hopes of doing one on the next project. From what I've read, the ECM is not capable of turning on fans with a high/low function like the previous generations. It controls the speed of the fans in a variable speed fashion. That or you can install a temp sender and a standalone fan controller, but I like how clean the factory setup is and letting the ECM control the fans.
Updates? Unfortunately nothing to report truck wise. I've been preparing for my daughters wedding that is scheduled this coming Oct. 10. She wants to have her ceremony and reception here at our place, and that requires a ton of work to be ready for that. She wants the ceremony to be near a particular grouping of trees and have the guests be able to have a short walk over to the barn where dinner will be served, then dancing. I've been focusing on building a shop so I can store all the stuff that is currently in my pole barn. The plan is to in to pour a slab in the barn which will server as our reception hall. I think I may have agreed to more than I can get done in time...
I know that my stand alone harness, (from Swaptime) does have a single wire that is labeled "fan" The fan that I installed just has 2 wires, so I'm hoping my computer can work with what I bought. It would be really cool if the ECM does control my fan with variable speed because it seems like it may be loud at full speed. I probably wouldn't be able to hear it over the motor anyway. I won't be much of a help with anything wiring related, but I'll be glad to try.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-20-2020, 09:57 AM   #202
MDPotter
MDPotter's Avatar
It just so happens that I'm getting married Oct 10 as well! That does sound like a lot of work. But hey, instead of paying a venue you have improvements to your property!
We don't even have an engine yet, I'm just doing some preliminary research. If we end up going the Gen V route I'll have to get ahold of Mitch to talk through some details. I like the way he reworks the harnesses and he seems to be a good source of Gen V swap information.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-20-2020, 11:00 AM   #203
cornerstone
Congratulations on your wedding man! I guess it’s true what they say “Great minds think alike!” That was exactly my thinking, I mean a decent venue runs at least 5K, and the slab will be about the same, plus I get my shop finally erected... it’s a win win. My plan currently is to do the work myself, but I’m starting to think I may have to hire it out.
Brian
Old 05-20-2020, 11:53 AM   #204
MDPotter
MDPotter's Avatar
Thanks! I'm just hoping this COVID stuff is mostly gone by then so everything can happen as planned.
Old 05-25-2020, 03:16 PM   #205
TA_C10
TA_C10's Avatar
Dang, been gone too long. Lot's going on around here! Excited to see the paint man. And you better bet you will need the slowest reducer they make in our heat brother. I had good luck painting in a homeade garage booth with slow reducer made for 90* heat. And my garage was around 90-100* when I painted. No problems. Single Stage hot rod flatz. But just keep an eye on it, will be fine.
I like that blaster idea. The tank looks like it will work. I wish i had a blaster. Borrowed one of those HF double tanks from a friend. It didn't really work very well for me. If I had a blast cabinet for small parts it would work just fine. The tank you show and setup looks like it should have good volume and pressure.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 05-25-2020, 03:20 PM   #206
TA_C10
TA_C10's Avatar
Oh, and 2 thumbs up, wait, there is an emoticon for that.... for that Billy Jenkins Bock!!!!
"It's only money".
Old 06-24-2020, 12:29 PM   #207
GerhardH
GerhardH's Avatar
Come back after a while and Brian has done magic things- Congratulation looks prettttttty good cowboy.
I would spend one more Billy Jenkins Bock!!!
Cheers!
Best regards GerhardH!
Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20
1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400
http://67-72chevytrucks.com/vboard/s...d.php?t=760400
GerhardH is offline   Reply With Quote
Old 07-18-2020, 12:21 AM   #208
cornerstone
No truck update yet, but at least one project that was holding me up is done now. I had been working on getting the concrete forms built for my shop. I took a look at the calendar and at the pace I had been going, there was no way I would have enough time to get both slabs poured before the wedding. I changed the order of priority and switched over to the pole barn project. That’s where my daughter wants to have her wedding reception a few months from now, and dancing on a dirt floor wasn’t gonna cut it. It took a week for me to clean it out and sell off a ton of stuff. I bit the bullet and found a cement crew and got it knocked out this week.
Of course every year it seems the heaviest work I do is exactly the time we hit 100* and stay there til I’m done. Good Lord it’s HOT IN TEXAS.
Brian
Old 07-18-2020, 12:43 AM   #209
Kronald_70GMC
Kronald_70GMC's Avatar
That is a pretty cool looking pole barn!
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
Kronald_70GMC is offline   Reply With Quote
Old 07-18-2020, 04:50 AM   #210
TA_C10
TA_C10's Avatar
Agreed, very nice barn your building there. Does the loft go all the way front to back? And yeah man, it's been hot, making my body work go slow...
"It's only money".
Old 07-18-2020, 10:04 AM   #211
cornerstone
Thanks guys. Yes the loft is the full 36 feet deep.. I have a staircase to the loft that I had to remove so the concrete work could proceed smoothly. If I keep that one I want to have it raise up to stay out of the way of the lower floor. I've also considered building a ladder to get up and pole to slide down, as a kid I went over to a friends house who had a barn with a hay loft that had a pole to slide down, so much fun back then. I'd probably bust an ankle if I tried it at 52.
Brian
Old 09-16-2020, 10:28 AM   #212
GerhardH
GerhardH's Avatar
Wonderful!!!!
Old 09-19-2020, 11:09 AM   #213
TA_C10
TA_C10's Avatar
And bump. How's the truck?
"It's only money".
Old 09-21-2020, 10:10 PM   #214
cornerstone
How's the truck?
Lonely and dusty. I'm hoping just one more month and I'll be able to get back to work on it.
Brian
Old 12-02-2020, 05:11 PM   #215
TA_C10
TA_C10's Avatar
No progress in forever. The flag is going up!
"It's only money".
Old 12-02-2020, 05:20 PM   #216
MDPotter
MDPotter's Avatar
Yeah, the wedding was almost two months ago!
Old 12-02-2020, 05:58 PM   #217
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Cornerstone...don't listen to them. I'm going on 4 years of honeymoon, but seriously why aren't you working on the truck!? LOL
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-04-2020, 10:51 AM   #218
cornerstone
The B.S. flag is well deserved...
Why you ask?
For the last month it's been our master bathroom remodel down to the studs, tile shower walls complete with cubby holes, floating concrete countertop vanity, tile floors and sheet rock / tape and bed/ texture. Only a paint job remaining!
A weeks worth of work installing a 7.5 KW off grid solar panel system on the roof of the barn for "free" electricity for life. Still have another couple of weeks to go til that's finished!
Who knows how much time I have in a real estate deal. I had to re platt my land in order to sell off our rental house to some friends. It'll be great having another family with boys my sons age around so he has other buddies to ride dirt bikes with, instead of only me.
Then there was the chicken coup remodel... and the car repairs... and and and
Responsibilities suck!
I do appreciate you guys calling me out though! It's nice to know someone else besides me wants to see my truck finished!
Brian
Old 12-04-2020, 11:00 AM   #219
MDPotter
MDPotter's Avatar
We're just giving you crap - we know life happens. I can certainly be blamed for neglecting some things for working on trucks instead. But those all sound like more important tasks than a truck!
Would it be weird if I asked for before/after pics of your bathroom? That sounds like a really nice job. I've got a buddy interested in concrete countertops and in my commercial construction world it's not something I see.
Old 12-04-2020, 11:25 AM   #220
rowdy11
Guilty of this as well...very busy pandemic summer and fall with unexpected big events such as weddings and remodels are sometimes a part of life. Welcome overall but it can be detrimental for builds.
Hey when you have no one following your build like I do, you don't get as much good natured ribbing! Lots of folks invested in your success and have the best intentions for you. Can't wait for the time that it works in your life to spin back up and finish your build!
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 12-04-2020, 12:24 PM   #221
1971Stepside
Almost Satisfied
This is correct
Your last update was in June! Let's get it going man. I love your build...in fact it is probably going to cost me a lot of money because I want to build a 4wd now.
Old 12-04-2020, 06:15 PM   #222
TA_C10
TA_C10's Avatar
"It's only money".
Old 12-10-2020, 10:51 AM   #223
cornerstone
Not weird at all, pm me your number and I'll send pics to you directly.
Brian
Old 12-18-2020, 11:34 AM   #224
tucktuck
tucktuck's Avatar
Check your PMs when you get a chance please sir. Cant wait to get caught up with you...
tucktuck is offline   Reply With Quote
Old 12-18-2020, 12:14 PM   #225
cornerstone
I answered your questions just now. Tell us about the truck in your avatar! Is it yours or what you eventually are hoping to have?
Brian
