04-30-2016, 07:40 PM | #1 |
Re: Hydroboost Mounting Plates
05-01-2016, 12:10 AM | #2 |
60-66 Nut
I'll send you a PM with ordering and payment info.
06-26-2016, 12:57 AM | #3 |
so.. with the hydroboost, I only need a direct mounting plate to keep it tight and clean to the firewall?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
08-08-2016, 12:55 AM | #4 |
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
03-20-2017, 06:39 PM | #5 |
I would like the same bracket but with mounting holes and black powder coat will be paired with a 2012 2500 Silverado unit.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
03-20-2017, 11:23 PM | #6 |
60-66 Nut
I will send you a PM with ordering and payment info.
03-20-2017, 11:27 PM | #7 |
CaptainFab-
I got an 85 K20 that I'm converting to a manual trans & hydro-boost. I'm having a hell of a time finding a pedal assembly for such that doesn't cost a fortune. Locating a manual/vacuum version seems to be much easier (and cheaper!). So, I'm thinking I'll first convert it to manual clutch/vacuum (its currently auto/vacuum) and then use your bracket to convert it over to hydroboost. Am I understanding this right? You have a bracket that properly re-positions the hydro-boost unit to replace the vacuum unit? Does this correct the geometry difference in the pin height on the brake pedal? Any mods needed to the pushrod? Thank you in advance, Mike |
03-20-2017, 11:35 PM | #8 | |
60-66 Nut
I do not make any booster brackets or hydroboost mounts for the square bodies. There is no need since factory components are readily available. I do not know what the hole pattern would be if the factory booster brackets were removed from the vacuum booster. Those are riveted to the booster.
