Old 04-14-2004, 03:59 PM   #1
Ric83
Ric83's Avatar
Question What causes this??
My dad asked me to chech the timing on his truck yest. ('83 Scotsdale w/ stock 305)
When I took a look at it, it sounded like it was idleing a little too fast. When I pulled the vac. hose off of the advance to check the timing, it made very little diff. as to how it idled. Well, while shining the light, I noticed that every few seconds, the timing mark would jump quite a bit to the advance side. What would cause it to do that?? I know his truck needs a tune up pretty bad so we will do that, but is there something in specific I need to look into?? After setting the timing at 10, I took it for a drive and it drives like a dog. It has not kind of power, you have to let it build up speed and forget about passing anyone. I ended up setting the timing at 8 instead. It seemed to like it a little better but had all the mentioned problems still. Anyone have any suggestions?
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 04-14-2004, 04:18 PM   #2
Russell
Professional Grade
Russell's Avatar
If it is idling too quickly, the mech advance may be kicking in occasionally. Another possiblity is that the harmonic balancer has slipped, causing you to not be able to time it properly...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-14-2004, 05:25 PM   #3
chevyjr73
chevyjr73's Avatar
the vacuum advance may not have changed idle when you pulled it because it might be connected to ported vacuum. if the timing is jumping around either your springs in your distributor is worn or the distributor itself is bad. also you may have some slack in your timing chain. it may feel too sluggish because your timing is noy set high enough. i have mine set at 14 degrees btdc. anything less and its a dog. you could also have a vacuum leak causing it too idle so high.
chevyjr73 is offline   Reply With Quote
Old 04-14-2004, 06:32 PM   #4
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Sounds like a worn timing chain like chevyjr73 mentioned. If it has alot of miles on it then I would spend the time and money and get a new set. Plus you can check your balancer while you're there.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 04-15-2004, 10:42 AM   #5
Ric83
Ric83's Avatar
I am not too sure on the distributor. We thought it might be it, but not sure if it was something in it which could be changed or if it might be the whole thing.
As far as the timing chain, I just replaced it a few months ago. Not sure on how long ago exactly, but I would definatly say no more than a year. When I installed it I reset the distributor as well and set the timing to 10* and it ran great. Beter than I think it has run the whole time he has had it.
Ric
Here she is
Old 04-15-2004, 10:58 AM   #6
chevyjr73
chevyjr73's Avatar
if you already replaced the timing chain i would definately go with a new distributor. the mechanical advance in it is probably worn out.
