Old 04-14-2004, 05:56 PM   #1
rocktriviagod
drip drip drip goes the tranny
I know one of you out there will have a simple fix for this problem. My 78 Chev (350/350TH) leaks tranny fluid where the speedo cable goes into the trans. I replaced the O-ring but it didn't make much difference. Is there a particular procedure I should be following or better brand of 0-ring ????
Thanks!!
Currently in and around my garage:
1978 Chevy Stepside (Elvis)
1993 Chev S10 ext cab (LittleTruck)
1998 Chev Astro Van (Wife's Hauler)
2001 Honda 1500 Valkyrie Interstate (dad's toy)
2003 Honda 1800 Gold Wing (mom's toy)
rocktriviagod is offline   Reply With Quote
Old 04-14-2004, 06:09 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I'm guessing you replaced the o ring on the sleeve. There is a seal on the speedo gear shaft too.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-14-2004, 06:21 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I was able to buy a whole new "bullet" with inner seal and outer o-ring for just a few dollars at a transmission supply place. That ought to fix your problem unless there is a rough spot on the gear or something that eats up seals.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-14-2004, 08:24 PM   #4
rocktriviagod
Thanks for the ideas. I'll check with the trans shop..........
Old 04-15-2004, 01:03 PM   #5
KShortell
KShortell's Avatar
Cool thread.
I've got the same problem-- minor, but annoying.
Semper Paratus
KShortell is offline   Reply With Quote
Old 04-15-2004, 02:27 PM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I just went to the HELP section and bought an assorted O-ring pack. Put one in that fit the best and all fixed. Mine didn't have one at all in there somehow.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-15-2004, 03:25 PM   #7
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Guys..its not an o-ring....its a gasket that looks more like a top hat that has its top cut out. Its harder plastic than an o ring also. Like 2 bux and a pita to put in....
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 04-15-2004, 07:35 PM   #8
MylilBowTie
Right turn Clyde
got any pictures of it?
Old 04-15-2004, 08:53 PM   #9
swervin ervin
Here's the seal I'm talking about. This is what my 700R4 uses. I'm guessing a 350 uses something similar.
Old 04-15-2004, 10:35 PM   #10
LOHRTBT
LOHRTBT's Avatar
Oh my bad guys...on the speedo mike is correct... I was thinkin about the kickdown cable.
~Dave~
Old 04-16-2004, 12:44 AM   #11
Slonaker
Slonaker's Avatar
These are for my TH350C. They are resting on the receipt, so you can see how cheap they were ($5.90 for the pair). I'll install them one of these days.
Speedo cable bullet with seal and o-ring preinstalled (side view) and new speedo gear:
Speedo bullet (end view of seal):
Damn! This cheap little camera takes good close-ups! The bullet in the pic above is only about 3/4 inch in diameter...
Slonaker
Stock '01 Silverado
