Old 04-14-2004, 10:11 PM   #1
Jeepster376
Jeepster376's Avatar
Vacuum Can
I have the vacuum canister mounted on the heater box, I think I see it on mos AC equipped trucks. Mine has a vacuum line running from the manifold to the can and that's it. What could this be accomplishing hooked up like that. What is the proper connection?
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 04-14-2004, 10:13 PM   #2
smitty62
smitty62's Avatar
That's it
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 04-15-2004, 07:19 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Jeepster, is there another nipple on the vac can?
Old 04-15-2004, 12:14 PM   #4
Jeepster376
It's difficult to tell, there is some kind of knub I can feel on the back side, but I don't think it's an opening. It just seems like such a little can connected only to the manifold, can't be doing much of anything.
Old 04-15-2004, 12:37 PM   #5
smitty62
smitty62's Avatar
It's a vacuum reservoir--all it does is maintain vacuum to activate the heater/ac controls!
Smitty
Old 04-15-2004, 01:41 PM   #6
Jeepster376
Yes but it needs to connect to something. I took a closer look and found that, that knub I felt was in fact another nipple, and I found the little vacuum line had fallen off that goes into the vacuum switch on the Heat/AC controller.
Old 04-15-2004, 04:12 PM   #7
Longhorn Man
The interesting thing about those is, if you don't have a check valve, I don't see how they can do anything.
Old 04-15-2004, 11:40 PM   #8
jhow66
jhow66's Avatar
check valve inside
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
