04-01-2002, 10:09 PM | #1 |
body lift
Does any one know of a place that sells the rubber peices that go between the inner fenders and the frame after a body lift without buying the whole body lift kit?
Or maybe someone has made a pair? what is a good material to make them from? Any ideas would be appreciated!!!
70 3/4 ton 4x4 FOR SALE Greene, IA |
04-02-2002, 01:19 AM | #2 |
Strongman Garage
cab mounts...... www.gmcpauls.com you can get them in polygraphite or rubber
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
04-02-2002, 06:32 PM | #3 |
just the rubber flaps that usually go between the inner fender and the frame to cover up the gap between the two and to keep the engine compartment clean after you put a body lift in (so you can't see the engine through the wheel well)
thanks for the reply anyway!
04-02-2002, 07:02 PM | #4 |
SKINNY TIRES RULE!
I have seen them advertised. Have you check JC Whittney? You may also thumb through a 4x4 magazine or two.
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-02-2002, 08:10 PM | #5 |
thanks
04-02-2002, 08:42 PM | #6 |
ive never done it but i bet you could save some money and make some out of old conveyor belt rubber or mud flaps or something? good luck, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
04-02-2002, 08:46 PM | #7 |
that's a good idea!
what else would be rubber and big enough any ideas?
04-02-2002, 10:32 PM | #8 |
computer illiterate
if you have a local dirt track shop they sell thin rubber and plastic in roles you could trim to fit
72 2wd blazer 72 swb 4x4 |
04-03-2002, 12:28 PM | #9 |
Here's an idea find a old usless tire tube and cut it up to the proper size. I think this is crazy anuf to work.
------------------ 1969 Chev 4x4 9" of lift,327cid,38/16/16.5 Super Swapers,Factory Tack,Powder Coated almost everything. Calgary, Alberta, Canada
1969 Chev 4x4 9" of lift,327cid,38/16/16.5 Super Swampers,Factory Tack,Powder Coated Frame and other misc. Calgary, Alberta, Canada |
