Old 04-14-2004, 11:18 PM   #1
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
gauges
in my 63 gmc, i can't get the fuel gauge and the water temp to work i can't find any wires that aren't connected if info would help.
i have a 305 v6 that might help.
kamikazegmc is offline   Reply With Quote
Old 04-20-2004, 01:02 PM   #2
Lgriffin
Assuming that the wiring is the same as a 63 Chevy. The power for both gauges is a purple wire. This wire goes thru a connector block under the dash, to the ignition switch, and then the engine wiring harness to the solenoid.
Larry
68 C20 327 daily driver
63 C20 292 Camper truck
65 C10 ? Custom Cab AC,PB,PS,$flasher
Lgriffin is offline   Reply With Quote
Old 04-22-2004, 09:03 PM   #3
kamikazegmc
Registered Smarta$$
i found what it was
63 GMC custom
going to be slammed
Old 05-31-2004, 10:43 PM   #4
PTairco
Fuel gauge not working
If you ever test one of these don't apply full voltage to the sender directly from the battery, it will fry. Just a thought.
PTairco is offline   Reply With Quote
