Old 04-14-2004, 11:53 PM   #1
GMC Jim
GMC Jim's Avatar
Raer Drum Brakes
Installed new brake shoes and wheel cylinders on rear of '71 rear wheel drive pickup. Drums are slighly different!! Left drum has casting no.- 3982297; Max Dia 11.09 and is 3 5/8 depth.
Right drum has casting no.- 3989541; Max dia 11.09 and is 3 7/8 depth. Note there is a difference of 1/4" in depth !!
I called the local GMC dealer; parts dept. and was told the drums were discontinued and the last part number on reference was 3984855. !!!!
As the left drum is badly scored , I desire to replace it... but my question is :- what is the right drum to use and does the 1/4 depth difference matter...( I would think it would !) The depth measurement I am refering to is the maximum outside measurement.
Also is there a range of barke drums that are interchangable. example '70 thru '79, maybe... Any help is sure appreciated......Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 04-15-2004, 12:42 AM   #2
1969 GMC
1969 GMC's Avatar
is your truck 1/2 or 3/4 ton?
just askin cuz if its a half ton, should have the 12 bolt...if its a 3/4 ton it should have the dana 60...
if its a dana 60 I could check mine, I think it would be the same.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-15-2004, 12:47 AM   #3
GMC Jim
GMC Jim's Avatar
truck is 1/2 ton..... and has 5 bolt brake drums.....
