04-15-2004, 05:50 AM | #1 |
smoking bad need help!!!
hey guys and gals i need some help... my truck spews white smoke when i stop after having the motor at a steady cruisen speed (freeway)... at first i thought it was rings... but i noticed my tranny was losing mass amounts of fluid after i drive on the freeway... so i think the vacuum is sucking fluid into the motor... woudl this cause white smoke?? because i put in about half a gallon of fluid... cause it was slipping and shifting all over the place.. i put the fluid in & ran great!!! i checked the fluid and it is low again... in the tranny ..mind you the pan doesnt leak... so i need help ya'll... if it is the tranny do i just put on a new modulator?... thanks all... oh ya.. by the way 454/TH400....thanks again
i think i found me truck! 78 Crew Cab Dually 454/TH400, Dual Flows, Edelbrock Intake, Cam, Lifters, Billet Grill, K&N Airfilter, Grant Steering Wheel, A/C, soon to be power windows and locks, lots of plans for this... ....gas prices go down please |
04-15-2004, 10:16 AM | #2 |
Yes and yes
Yes burning trany fluid will make a white colored smoke And Yes if its not leaking on the ground you are probably sucking it threw the modulator valve. They are fairly cheep and easy to replace.
