Old 04-15-2004, 07:03 PM   #1
fossilrunner
fossilrunner's Avatar
what size tires
any body know what size tire I could run on a 1993 chevy 1500 with a 6 inch suspenion lift and a 3 inch body lift. I will not be doing any hardcore offroading mainly driving it on the street.
fossilrunner is offline   Reply With Quote
Old 04-15-2004, 07:46 PM   #2
1FaastC10
1FaastC10's Avatar
35 12.50s i think is what i was told.
1FaastC10 is offline   Reply With Quote
Old 04-15-2004, 08:22 PM   #3
The Dude
you could fit 37's
The Dude is offline   Reply With Quote
Old 04-15-2004, 09:00 PM   #4
super72
super72's Avatar
A friend of mine runs 39.5 super swampers. He does go in the mud every now and then. I personally have seen them rub once when he fell into a washout at about 40mph. Looks mean as hell to!
super72 is offline   Reply With Quote
Old 04-15-2004, 10:58 PM   #5
BurnoutNova
BurnoutNova's Avatar
i know someone with only a 3" bl and he runs 35x12.50's so you could fit way bigger than that
BurnoutNova is offline   Reply With Quote
Old 04-16-2004, 02:25 AM   #6
IoWnZa
Big Block Blazer
I would stay away from the Body Lift and you would still be able to run 35's with no problem. and make sure to use all Spring Lift for the 6" Suspension. Blocks are horrid.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys]
IoWnZa is offline   Reply With Quote
Old 04-16-2004, 06:08 PM   #7
1FaastC10
1FaastC10's Avatar
IoWnZa, this is an IFS truck. you cannot lift the front with springs, as there are none. as for the blocks, it depends on what he's doing, and what he has under the hood. if its a primarily stock truck, and he only plays occasionally, it will be just fine with blocks. i'd personally do a shackle flip before i put lift springs on the back.lift springs have more arch, and therefore, less compression, which isnt good for flex, and flex is good for wheeling.
Old 04-19-2004, 04:57 PM   #8
ALBATROSS
My brother has a 6 in. susp. and a 3 in. body. He ran 35x14.50x15 swamper boggers with no problems. It looks like he could probably run 37 or 38's not sure on the width though. He started out with just the 6 in susp. and his 35x12.50 wranglers rubbed on tight turns.
ALBATROSS is offline   Reply With Quote
Old 04-20-2004, 09:27 AM   #9
Joey-D
City's Articulation Ramp
Joey-D's Avatar
My old 92 had 35x12.5x15 of 15x10 rim and a 6 inch trailmaster lift. I would rub putting out of my city driveway and turned. I hacked the fenders 3 inches and took 3 inches off the bumpers. With a 3 inch body lift, I would run probaly 36x14.5 on stock fenders. Plus remember, if you still have you 3.42 gears, with 35s that gear reduces to about a 2.83. In other words a real dog. I drove my truck hard, and with only 35s went throught that cheap IFS like it was nothing. 3 CV Joints, 3 Hub assememblies, inner and outer tie rods, pitman arm, and numerous other items. Just add it up, if you are in the planning stage still, RUN A SOLID FRONT AXLE CONVERSION!!!!!!!!!!!!!!!!!!!!!!!
P.S. With a add-a-leaf and 4 inch blocks in back, I went throught 2 sets of blocks because I kept breaking the nipples off of them with the axle wrap, finally found a way to fix and reuse the blocks.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 04-20-2004, 03:30 PM   #10
The Dude
this was my friends old truck.
it has a 6in lift, 3 in body, torsion bars cranked, and bigger blocks out back for a total of 11in of lift. it is runin 38's
Old 04-20-2004, 05:51 PM   #11
Joey-D
Joey-D's Avatar
That is a good looking rig. I cranked my torsion bars once, but then let then back down. It all depends on the use of the vehicle for torsion bar twisting. Go for it if you just want the truck to look pretty, but don't if you want to use it. I found two problems with cranking the bars; 1: any time I made a turn at more than 2 1/2 mph the tires would squeel before of the stiffness and for that same reason 2: I had no articulation. That is one pet peeve of mine, if a vehicle is fast, drive it fast, if it lifted, get it muddy. In other words USE YOUR TRUCK LIKE IT WAS INTENDED FOR!!
Thank you, I needed that.
Joe
