Where to start???
I have a 70 3/4 ton that I'm going to start working on. I've never done anything like this before so I'm going to ask a million questions.
![]() It has HD suspention, 350 V8, and a 4 speed. I don't drive it very much now because the rear end is so low I don't want to drive it much over 45. So I was thinking start with swaping the rear and getting disk brakes. I just read a post about a rear out of a 79 Lincoln Versailles. Will that work on a 3/4 ton? I like the way this truck looks so this is what I'm going for. ![]() What will I need to do to get this look "suspention wise" out of my truck? |
That's a real good looking truck.
You don't have to replace the rear end - swapping in a strange housing is a big job. Just change the gears inside the rearend. If you want a low cruiser, you may want to change your tranny to a newer 5 speed, too. Don't be afraid to ask questions, how else will we all learn? To lower your truck, contact some of our vendors listed on the home page. I got my kit from Early Classic Enterprises, but I'm not that low. That blue truck may have an air bag system. Disc brakes are nice. Again, look at some of the vendor links. Good luck, Scott
Silence is golden, duct tape is silver. - Scott |
AKA Phillip Johnson, AKA BANNED
That is a very nice truck. I would leave it just as it sits! Stock trucks are GREAT!
More Cowbell....
I would lift it and put those tires that are in the background on it.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
You need to figure out if you have the Dana 60 or Corp rearend first. You can get more highway type gears for the Dana. Corp is one heavy duty rearend, but limited in options (4.11, 4.56,...etc)
Swapping another type rearend is very possible, but if you are new to all this I don't think I would recommend it. Don't forget you have 8 lug right now and you are talking about a Lincoln rearend. Anything is possible....I have a narrowed 9" Ford rearend in a Chevette...lol Good Luck! |
Thanks for all of the advise.
What is the best way of figuring out which rear end I have? Swaping gears and the tranny sounds like a good start to me. I know there are some guys on here that are running 6 speeds so if they could chime in on swapping one in that would be great. I've always wanted a car/truck with a 6 speed. Is there an addaptor that will work with the stock motor? Ya the tires in the back ground are 66's. They are freaken huge. They are going on the blue truck to the left of them. The plan for that truck are a blown big block with 4 wheel stearing. Door handle button is gone. I like to think of it as an extra security device. It's a trick to get it open. There are 2 gas tanks so that silver spot on the back is a filler cap. |
Formerly yellow72custom
Nice truck. I like the way it sits now!
Look at the cover in the middle of your rearend....if it is completely round you have an Eaton HO52. If it is odd shaped with 10-bolts on the cover it is a Dana 60. I'm betting that since it is a GMC it has a Dana 60. Every GMC 3/4 ton i have seen has had a Dana, while Chevies usually had the Eaton rear. Here is a Dana 60 (it is a front axle, but the shape sholuld be the same for the rear: ![]() And here is a Eaton HO52: ![]()
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
yellow72custom thanks for the pics. Made that easy.
I did some searching for 6 speed conversions and I found http://www.weirhotrodproducts.com/index.html So it can be done but looks like it's going to take some work. |
Navel Inspector
I don't know a thing, but that truck is a nice clean start. Stay focused and learn as you go. Kinda what I am doing.
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I WOULD START OUT BY DECIDEING WHAT YOU WANT THE TRUCK TO LOOK LIKE AT THE END AND STOCK,CUSTOM ETC AND GO FROM THERE..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I agree with everyone else, just like myself, what the hell am I going to do with my truck when I get finished? will I ever be finished with it, probably not. but the reason I was asking about rear ends is because I was thinking about switching over to disc brakes, then I remember that ece sells the rotors for 6x5.5 for 75 a piece, then I would have gotten calipers that match the rotors. then i thought about someone having a mid 90's impala ss rear end, then I thought about my idea a few weeks ago about jag rears. I want to have a 5 or 6 lug rear with disc brakes, then add in the air. do up my interior with custom installed gauges. there is a bunch of stuff that we all have ideas for you. VERY NICE TRUCK!!!
~Christopher L. Orr 71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc. |
