Old 04-16-2004, 12:27 AM   #1
bigblock73
yeller
bigblock73's Avatar
power brake booster question
Do power brake boosters ever go bad? At the moment, money is tight for the truck, but I need to install my brake booster. The booster itself worked fine when it was pulled, and it appears to be in excellent shape, at least on the outside. Can/should I clean it up, repaint it, and use it....or buy a new one?
Not trying to cut corners, just not sure if this is pretty common or if most would spend the money on a new one.
Anyone buy a new one lately, how much do they go for and where did you get yours at?
bigblock73 is offline   Reply With Quote
Old 04-16-2004, 01:04 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I got one about a year ago for about $80 from Car Quest. Yes they can go bad, but you can easily tell with a few simple tests. Just search the web for testing a brake booster and try it on yours.
NeCrOmAnCeR is offline   Reply With Quote
Old 04-16-2004, 10:11 AM   #3
Jonboy
Slots go on anything!
usually you will hear a hissing sound when you hit the brakes. I would clean up the one you have. I am guessing you will be installing a new master cylinder. If it is bad, you can unbolt the master cylinder without having to disconnect the lines, and move it forward. Replacing just the booster is pretty easy, if you need to do it later.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-16-2004, 10:30 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
A guy has a web site with some info...
http://www.73-87.com/7387garage/chas...on/booster.htm
Seriously, though, I have had one go bad in the past. I am a little suspicious of mine. None of the tests I have done indicate that it is bad, but I get very little boost out of it.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-16-2004, 06:48 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I know that guy. He has some good info there, but he is kinda slow.... Like he don't know it is there..
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-16-2004, 10:19 PM   #6
bigblock73
yeller
bigblock73's Avatar
Listen here butt clowns.
I wasn't asking how to test it...that would be kind of hard to do with the state Yeller is in now.
I was just asking what you guys would do if you were me.
I ended up buying a new one...the foam (dirt shield) on mine was rotted away, and the more I wire brushed the old one the more I realized unless I took it to bare metal, the paint would never stick.
Old 04-17-2004, 02:12 AM   #7
Slonaker
Slonaker's Avatar
I briefly considered changing my custom title to "Butt Clown."
Well, very briefly...
Slonaker
Stock '01 Silverado
Old 04-17-2004, 03:39 AM   #8
Nvbowtie
Nvbowtie's Avatar
Just bought one tonight as a mater of fact;
Mast Cyl 13.99
http://www.partsamerica.com/PartDeta...tNumber=101521
Booster 87.99
http://www.partsamerica.com/PartDeta...Number=5471008
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 04-17-2004, 02:22 PM   #9
Captkaos
Captkaos's Avatar
Is Butt Clown above or below A$$ Clown.... I just want to know where my ranking stands.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 04-17-2004, 03:08 PM   #10
bigblock73
yeller
bigblock73's Avatar
A butt clown is somewhere in the middle of a clown and a$$ clown...so you have not reached a$$ clown status...yet.
Old 04-19-2004, 06:25 PM   #11
Captkaos
Captkaos's Avatar
Crap. I need to try harder then....
Chris Lucas
1973 Chevy C-10
Captkaos Customs
