need a 1/2 ton frame
I am in need of a 1/2ton frame close to south west Colorado.
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
AKA Phillip Johnson, AKA BANNED
I have a 3/4 with a pink slip and vin tag in Northern Calif!
![]() Join Date: Nov 2002
is washington state close enough? I have 72 with the front suspention, sway bar and the p/s pump and gearbox, it's a long wheel base frame . $200
I have no transportation and need something closer
Thanks for the offers
Tow bar included!
I am really looking for a 1/2ton frame
what do you need it for? i have you from a 70 chevy. it needs some work. it would be cheap if you want it. pm me if you are interested
'67 c10 350/th350 |
Too many is never enough!
frame
Too bad you're stuck on half ton. I have a 3/4 ton frame in Denver. You don't have any 1/2 ton stuff to swap onto it? Just in case it is a leaf spring rear. Take out the rear diff and front crossmember and it is identical to 1/2 ton.
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
