Old 04-16-2004, 08:25 AM   #1
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
Installing tach in dash
I bought a 76 Camaro instrument cluster that I'm going to take the tachometer out of and install it in my 71's dash panel. I know some of you out there have done this mod, do you have any good pictures to post (of the way that you mounted and cut the inner panels) What about a tach filter??? I assume I will need one of these??? Does anybody have one that they want to get rid of? I'm also going to take the electric clock out and put that in the panel too. But I need to test these items first before I go cutting up my dash!!!! Are there any simple tests other than hooking the tach and clock up to the vehicle? TJ
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 04-18-2004, 09:48 AM   #2
bigskiohio
should be able to hook up tach and clock under hood or spare battery. I had a72 i put a tach in 20 years ago ,i used a sun tach
and i just cut the printed circiut in back there was nothing ruuning in that area of tach hole.
bigskiohio is offline   Reply With Quote
Old 04-18-2004, 12:11 PM   #3
neonlarry
neonlarry's Avatar
Check out thisPost .
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-18-2004, 12:35 PM   #4
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Re: above"POST" link....
Man, that was a good install and finish product! I think that is what you'll be looking for with your Tach needs!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
