Old 04-16-2004, 11:54 PM   #1
Als454
Question Need BBC pulley pictures
Can someone get me pictures of the pulley setup on a BBC with A/C and P/S. My truck did not have A/C originally, I added it. I need some clarification on how the belts and pulleys are configured. Thanks
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 04-17-2004, 02:18 AM   #2
flip66
flip66's Avatar
I have one and can take some pic but the ac is no installed all the pulles are there tough
flip66 is offline   Reply With Quote
Old 04-17-2004, 02:36 AM   #3
flip66
flip66's Avatar
pic1
Old 04-17-2004, 02:37 AM   #4
flip66
flip66's Avatar
pic2
Old 04-17-2004, 02:52 AM   #5
flip66
flip66's Avatar
pic
Old 04-17-2004, 03:05 AM   #6
flip66
flip66's Avatar
pic
Old 04-17-2004, 12:44 PM   #7
Als454
flip66, I have a few questions. Pictures are kinda are to make out.
How many grooves do you have on the crank shaft pulley? I thought there should be three.
Belts, should there be...?
One for the alternator, Going around the alternator, crank shaft and water pump.
One for the a/c going around the compressor, water pump and crank shaft.
One for p/s going around the p/s pump and crank shaft.
Old 04-17-2004, 01:43 PM   #8
dwaite72lnghrn
3 grooves on the crank. the 1 closest to the block is for the alternator, #2 is for the air conditioner, #3 is for the Power steering. 2 grooves on the water pump are for the alternator and the air conditioner. I will see if I have an old picture of my '72 setup.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 04-17-2004, 01:46 PM   #9
dwaite72lnghrn
here it is.
2009 HHR aqua blue
Dave & Jeanne
Old 04-17-2004, 09:25 PM   #10
Als454
dwaite, My power steering pump has a two groove pulley on it, any idea why?
Old 04-17-2004, 10:09 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
72 spec crank pulleys.... There are two, which stack on top of each other...
Old 04-17-2004, 10:11 PM   #12
Tx Firefighter
stacked...
Old 04-17-2004, 10:13 PM   #13
Tx Firefighter
power steering...
Old 04-17-2004, 10:17 PM   #14
Tx Firefighter
installed...
Old 04-17-2004, 10:25 PM   #15
dwaite72lnghrn
Not really sure. Is it original or did it come out of a recycle yard off a c40-60 where they used 2 belts.
2009 HHR aqua blue
Dave & Jeanne
Old 04-18-2004, 02:50 AM   #16
flip66
flip66's Avatar
Is kind of hard to see you are right about the way the belts go I do not have the ac belt on so the grove you see is were it is suppose to go,. I can get better pic if you need them
