Old 04-17-2004, 02:47 AM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
WTB: P/S pump pulley, GM #3993325DJ
Needed: Power steering pump pulley.
This one has part number 3993325DJ stamped on it. I think it came off of a 72 4x4 small block, no A/C. This one is bent to sh!t.
Kinda scared to call the dealer, but I suppose I will have to if I can't find a good used one.
Thanks!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-17-2004, 11:57 AM   #2
Rakort
With the cost of the new pulley compared to the hassle of removing a PS pulley from a used pump I'd say go to the dealer. At least that is wht I did. Sometimes those pulleys are on there darn hard and unless you have the right puller it will be difficult to get off. I don't remember wha I paid, but maybe $20 or so.
Rak
Rakort
Parts for Sale: Pictures
Awesome Elec. Schematic Available: Picture
Rakort is offline   Reply With Quote
Old 04-17-2004, 01:03 PM   #3
glock35ipsc
I have a puller, it came off real easy.
Bob
Old 04-17-2004, 03:38 PM   #4
Rakort
Ahh, maybe its just me! I never had an actual ps pulley puller, just a generic snap on puller set and for the life of me I couldn't get the last one off I tried.
Rakort
Old 04-17-2004, 03:53 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
Power steering pulleys bend easy, I would go new. Theres lots on Ebay.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 04-19-2004, 04:37 PM   #6
72'BBGMCSGCC
I called the dealer and they said they were discontinued.
72'BBGMCSGCC is offline   Reply With Quote
Old 04-21-2004, 10:13 AM   #7
glock35ipsc
Yup, not available from the dealer.
Those that are on eBay, how many different variaties are there of the keyway'd pulleys? Other than different diameters (if that is the case), is there different backspacing (?)
Bob
Old 04-21-2004, 10:42 AM   #8
boraxman
Keepin an eye out
boraxman's Avatar
Keyed are keyed through '84 and all the small block ones are pretty much the same. I would go w/ a aluminum one as the steel ones(on Ebay) are cheap China jobs and tweak easy. You may also find a OE one on Ebay.
ZIP 91351
Old 04-21-2004, 12:10 PM   #9
glock35ipsc
Thanks, boraxman. I checked eBay and found an aluminum one. Good deal, since I have aluminum pulleys already.
And you are absolutely correct about the chrome ones. I bought a chrome water pump pulley. Bent hunk of junk!! That's why I went with aluminum
Bob
Old 04-21-2004, 03:22 PM   #10
69k5
i have one off a 72 k20 4x4. pulled it off this weekend. it wasnt bent that i know off but ill double check just to make sure if your intrested.
69k5
69k5 is offline   Reply With Quote
Old 04-21-2004, 03:23 PM   #11
69k5
ill double check that part # as well.
Old 04-21-2004, 03:42 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Seems like about 1/2 of them are bent nowdays.
I just tweak them back till they are running true again. I've done this to several and never had any more trouble out of them.
Old 04-22-2004, 12:58 AM   #13
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Like TX FIREFIGHTER said, use a rubber hammer to tap the high spot and they normally straighten right up. They bend easy and they straighten easy.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 04-22-2004, 01:00 AM   #14
glock35ipsc
I went ahead and bought an aluminum one off of eBay. But I might go ahead an try to straighten this one out just to have around for the next project
Bob
Old 04-22-2004, 11:31 AM   #15
69k5
itwas the right one if you decide you want it later.
69k5
Old 04-22-2004, 11:36 AM   #16
glock35ipsc
Thanks 69k5. I'll keep it in mind for the next project. How much do you want for it? Send me a PM if you want.
Thanks,
Bob
Bob
Old 04-22-2004, 03:50 PM   #17
69k5
pm sent
