On my 72 1/2 ton blazer dose it have self adjusting rear brake's??
If so how do you make them work agian? I think the self adjuster needs some kind of lube?? Thanks for any input!!
72 blazer, 71 2wd short bed, 67 nova Too many damn toys!! |
go cyclones
I beleive they do. They readust themselves everytime you go in reverse.
I am a Gov't Mule
Last time I did the rear brakes on my K5 the adjusters were frozen with corrosion. After soaking with wd40, I was able to get them apart. Then I put wheel bearing grease on the threads before I reassembled. Works like a charm now.
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy... ![]() |
I'm going try that when I get on the agian.
Thanks for the info!!!!!!!!!
