Battery Wire Path to Starter
What would be the best path to run the battery wire from the starter on a 350. It has headers on it.
Thanks |
![]() Join Date: Mar 2003
I would run it down to the front of the block and along the length of the block
Let me make sure I understand. Do you mean right next to the block behind the headers under the spark plugs all the way up? Green circle.
Thanks |
Run it down along the block under the motor mounts, attaching it to a couple oil pan bolts with wire clamps.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
I agree with the direction offered here running this wiring: come across the pass side of the intake down the front of the block beside the fuel pump, then run it along the oil pan railing with some wire clips alike the original setup was like from GM. Be sure to avoid making too much contact to metal surfaces as this will heat up the wire considerably. One could possibly increase the wire size from the harness at the firewall location before it runs across the top of the engine; I also feel that if a wire is too long it will also lose it's conductivity to operate under hot conditions(summer drives, desert conditions, etc...)
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
I ran it down under the motor mounts and I used a couple of tie locks until I can get my hands on some of the wire clips tomorrow. Thanks for the help. Ill post a pic once I am done.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Ive got mine hidden Run under the battery tray then along the frame and crossing over at the rear away from all heat and out of sight. Looks really clean Id take a pic but it woudlnt do much good.
Mine is much like the routes described...
Don't know if it was left loose originally, but did manage to short and burn almost completely apart. Be sure to use the looms or something to secure it.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
I've got mine wired similar to 1972 C10. No problems with and its hidden.
72 Chevy LWB leaf spring rear,SBC 385 Fast Burn,Art Carr built 700r4,3.73 Eaton posi,one piece windows,lowered 4/5.5, 60/40 seat, shaved turn signals,shaved reverse lights,shaved stake pockets, stainless steel 21gall in rear, c-notched, vintage air,ps,pb,currently doing body work. 68 Camaro conv.327,turbo 350,pb,disc brakes,built it for the wife 38 Chevy Coupe on the back burner LIFE IS GOOD! SMILE |
